8th April 2016, 11:11 | #37402 | Link |
Feature request.
Thanks madshi for this great software and support. Now madVR works just excellent in my old HTPC. I'd like to ask for adding one feature, if possible. There's "display modes madVR may switch to" string in settings and it works Ok. Is it possible to add "default display mode" string with a single mode madVR would have to switch to when exiting? I'd like to have this setting because the system stuck in 24p after rebooting in an unusual way, i.e. when pausing or playing video. With this setting it would return to usual 50p or 60p after the next play/stop. Thank you in advance. |
8th April 2016, 18:03 | #37404 | Link |
He means in case of a crash, so madVR has no change to trigger a return. Personally, I'd probably just use a specific display mode changer, write a short batch file and put it into Window's auto-start folder.
E.g. "reset_display_mode.bat": Code:
c:\dc.exe -width=1920 -height=1080 -depth=32 -refresh=60 |
9th April 2016, 00:25 | #37405 | Link | |
I did not said its better, only coment its look like sharper because the guy says that 4 is smoother than 3
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500 Windows 8.1 Pro x64 |
9th April 2016, 00:29 | #37406 | Link |
Does anyone who have an nvidia gpu see any difference with triple buffering enabled on nv control panel? Should i enable this?
9th April 2016, 01:01 | #37408 | Link |
Triple buffering don t have application controled option only on and off
9th April 2016, 09:32 | #37411 | Link | |
Option 1: copying the settings.bin file from the madvr folder if it exist. The folder on both OS has to be writable. Option 2. exporting and importing the registry entry using regedit: Code:
HKEY_CURRENT_USER\Software\madshi
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
9th April 2016, 12:07 | #37412 | Link | |
Thank you. The case is closed |
9th April 2016, 20:18 | #37416 | Link | |
Sent from my 306SH using Tapatalk |
9th April 2016, 20:54 | #37417 | Link | |
Posts: n/a
Now I just have to figure out whether it makes more sense to use: 1. Chroma Upscaling NNEDI3 256n + SuperRes (Strength 3) without Image Doubling OR 2. Some other Chroma Upscaling settings with Image Doubling NNEDI3 32n (set to Always) to get the best image possible without dropped frames in 16:9 films. I don't think its possible though... I guess I need to make comparison shots and make a decision! |
9th April 2016, 21:04 | #37419 | Link | |
Is this for real?
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED |
