Old 29th January 2008, 13:49   #261  |  Link
squid_80
They use it for motion estimation. As far as I'm aware decoding doesn't need that.
squid_80 is offline
Old 31st January 2008, 12:14   #262  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I have one question.
Why MPEG Layer-2 audio is demuxed to *.mpa extension instead of *.mp2 ?
Atak_Snajpera is offline
Old 31st January 2008, 13:10   #263  |  Link
buzzqw
HDConvertToX author
@Atak_Snajpera
from vob and ts (mpeg2 video) the audio extension is MPA
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 31st January 2008, 13:16   #264  |  Link
Atak_Snajpera
aaaaaand.... What is your point?
If audio is detected as MPEG Layer-2 it should have *.mp2 extension.
Old 31st January 2008, 14:00   #265  |  Link
buzzqw
HDConvertToX author
look here
audio reported as mpa, extracted as mpa
(if you want i can post the sample vob , 7mb)
BHH
buzzqw is offline
Old 31st January 2008, 15:17   #266  |  Link
Atak_Snajpera
MPA L2 = MPEG Layer-2 = *.mp2
Do you understand me know?
Old 31st January 2008, 15:21   #267  |  Link
buzzqw
HDConvertToX author
.. i loose a "Why" .. fast read as "How"
BHH
buzzqw is offline
Old 31st January 2008, 15:34   #268  |  Link
Is it a problem for you?
MPA covers all layers.
Guest is offline
Old 31st January 2008, 15:47   #269  |  Link
Atak_Snajpera
I think *.mp2 extension is more logical instead of mpa. If I have Dolby digital stream then I have ac3 extension. If I have PCM then I have wav and so on.
Old 31st January 2008, 16:19   #270  |  Link
I didn't ask whether you thought it was logical.
If I have MPEG audio then I have *.mpa and so on.
Guest is offline
Old 31st January 2008, 16:29   #271  |  Link
Atak_Snajpera
If this "too" difficult to change then forget it. It looks like I won't convince you to use correct extension.
Old 31st January 2008, 16:38   #272  |  Link
I asked you a simple question and you refuse to answer. Who is the intransigent one?
http://www.fileinfo.net/extension/mpa
Guest is offline
Old 31st January 2008, 17:15   #273  |  Link
Atak_Snajpera
Some apps (h264tsto or xport) cannot detect audio type so demuxed stream has always .mpa extension. I use NicMPASource only if I have .mp2 extension so I'm sure that stream will be recognized otherwise DirectShowSource is used (if .mpa). You may ask then Why not use DirectShowSource for .mpa and .mp2? Because I've noticed that Nic's plugin is more stable. Besides It would be easier for user if he had .mp2 extension so knew immediately that he is dealing with MPEG Layer-2 compression.
All I'm asking to be more precise.
http://www.fileinfo.net/extension/mp2
Old 31st January 2008, 17:29   #274  |  Link
buzzqw
HDConvertToX author
@Atak_Snajpera
you can use a Try / Catch avisynth script, if nicaudio fails go to dss
or try first with Nic, check for audio channels, and if not 2/error -> go to dss
BHH
buzzqw is offline
Old 31st January 2008, 18:29   #275  |  Link
Atak_Snajpera
It's not very professional solution in my opinion. I will use MediaInfo to rename demuxed mpa to mp2.
Old 31st January 2008, 23:30   #276  |  Link
Inventive Software
Turkey Machine
WTF? How hard is it to rename it to MP2?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 31st January 2008, 23:42   #277  |  Link
Besides It would be easier for user if he had .mp2 extension so knew immediately that he is dealing with MPEG Layer-2 compression. ...
The layer is already specified in the file name. But I suppose it is not difficult to print an extension of mp1, mp2, or mp3, so I will implement that for you. Thank you for the suggestion.
Guest is offline
Old 1st February 2008, 05:43   #278  |  Link
The Scientist
The Scientist's Avatar
oh no, can we have a vote, lol
The Scientist is offline
Old 7th February 2008, 09:32   #279  |  Link
The Scientist
ermmmm, can we vote on that? lol
Old 21st February 2008, 14:28   #280  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
@neuron2: you may be interested in this: https://forum.doom9.org/showthread.php?t=135055
Sharktooth is offline
