16th January 2008, 17:09 | #3001 | Link |
I don't need to search. Haruhiko brought back 98 support a few builds after he dropped it by using unicows.
Anyway, let's see when the first Win98 users start to complain about missing 98 support Edit: 3000th post in this thread Last edited by fastplayer; 16th January 2008 at 17:12. |
16th January 2008, 17:21 | #3002 | Link |
Turkey Machine
Oh bugger, I shoulda known about that, cause I suggested it to him! How silly of me!
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
16th January 2008, 18:30 | #3004 | Link | |
http://lists.mplayerhq.hu/pipermail/...ry/thread.html Last edited by fastplayer; 19th January 2008 at 15:55. |
16th January 2008, 18:31 | #3005 | Link |
Not without comparing the actual changes. It's too much work to specify all applied ffmpeg revisions. So I stopped doing that.
MPC-HC 2.2.1 |
16th January 2008, 20:40 | #3006 | Link | |
Otaku
That plugin is probably blacklisted because I have others like enhancer and dfx and they show up in the list. Even by changing the dsp plugin name won't work.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
17th January 2008, 10:37 | #3007 | Link | |
17th January 2008, 12:45 | #3009 | Link |
Excluded WinAmp plugins are
// DSP stacker, Adapt-X and Vst host are not compatible with ffdshow currently. Maybe ffdshow's bug, but I can't help... if ( _strnicmp(_l("dsp_stacker.dll"),filename,16)==0 || _strnicmp(_l("dsp_adaptx.dll"),filename,15)==0 || _strnicmp(_l("dsp_vst.dll"),filename,12)==0 ) return; |
18th January 2008, 09:37 | #3010 | Link |
Curious BetaTester
i just tried compiling svn 1790 (because of 1788) with 'make UNICODE=yes' but it fails on makeAVIS
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
18th January 2008, 12:31 | #3012 | Link | |
Turkey Machine
@SMD: Regarding your workaround, that does work, but only because MPC falls back on it's internal MPEG-2 decoder (even though it's specifically disabled).
18th January 2008, 12:46 | #3013 | Link | |
should be ok if put at low priority for bug fixing. |
18th January 2008, 13:07 | #3014 | Link | |
Please let me know if you find a similar case. 352 x 480 may be the case. If you can encode such file, could you send me a sample? As for libavcodec mpeg2, I'm not willing to fix as usual. Last edited by haruhiko_yamagata; 18th January 2008 at 13:51. |
18th January 2008, 16:09 | #3015 | Link |
Turkey Machine
Thank you haruhiko. I'm just waiting for a build. I'll see about making a test 352x480 video just to see if that works or not.
18th January 2008, 16:12 | #3016 | Link | |
Life's clearer in 4K UHD
I've just checked my filters. I can confirm that FFdshow is being used: - EDIT: And the aspect ratio is correct also: - Cheers
18th January 2008, 18:49 | #3017 | Link |
Curious BetaTester
maybe i misread the change logs
18th January 2008, 20:25 | #3018 | Link |
When I encode a video using x264 or ffmpeg to 29.97fps, ffdshow shows that the fps is 25 even though I made the fps 29.97 during the encode.
I even checked it out in gspot and it does say 29.97fps. Is this a bug? I have other videos that weren't encoded by me and it shows the correct fps on them. |
19th January 2008, 04:28 | #3019 | Link | |
19th January 2008, 10:42 | #3020 | Link | |
bug report:
I guess this bug is also present in the tryouts? |
