Old 24th June 2014, 11:30   #26721  |  Link
michkrol
Originally Posted by Anime Viewer View Post
128 seems unnecessary to me. The linked image shows luma image doubling with 32 neurons enabled on the left side, and image doubling off on the right side. With it off the aliasing on the lips, teeth, and circles are noticeable, but I don't notice any difference between the 32 shown in the left picture and any other image double setting be it 16 or 256. Simply enabling it at 16 neurons seems like enough.
Image Doubling on vs off
As always with these tests, the results can and will vary based on source material type, resolution and quality. For anime with thick contours, like in your example just enabling NNEDI works wonders, but live-action imagery can benefit from more neurons.
On the topic of wasted resources. I did some experimenting, and it seems like a waste to use Jinc for Image Upscaling. The image on the left (below) uses bilinear image upscaling while the one on the right (below) uses jinc image upscaling. I don't see a significant difference, and going with bilinear drops the render times by around 10ms.
Bilinear vs Jinc image upscaling
The difference depends mostly on scaling factor, so let me ask, are you using NNEDI doubling for that comparison? If yes, then the scaling factor is ~1.11x meaning you'll only notice switching upscaling to nearest neighbor.
Sometimes, depending on the source, you can get a (subjectively) better image by using cheaper algorithms, because they blur details and hide noise that shouldn't be there in the first place.
All in all, for your example you're right, but you can't say your findings are true for every video out there
michkrol is offline   Reply With Quote
Old 25th June 2014, 02:51   #26722  |  Link
mindbomb
I think I may have found a bug - the "use opencl to process dxva nv12 surfaces" option is active when film deinterlacing is used, and not just for video deinterlacing.
mindbomb is offline   Reply With Quote
Old 25th June 2014, 03:34   #26723  |  Link
Asmodian
Why is that a bug? That option should be active anytime DXVA decoding is used.
Old 25th June 2014, 12:14   #26724  |  Link
magnusr
vt50 settings
Hi
I have panasonic vt50 (16-235) plasma. Windows 8 using ATI 280x with latest driver. Using mphc, lav and madvr.
Is the correct settings:
ATI CCC: pixel format: RGB 4:4:4 (Limited RGB)
ATI CCC: Video: Dymanic range not selected
LAV Video Decoder: RGB output leves: untouched
madvr: RGB output leves: TV levels (16-235)
Is this correct? Thx in advance
magnusr is offline   Reply With Quote
Old 25th June 2014, 12:32   #26725  |  Link
this setting is right if you only care for MadVR use.
just test it with a black clipping file.
can't those tv do 0-255.
Old 25th June 2014, 13:03   #26726  |  Link
magnusr
Thanks So I guess its correct for my mkvs then.
But what do you mean if it's only for madvr use? You mean bad for desktop usage?
Old 25th June 2014, 13:05   #26727  |  Link
DarkSpace
This looks wrong. Assuming that your TV can't handle fullrange RGB, you should set it to either
madvr: RGB output leves: PC levels (0-255)
(which is the general-purpose solution), or to
ATI CCC: pixel format: RGB 4:4:4 (Full RGB)
(which is probably the preferred solution if you care only about your videos displaying correctly - be warned: anything other than madVR will display incorrectly, with clipped colors).
In your current setup, madVR squeezes the 0-255 RGB data into the 16-235 range, and later, your video driver squeezes that 16-235 data, which it thinks is 0-255 data, into 16-235 again!
DarkSpace is offline   Reply With Quote
Old 25th June 2014, 13:57   #26728  |  Link
QBhd
QB the Slayer
QBhd's Avatar
I just did a quick little search for the VT50... I am sure it can handle 0-255 as well as 4:4:4... delve deeper into your manual and settings to find out how to make it happen.
QB
QBhd is offline   Reply With Quote
Old 25th June 2014, 14:03   #26729  |  Link
Neet009
Hi
AFAIK VT50 can handle 0-255.
You could change the option "HDMI/DVI RGB Range" to "Non-standard",and then set everything to 0-255.
Neet009 is offline   Reply With Quote
Old 25th June 2014, 14:10   #26730  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by Plutotype View Post
Hi folks,
Win7 x64 ( Aero disabled ), madvr 0.87.10, MPC-HC nightly, Reclock, AMD HD7750 ( 14.4 WHQL ), Samsung UE65H8500 ( UHD TV ) connected directly per HDMI. 23.976fps movie played back on 3840x2160p24 resolution.
Playback in windowed mode works fine ( fullscreen as well ), but switching on fullscreen exclusive mode, when going fullscreen causes black screen and the playback stops there.
http://www.mediafire.com/download/59...adVR_-_log.rar
Any hint please what blackscreens the FSE mode?
Thanks
in FSE settings.. lower the "how many frames shall be presented in advance" until a picture shows up..
some one helped me out with this before.. mine was set at 16 frames, and black screen, I had to put it down to 12.
Ghetto | 2500k 5Ghz
Old 25th June 2014, 14:14   #26731  |  Link
tp4tissue
tp4tissue's Avatar
Question guys:
if I use windows classic theme without desktop composition on Win7.. there's tearing in windowed playback mode.
is there a fix for this?
Ghetto | 2500k 5Ghz
Old 25th June 2014, 15:01   #26732  |  Link
magnusr
The option hdmi/dvi is not in the menu using a hdmi cable. Then you need to use a dvi>hdmi cable... Atm Im using a hdmi cable.
So there is no 0-255 wihtout dvi>hdmi...
Old 25th June 2014, 15:06   #26733  |  Link
magnusr
The only way to get the tv to display this jpg picture below correctly is to set pixel format 4:4:4 limited (16-235). So I dont think Full RGB is correct for desktop usage either.
If the pixel format in CCC is 4:4:4 full (0-255) I only see 14 of the black boxes. When pixel format in CCC is 4:4:4 limited (16-235) I see atleast 27 boxes
Also using totalmedia theater i can see 17-25 in the calibration video flash when CCC is set to pixel format limited.. If I set CCC to full pixel format I see no flashing in the calibration video.
And with CCC pixel format set to limited and madvr to tv 16-235 I can also see the blinking. If CCC pixel format is set to limited and madvr to pc 0-255 I cannot see the blinking.
Therefore I conclude that the following must be correct fort the VT50 using a hdmi cable from the 280x:
Old 25th June 2014, 15:21   #26734  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
The only way to get the tv to display this picture correctly is to set pixel format 4:4:4 limited (16-235). So I dont think Full RGB is correct for desktop usage either.
Are you viewing that picture using some image viewer or your media player? Remember that
vivan is offline   Reply With Quote
Old 25th June 2014, 15:45   #26735  |  Link
magnusr
Acdsee image viewer and paint gives the same result. Im not viewing the image in the media player.
I use mphc+lav+ madvr and arcsoft totalmedia theatre 6 to see the blinking 17-25 in the calibration video.
Old 25th June 2014, 19:22   #26736  |  Link
blu3wh0
I'm using a GT50 and I have no problems with this, so your VT50 should support Full Range. Make sure you select Non-standard range on your TV options for 0-255. There are three options (Standard, Non-standard, and Auto), do NOT select Auto as it will not properly choose Non-standard when you feed it 4:4:4 RGB (Full Range). Also, madVR needs to be set to 0-255.
blu3wh0 is offline   Reply With Quote
Old 25th June 2014, 20:27   #26737  |  Link
Asmodian
Originally Posted by tp4tissue View Post
Question guys:
There are two modes for Windowed besides Windowed Overlay (Present frames in advanced enabled or not). Which mode are you using? Try the other one.
Old 25th June 2014, 21:33   #26738  |  Link
Trib
Just a quick question about SmoothMotion. When playing a 24fps film with tv at 60Hz the same applies as playing a 60fps film? As in keeping rendering time below vsync interval of <~17ms? Havent used SmoothMotion before, but I've gotten lazy and don't wanna add another filter in my chain(Reclock with 24fps-24Hz) and just use 60Hz with everything after a fresh Windows 8.1 install.
Hardware: Asus P8Z68/GEN-3, 8gb 1600Mhz ddr3, Core i5 2500k, Gtx 680, xonar essence st
Software: MPC-HC, MadVr
Trib is offline   Reply With Quote
Old 25th June 2014, 22:24   #26739  |  Link
Shiandow
You should be able to use smoothmotion with higher rendering times; MadVR only needs to process the frames that are in the original film. The only exception to this is with dithering, but unless you're using one of the error diffusion algorithms that shouldn't be a problem.
Old 25th June 2014, 23:28   #26740  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
SmoothMotion efficiency can vary depending on content. Videos with variable refresh rates can somethings be a problem for it, but then it can also be a problem without it.
Even though you say you don't want to use Reclock you might benefit from using them together. If you're planning on running everything on 60hz then you might find it beneficial to run Reclock at a forced divisible of that - namely 30fps or 60fps. (30fps would be closest to the original source, and less taxing on the system thus probably the best choice of the two). That should pretty much guarantee that you get smooth playback regardless of what video fps the source file may be.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
