Old 21st October 2016, 17:18   #1621  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Simple x264 Launcher v2.76
https://github.com/lordmulder/Simple...ases/tag/v2.76
Version 2.76 [2016-10-21]
* Updated x265 to version 2.1+25
* Updated NVEncC to version 3.01
* Detection of "portable" VapourSynth (see README for details!)
* Detection of "portable" Avisynth (see README for details!)
Old 6th November 2016, 16:19   #1622  |  Link
LoRd_MuldeR
Software Developer
New TEST build with latest x265 encoder:
https://sourceforge.net/projects/mul...6.exe/download
Old 11th November 2016, 14:02   #1623  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Is it possible to use the x264 launcher with VapourSynth installed in portable mode?
I haven't found a way to tell it where VapourSynth and Python are located, and the launcher tells me that VapourSynth is NOT currently installed. I understand that it cannot find it automatically since by definition the portable installation is not tied to the system, but IMO it should be possible to specify the directory somehow, with the preferences dialog or by editing a configuration file. Is it currently possible? If not, can you add that possibility?
r0lZ
Old 26th November 2016, 17:31   #1624  |  Link
BakaProxy
LoRd_MuldeR would it be possible to add a feature in which you can set a custom deadlock value or even fully disable it? Because some scripts have long initialization times which exceed the default 60 seconds, which makes batch encoding quite irritating to handle within your GUI.
Thanks in advance.
BakaProxy is offline   Reply With Quote
Old 27th November 2016, 00:46   #1625  |  Link
LoRd_MuldeR
Software Developer
Thanks in advance.
Please see here:
https://github.com/lordmulder/Simple...nd-line-syntax
Old 27th November 2016, 03:07   #1626  |  Link
BakaProxy
Originally Posted by LoRd_MuldeR View Post
Oh it's actually 5 minutes. Then I can rest assured for now, but I would definitely appreciate it if you can set a custom deadlock value. It would save me some time and effort and I'm sure I'm not the only one who could use this, but that's your decision.
Verstuurd vanaf mijn SM-A500FU met Tapatalk
Old 27th November 2016, 09:47   #1627  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Since I haven't received an answer to that question, should I assume that it's impossible?
r0lZ
Old 27th November 2016, 22:52   #1628  |  Link
LoRd_MuldeR
Software Developer
Sorry, missed that for some reason.
It should be possible now, with the very latest version. But you have to follow instructions exactly:
https://github.com/lordmulder/Simple...md#vapoursynth
Old 28th November 2016, 10:42   #1629  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
OK, thanks! I have already "installed" VS Portable elsewhere, but I suppose that I can do an hard or soft link to duplicate it within the extra folder. But IMO, it would be better to have the possibility to specify the path manually, perhaps with a command line argument, or within the preferences.ini file. Just a suggestion.
[EDIT] Using an hard link (called Junction in Windows terminology) works fine, but a soft link doesn't work. So, the directories with the Simple Launcher and with VapourSynth must be on the same physical partition. An additional reason to provide a way to specify the path. ;-)
r0lZ
Old 9th December 2016, 23:12   #1630  |  Link
LoRd_MuldeR
Software Developer
New TEST build available:
https://sourceforge.net/projects/mul...9.exe/download
Updated x264 and x265 to the latest versions.
Old 14th December 2016, 00:10   #1631  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.77
https://github.com/lordmulder/Simple...ases/tag/v2.77
Version 2.77 [2016-12-11]
* Updated x265 to version 2.1+69
* Updated x264 to revision 2744
* Updated NVEncC to version 3.02
Old 14th December 2016, 03:42   #1632  |  Link
olex99
I have a weird feature request.
I currently do my encoding on a computer that I only have access to on the weekend. I'm usually doing Home Videos for archiving so I only care about quality, I use QTGMC as my de-interlacer and because of this my encodes average around 0.3fps and can take up for 3 weeks to complete.
I use Simple x264 Launcher as my GUI and it works well, I usually have up to 6 Job running at a time as I only use the Single Threaded Avisynth to do the work.
What I would like is a way to see the status of the encode remotely since I only have access to actually be in front of the encoding computer on the weekend. What I do have access to though is the file system. Is there a chance you can add a feature to allow a log file to be written with the status of the encode while the encode is happening? I could then check this file at any time to see where the encodes are up to. I believe it can be done by piping the output to a text file but I don't have anyway in the software to add that command line from what I can see.
olex99 is offline   Reply With Quote
Old 14th December 2016, 15:15   #1633  |  Link
LoRd_MuldeR
Software Developer
Ever heard of VNC?
Really, instead of messing up one tool with too many (unrelated) features, you should use the right tool for each job - and combine them as needed (cf. Unix philosophy).
Having said that, there already is a feature in Simple x264 Launcher to automatically generate a log file for each encoding task.
But this won't be very helpful for you, I guess, because the log file is saved when the encoding task has been completed. The log file is not written (or updated) in "realtime" while the encoding is still running.
And even if the log file was updated in "realtime", it still wouldn't allow you to see the current progress by looking at the file. That's because:
(a) progress lines are not written to the log, because it would completely flood the log. Except for warnings that might pop up throughout the encode, most long lines are either created right at the beginning or at the very end;
(b) even if we wrote all output the the log file in an "unfiltered" way, including progress lines, you still couldn't see progress in "realtime", because the file I/O buffering of the operating system will delay file writes.
Old 2nd January 2017, 19:34   #1634  |  Link
fijam
I've been using Simple Launcher for over a year now, thanks for that great piece of software.
I have three small pet peeves:
1. it's not possible to edit the paths and filenames in source/output directly (the field is not editable, you need to click [...] and edit it there, then click Save again)
2. there is no way to disable custom parameter validation, e.g. I'd often like to use tmod's --aq2-strength and Simple Launcher will not let me do that ("custom parameters are invalid and will be discarded")
3. my templates quickly grow into a rat's nest, some kind of system with categories for templates (DVD/HDTV/BD, or SD/720p/1080p for example, preferably user-editable) would be nice
fijam is offline   Reply With Quote
Old 3rd January 2017, 18:53   #1635  |  Link
Pulp Catalyst
what de-interlacing capability does this have?
also, how difficult would it be to add (NNEDI3 + YadifMod) combination? (there are AviSynth and Vapour-synth plugins available for both).
Pulp Catalyst is offline   Reply With Quote
Old 7th January 2017, 03:31   #1636  |  Link
LoRd_MuldeR
Software Developer
Yes, that's intentional. If free editing was allowed, the user could enter arbitrary invalid or non-existing paths, so we would have to do (rather complex) validation.
Parameter validation can't be disabled for good reason.
However, there was (yet another) small issue in the parameter validation code. Should be fixed in latest TEST version:
https://sourceforge.net/projects/mul...7.exe/download
I will need to think about a solution...
Yes, those are Avisynth/VapourSynth filters. Using them with Simple x264/x265 Launcher is no different than with any other application that supports Avisynth/VapourSynth input.
If you want to use those deinterlacing filters without frame-serving your source from Avisynth or VapourSynth: Nope, that's not possible
Old 7th January 2017, 22:43   #1637  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.78
https://github.com/lordmulder/Simple...ases/tag/v2.78
Version 2.78 [2017-01-07]
* Updated x265 to version 2.2+22
* Updated Avs2YUV to version 0.24 (BugMaster's mod 5)
* Added new option to save pending jobs *without* confirmation
* Some fixes to parameter validation code
Old 10th January 2017, 12:06   #1638  |  Link
masagrator
AviSynth not detected
I don't know why, but Launcher cannot detect my Avisynth 2.6. Is there a way to write a path to Avisynth? I tried with AviSynth+ and works only with 64-bit plugins... Launcher and avisynth are installed on system partition. I tried reinstalling and nothing. Windows 10 64-bit Education. I checked 2 last versions of Launcher. I tried with "portable version", changing name and copying standalone avisynth to Launcher folder. And still the same.
masagrator is offline   Reply With Quote
Old 10th January 2017, 20:34   #1639  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher will launch encoding tools, e.g. x264, as separate processes. And these tools will then try to load Avisynth.DLL, when needed – usually from the "System32" (or "SysWow64") directory.
The only difference in "portable" mode is that Simple x264 Launcher will add "<InstallPath>\Avisynth\{x86,x64}" to the PATH environment variable before launching the encoder process, so that the encoder process will be able to load Avisynth.DLL from that directory too. Still, programs prefer loading DLL's from the "System32" (or "SysWow64") directory, before they fall back to the directories listed in PATH.
Anyway, you can try running "toolset\x86\avs_check_x86.exe" or "toolset\x64\avs_check_x64.exe" manually and look at the output, in order to check for the availability of 32-Bit or 64-Bit Avisynth, respectively.
Old 14th January 2017, 10:39   #1640  |  Link
VincAlastor
Is it possible to add aomenc for testing, please? With your GUI it could be easier to test this new encoder with logs and statistics.
daily nightly builds:
http://forum.doom9.org/showthread.ph...44#post1778544
VincAlastor is offline   Reply With Quote
