Old 9th June 2019, 15:13   #2481  |  Link
stax76
stax76's Avatar
Thanks, I get this error:
Indexing using ffmsindex failed with exit code: -1073741511 (0xC0000139)
The exit code might be a system error code: {Entry Point Not Found}
The procedure entry point hs could not be located in the dynamic link library hs.
Old 9th June 2019, 15:25   #2482  |  Link
StvG
Can you try indexing with ffms2 (ffvideosource() will index the file)?
StvG is offline   Reply With Quote
Old 9th June 2019, 15:32   #2483  |  Link
stax76
stax76's Avatar
For staxrip I would need ffmsindex.
Old 9th June 2019, 15:46   #2484  |  Link
StvG
I added ffmsindex (same download link).
Do you have installed Visual C++ Redistributable for Visual Studio 2015+?
Old 9th June 2019, 15:59   #2485  |  Link
stax76
stax76's Avatar
ffmsindex and memory management is working now, thanks!
Old 9th June 2019, 16:56   #2486  |  Link
STvG,
How did you modify the zip on MediaFire without editing your original post #2483 link ? (Is it a paid MediaFire account option).
Thanx in advance.
Old 9th June 2019, 17:18   #2487  |  Link
StvG
I used trial upload option (without creating account). A pop up window appeared with options skip/replace/keep both when I uploaded the updated ffms2.7z (same file name as the previous one). I replaced the old file with the new one and the shared link is kept.
Other cloud services have an additional option to keep both files with same file names but without renaming any of them - old one is hidden and there is option to see versions of the files. Maybe MediaFire has this option too but just it's not available without account.
Old 9th June 2019, 17:25   #2488  |  Link
Thanks StvG,
I've had a little look around but dont see anything obvious to replace file using same link (Free Account).
If anyone has located MediaFire method to replace file for same link (in free of paid acc), then please post a howto somwhere, cheers.
Old 11th June 2019, 17:48   #2489  |  Link
ChaosKing
@StainlessS Have you considered hosting your stuff on github?
If a "stable link" is important, maybe dropbox is also an option for you.
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 11th June 2019, 19:55   #2490  |  Link
Yes thanks, I considered it last time you suggested it
still same response though, not lookin' forward to figuring out the GIT stuff, maybe one day.
Old 12th July 2019, 06:50   #2491  |  Link
stax76
stax76's Avatar
Old 15th July 2019, 13:17   #2492  |  Link
frank
HolyWu's release of ffms2 has the seek issue at ts streams again but the version (2.31.00 ??) from StvG is ok and much smaller.
StvG, how did you compile it?
frank is offline   Reply With Quote
Old 16th July 2019, 07:49   #2493  |  Link
StvG
My build has reverted those commits. I didn't include any additional libraries (only ffmpeg release/4.1) but I guess the big difference in sizes comes from different compilers (I used msvc).
Here can be downloaded a newer build. It has reverted this commit which should fix that issue. Also it has removed the same thing related to AVC which should fix an issue with 1 frame off.
Old 16th July 2019, 08:17   #2494  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
Your FFmpeg build doesn't have zlib? That's an additional library outside of FFmpeg source code.
I will guess the size difference is beacause the Holywu build has more additional libraries than your build (libaom, libopenjpeg...)
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 16th July 2019, 08:49   #2495  |  Link
StvG
Originally Posted by Wolfberry View Post
Your FFmpeg build doesn't have zlib? That's an additional library outside of FFmpeg source code...
It has zlib.
Old 16th July 2019, 09:23   #2496  |  Link
ChaosKing
I've made a seeking test with "StvG ffms2" and it performs the same as "ffms2_test8.dll" https://forum.doom9.org/showthread.php?t=176231
Old 16th July 2019, 20:59   #2497  |  Link
StvG
Can you show which samples are VP9.mkv and VC1.mpg in your test?
Thanks
Old 16th July 2019, 21:57   #2498  |  Link
ChaosKing
Thanks
https://www.dropbox.com/sh/bxwibb20m...-PvwyU6Aa?dl=0
I wished the newer ffmpeg (ffms2) versions would also be frame accurate for the h264 mp4 files...
Old 17th July 2019, 00:53   #2499  |  Link
videoh
DGDecNV works good for that use case. If you have an nVidia card I can give you a free license (also any other Doom9 developers or contributors, just shoot me a PM).
Old 25th July 2019, 07:01   #2500  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I'm trying to index a DCP sample which has been exported in XYZ 4:4:4 12bit, however FFVideoSource seems to internally convert it to YUV 4:4:4 12bit.
Now I'm wondering... is there a way to let FFVideoSource output XYZ rather than YUV if someone wants to?
I mean, don't get me wrong, the idea of having the conversion done automatically is fine, but what if someone wants to get the original XYZ color space?
Images of what I mean:
Indexing (YUV) - Source (XYZ)
Thank you in advance,
Frank.
Broadcast Encoder
Avisynth memes: 1 - 2 - 3
Videotek - Audacity XP - LUT Collection
