Old 12th May 2017, 22:54   #14221  |  Link
stax76
stax76's Avatar
And mkvmerge accounts this delay? It's shown by a player as chapters (Editions):
Old 12th May 2017, 23:15   #14222  |  Link
sneaker_ger
NeroAacEnc writes the delay info 2 times:
A) as chapter
B) as proprietary iTunSMPB tag
Mkvmerge reads and applies delay from B automatically. A is treated like a regular chapter. So probably best to set --no-chapters for these m4a files.
Old 12th May 2017, 23:18   #14223  |  Link
stax76
stax76's Avatar
Thanks for the explanation, I'll use --no-chapters.
Old 15th May 2017, 18:49   #14224  |  Link
robena
When I use eac3 on Windows 7, every time it completes an operation, it makes a zipping sound.
I could not find it, is there a switch to turn that sound off?
robena is offline   Reply With Quote
Old 15th May 2017, 18:57   #14225  |  Link
sneaker_ger
Delete the .wav file(s) in the eac3to folder.
Old 16th May 2017, 16:24   #14226  |  Link
robena
Thanks, very neat!
Old 4th June 2017, 02:17   #14227  |  Link
Thunderbolt8
sometimes (or often) extracting .sup subtitles from remuxes results in subtitles which are comparably small in size and unusable when trying to open them with the usual programs to edit/ocr subtitles. when extracting these subs with gMKVExtractGUI they works fine though (and are bigger in size). it would be nice if this could be fixed.
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 4th June 2017, 08:56   #14228  |  Link
mkver
Seems that during extraction eac3to doesn't take into account whether the subtitles in the Matroska file are compressed (with zlib/deflate) and treats them as if they were uncompressed.
[Edit]: Looking at the result in a hex editor, I can confirm this.
mkver is offline   Reply With Quote
Old 4th June 2017, 12:08   #14229  |  Link
tebasuna51
tebasuna51's Avatar
Yep, this is the problem.
When you mux the sup with MkvToolNix the default option (automatically) is compress it with zlib, if you select uncompressed after eac3to extract the sup correctly.
Old 4th June 2017, 12:47   #14230  |  Link
Thunderbolt8
so I guess this shouldnt be too hard to implement then...? or is it more difficult than it sounds?
Old 4th June 2017, 13:24   #14231  |  Link
stax76
stax76's Avatar
It's probably not difficult but since there is mkvextract it probably has low priority...
Old 4th June 2017, 15:12   #14232  |  Link
Thunderbolt8
its not that there isnt another possibility to do this, its just very inconvenient when already working with it on a file and remuxing other streams from it and then having to use another tool afterwards again because the subs wont work otherwise.
e.g. with HEVC streams not working as well, when remuxing a file which contains HEVC video, audio with dialnorm and compressed subs, currently youd need either tsmuxer or mkvmerge for the HEVC video, eac3to to remove dialnorm from the audio stream and mkvextract for the compressed subtitle file, while ideally you could do all this just with one step using just eac3to.
Old 4th June 2017, 15:21   #14233  |  Link
stax76
stax76's Avatar
Maybe there there are situations, I just can't think of any, I don't know which tools and formats you use.
Old 18th June 2017, 17:12   #14234  |  Link
stax76
stax76's Avatar
It seems eac3to uses always 24 bit depth for flac output, could this be improved to automatically use only 16 bit depth if the input has only 16 bit? The resulting files are larger then I would decode to w64.
In staxrip currently I convert to flac using eac3to in case qaac cannot read the input format, is there a way I can make eac3to output 16 bit flac? If I remember right then -down16 don't help here, does it even make sense to convert to flac or should rather be w64 used?
The included flac lib is from 2007, I tried to replace it with a newer but it didn't work.
Which formats by extension typically use not more then 16 bit and typically work well with ffmpeg? I believe for many HD formats eac3to works better, for instance with atmos files ffmpeg often showed various errors and defaulted to 6 instead of 7 or 8 channels.
Old 18th June 2017, 17:22   #14235  |  Link
sneaker_ger
I believe eac3to already does that.
sample + log?
sample + log?
Why? That's the only purpose of the option.
Do you want to save space? That's your answer.
Extra-note: eac3to always uses slowest FLAC compression. Probably a waste of CPU/time for intermediate files.
Note that many lossy formats do not have an inherent bitdepth. You can decode to 16, 24, 32, ... bit however you like. Decoding is not as 100% defined as is with e.g. H.264.
Old 18th June 2017, 18:14   #14236  |  Link
stax76
stax76's Avatar
According to MediaInfo my AC3 test file is 16 bit, eac3to converts it to 24 bit FLAC, eac3to writes: Reducing depth from 64 to 24 bits...
                Audio Source File MediaInfo
General
Complete name               : D:\test.ac3
Format                      : AC-3
Format/Info                 : Audio Coding 3
File size                   : 5.33 MiB
Duration                    : 3 min 19 s
Overall bit rate mode       : Constant
Overall bit rate            : 224 kb/s
Audio
Format                      : AC-3
Format settings, Endianness : Big
Bit rate mode               : Constant
Bit rate                    : 224 kb/s
Channel(s)                  : 2 channels
Channel positions           : Front: L R
Sampling rate               : 48.0 kHz
Frame rate                  : 31.250 FPS (1536 spf)
Bit depth                   : 16 bits
Compression mode            : Lossy
Stream size                 : 5.33 MiB (100%)
Service kind                : Complete Main
         Convert to FLAC using eac3to 3.31 x86
eac3to.exe D:\test.ac3 D:\test.flac -down2 -simple -progressnumbers
AC3, 2.0 channels, 0:03:19, 224kbps, 48kHz, dialnorm: -27dB
Removing AC3 dialog normalization...
Decoding with libav/ffmpeg...
Encoding FLAC with libFlac...
Creating file "D:\test.flac"...
eac3to processing took 7 seconds.
Done.
Start:    17:44:09
End:      17:44:17
Duration: 00:00:07
General
Complete name         : D:\test.flac
Format                : FLAC
Format/Info           : Free Lossless Audio Codec
File size             : 36.0 MiB
Overall bit rate mode : Variable
Overall bit rate      : 1 516 kb/s
Audio
Format                : FLAC
Bit rate mode         : Variable
Bit rate              : 1 516 kb/s
Bit depth             : 24 bits
Stream size           : 36.0 MiB (100%)
Writing library       : libFLAC 1.2.1 (UTC 2007-09-17)
Old 18th June 2017, 18:26   #14237  |  Link
sneaker_ger
I don't know why MediaInfo says so. eac3to is working as designed.
https://forum.doom9.org/showthread.php?t=145096
Old 18th June 2017, 18:51   #14238  |  Link
stax76
stax76's Avatar
Thanks, it's clear now.
Old 18th June 2017, 20:40   #14239  |  Link
tebasuna51
tebasuna51's Avatar
I make a request to MediaInfo to don't show Bit depth in lossy formats, without sucess.
Old 18th June 2017, 21:11   #14240  |  Link
stax76
stax76's Avatar
I'll hide it then in case CompressionMode returns Lossy.
eac3to
