Old 27th October 2007, 06:45   #101  |  Link
burfadel
Seems to be fine now! I don't know why I had to delete it twice, but I can't seem to recreate the problem...?!
burfadel is offline
Old 27th October 2007, 09:05   #102  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Tiny request: replace the [ and ] in the command line stuff by something more usable (like " " or remove it completely). Not for me really but somebody report a bug for MeGUI. However, it was a path name issue (There was already a [....]).
edit: forgot to check the doc...there is already a command for that. Sorry.
Kurtnoise is offline
Old 28th October 2007, 02:45   #103  |  Link
Version 1.5.0 beta 9
* An option was added to control how HD videos are displayed. You can now shrink by half (the previous behavior) or you can view any quadrant of the video. This allows the interlace structure of HD videos to be inspected.
* The font size of the Info dialog was reduced so that it all stays visible with the new vertical arrangement.
http://neuron2.net/dgmpgdec/dgmpgdec150b9.zip
The INI file was changed again, so open DGIndex and then close it the first time you use it.
Guest is offline
Old 29th October 2007, 00:11   #104  |  Link
Version 1.5.0 beta 10
Sorry about the quick update, but the fix for emulated audio headers was rejecting some valid headers. I'm pretty sure everything is fully correct now.
http://neuron2.net/dgmpgdec/dgmpgdec150b10.zip
Guest is offline
Old 29th October 2007, 02:35   #105  |  Link
Originally Posted by Sharktooth View Post
we'll have feedback soon, since i added this version to MeGUI autoupdate...
You better get beta 10, because 7-9 may reject valid MPEG audio in program streams.
Guest is offline
Old 29th October 2007, 05:33   #106  |  Link
Please re-download beta 10. A bad build was uploaded.
Guest is offline
Old 30th October 2007, 02:44   #107  |  Link
burfadel
ah ok! that explains the problem I had earlier
burfadel is offline
Old 30th October 2007, 03:47   #108  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
ok...
Sharktooth is offline
Old 1st November 2007, 03:35   #109  |  Link
zurv
on beta 10, 00011.m2ts for spiderman3 (which plays fine in zoom (+cccp))
but, DGindex says "no video sequence header found!"
It also works in DSmux (Haali), but not mkvmerge. *shrug*
ideas?
thanks
zurv is offline
Old 1st November 2007, 03:45   #110  |  Link
Is it MPEG2 video?
Guest is offline
Old 1st November 2007, 03:49   #111  |  Link
zurv
i was about to edit the post.. i assumed it was because the first track worked and was mpeg2.. but i just looked again and the movie itself is avc - didn't expect to see them mix formats
hrmm.. now what to do with avc
at worst directshowsource would work.. but that feels dirty
I guess demuxing the audio would be the big thing...hrmmm
zurv is offline
Old 1st November 2007, 04:11   #112  |  Link
You can try DGAVCDec for the AVC portion.
Guest is offline
Old 1st November 2007, 07:31   #113  |  Link
burfadel
Are you planning to merge Dgmpgdec and DGavcdec in the future? that would resolve people using the wrong one and being confused with mixed tracks etc or even just the need to use two different programmes on mixed tracks!
Just thought it would streamline things a bit , seeing the programme is of similar nature. I know it kind of contradicts the Dgmpegdec name, but technically avc is mpeg4, so the name still works!
burfadel is offline
Old 1st November 2007, 13:56   #114  |  Link
See posts 91 and 93 of this thread.
Guest is offline
Old 2nd November 2007, 20:52   #115  |  Link
jeffy
neuron2, may I please ask, does this really dering (quant=0)?
BlindPP(quant=0,cpu=0,cpu2="ooooxx")
http://forum.doom9.org/showthread.ph...252#post675252
Thank you.
jeffy is offline
Old 2nd November 2007, 21:14   #116  |  Link
I don't know because I didn't write that filter. Generate a clip with and without it in your script and then do a Subtract() to see if there is a difference. You may need Levels() after Subtract to magnify the differences. I use the Levels filter in VirtualDub as it is easier.
Guest is offline
Old 3rd November 2007, 22:29   #117  |  Link
GR
Thx neuron2
beside that would be wonderful if dgindex could let me to set the begin & end not only on the key frame but also on each frame -v-
I need to clear some tvrip's advertisement(.ts or .m2ts) completely for save certain fullest scene
it just a problem now - -b
GR is offline
Old 8th November 2007, 04:50   #118  |  Link
Version 1.5.0 beta 11
* Fixed a problem that caused DGIndex to miss some audio streams. For example, if AC3 substream 0x80 was present, and MPA stream 0xC0 was present, both would be viewed as Track 1, and only the first one encountered would be detected. The concept of track number is removed (as it is a DVD-specific construct), and it is replaced with the concept of audio id. See the users manual for details.
* For MPEG audio streams, the Info dialog now shows full information: audio id, layer, number of channels, sampling rate, and bitrate. This information is also included in the filename of demuxed MPEG audio streams.
http://neuron2.net/dgmpgdec/dgmpgdec150b11.zip
This was a major redesign of audio processing so please beat up on anything audio related and try to break it.
To avoid possible hassles, delete your DGIndex.ini file before running this new version.
Guest is offline
Old 8th November 2007, 07:49   #119  |  Link
Sharc
DGIndex returns BT.709 as colorimetry info for unflagged mpeg2 streams. Is there a reason for this? Shouldn't it better return "unspecified" - or similar - for unflagged streams?
Sorry if this has been already discussed.
Sharc is offline
Old 8th November 2007, 08:18   #120  |  Link
kumi
Straight to video
kumi's Avatar
On the point that Sharc raises, could I request that you allow users to override what colorimetry is assumed by DGindex (and passed via hints) when the sequence display extension fields are absent? At present, when fed SD MPEG-2 input, DGindex assumes Rec.709, but Hank315 believes that the default SD MPEG-2 matrix might in fact be Rec.601. See here.
Thanks for the new beta
kumi is offline
