Old 26th June 2016, 12:09   #13981  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Ripman View Post
I downloaded 352.8khz wav files from HDtracks...
Nobody can help you because the forum rule 6 :
6) No warez, cracks, serials or illegally obtained copyrighted content! Links to content of a questionable nature (e.g. anything you don't own and/or have downloaded), asking for, offering, or asking for help/helping to process such content in any way or form is not tolerated.
Please read the forum rules.
Old 26th June 2016, 12:19   #13982  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by manolito View Post
Sorry this will not do it for me...
I use this audio conversion in StaxRip, everything should be automatic without any user intervention...
Then we can't help you with that.
Ask in StaxRip thread or use MeGUI (or BeHappy) than allow this operation.
Old 26th June 2016, 12:29   #13983  |  Link
Music Fan
Mostly I will convert AAC audio to AC3 audio. When converting to a lossy compressed format it is never a good idea to normalize to 0dB, I mostly leave a headroom of 2dB.
The problem is that StaxRip cannot use BeSweet for AC3 audio as the target format (this would enable normalizing to arbitrary values), it only can use eac3to.
You can do it with a free audio editor as Adobe Audition (that was earlier Cool Edit Pro).
Music Fan is offline   Reply With Quote
Old 26th June 2016, 13:38   #13984  |  Link
Groucho2004
Fossil
Groucho2004's Avatar
HDTracks is a legitimate site for music downloads.
Groucho's Avisynth Stuff
Old 26th June 2016, 14:45   #13985  |  Link
Ripman
HDtracks.com is a legitimate commercial site for hi-Rez downloads.
Anyway, they have about 80 or so new releases that are 352.8khz, and I'm trying to figure out if I can down sample these. I'll post a mediainfo report when I get in a little later.
Ripman is offline   Reply With Quote
Old 26th June 2016, 16:02   #13986  |  Link
Ripman
I downloaded 352.8khz wav files from HDtracks. I wanted to convert the wavs to 176400 so I can listen on my laptop also.
HDtracks uses a custom field in their wav files to store artwork. This field can sometimes contain many MBs of data.
I used the following command line. It all seems to work nicely. But each converted track has some pretty evil static at the very end.
Eac3to 352.wav 176.wav -resampleTo176400 -0.1dB
What should I change on the command line to get my down sampling to work properly?
As my op describes, I used the following command line with a 352khz wav file as input:
The mediainfo report seemed normal for the down sampled wav, but vlc reported it as a 32bit file.
So I used the following command line:
Eac3to 352.wav 176.wav -little -24 -resampleTo176400 -0.1dB
This also resulted in a down sampled file with static at the very end. Tbh, it seems to occur only with files that have a gain applied via the "#dB" command line option.
I appreciate any ideas on this one. Thanks.
Old 26th June 2016, 16:10   #13987  |  Link
Groucho2004
Fossil
Use SoX for re-sampling.
Old 26th June 2016, 18:20   #13988  |  Link
tebasuna51
tebasuna51's Avatar
Sorry.
Please post the log file to see how eac3to recognize this wav.
Maybe the wav's have extrachunks at end of files not recognized by eac3to, maybe some metadata not compliant with wav spec.
EDIT: without problems in my test:
command line: eac3to.exe 352.wav 176.wav -resampleTo176400 -0.1dB
WAV, 2.0 channels, 0:00:20, 16 bits, 11290kbps, 352.8kHz
Reading WAV...
Resampling to 176.4kHz...
Reducing depth from 64 to 24 bits...
Writing WAV...
Applying -0.1dB gain...
Creating file "176.wav"...
The original audio track has a constant bit depth of 16 bits.
The processed audio track has a constant bit depth of 24 bits.
eac3to processing took 2 seconds.
Done.
The resampling process is done at 64 bits, even the source is 16 bits, but by default the output is 24 bits.
Without static at end of file.
Old 26th June 2016, 21:41   #13989  |  Link
stax76
stax76's Avatar
What can be done is creating an audio profile based on the batch audio encoder instead of the GUI audio encoder.
it's created like so:
audio profiles menu > edit profiles > add > command line
and could look like so:
Old 26th June 2016, 23:01   #13990  |  Link
Ripman
Sorry.
Thanks for your response buddy. Here is a log that I generated. I definitely looks like there is 24bit of audio data. Are you suggesting that I should forgo 24bit processing in favor of 16bit? (As I mentioned above, it seems like I get the "static" issue when I apply a gain.) I'm going to try SoX also.
eac3to v3.29
command line: eac3to  "04-Violin Concerto, _The Red Violin__ III. Andante flautando.wav" "..\24-176.4-2\04-Violin Concerto, _The Red Violin__ III. Andante flautando.wav" -little -24 -resampleTo176400 -3.45dB
WAV, 2.0 channels, 0:06:29, 24 bits, 16934kbps, 352.8kHz
Reading WAV...
Writing WAV...
Applying -3.45dB gain...
Creating file "..\24-176.4-2\04-Violin Concerto, _The Red Violin__ III. Andante flautando.wav"...
The original audio track has a constant bit depth of 24 bits.
eac3to processing took 1 minute, 11 seconds.
Done.
Here is a mediainfo -f report for these files. (I removed the custom artwork tag.)
General
Count                                    : 325
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Count of audio streams                   : 1
Audio_Format_List                        : PCM
Audio_Format_WithHint_List               : PCM
Audio codecs                             : PCM
Complete name                            : C:\52\24-352.8-2\01-Phantasmagoria - Suite from The Ghosts of Versailles.wav
Folder name                              : C:\52\24-352.8-2
File name                                : 01-Phantasmagoria - Suite from The Ghosts of Versailles
File extension                           : wav
Format                                   : Wave
Format                                   : Wave
Format/Extensions usually used           : wav
Commercial name                          : Wave
Internet media type                      : audio/vnd.wave
Codec                                    : Wave
Codec                                    : Wave
Codec/Extensions usually used            : wav
File size                                : 2814506312
File size                                : 2.62 GiB
File size                                : 3 GiB
File size                                : 2.6 GiB
File size                                : 2.621 GiB
Duration                                 : 1329205
Duration                                 : 22mn 9s
Duration                                 : 22mn 9s 205ms
Duration                                 : 22mn 9s
Duration                                 : 00:22:09.205
Overall bit rate mode                    : CBR
Overall bit rate mode                    : Constant
Overall bit rate                         : 16939486
Overall bit rate                         : 16.9 Mbps
Stream size                              : 844934
Stream size                              : 825 KiB (0%)
Stream size                              : 825.1 KiB
Proportion of this stream                : 0.00030
Title                                    : Phantasmagoria - Suite from The Ghosts of Versailles
Album                                    : Corigliano: Violin Concerto, "The Red Violin" - Phantasmagoria
Album/Performer                          : JoAnn Falletta
Track name                               : Phantasmagoria - Suite from The Ghosts of Versailles
Track name/Position                      : 01
Performer                                : Buffalo Philharmonic Orchestra
Composer                                 : John Corigliano, Jr.
Genre                                    : Classical Music, Orchestral
Recorded date                            : 2015
File creation date                       : UTC 2016-05-31 07:39:40.980
File creation date (local)               : 2016-05-31 03:39:40.980
File last modification date              : UTC 2016-05-31 07:42:47.380
File last modification date (local)      : 2016-05-31 03:42:47.380
Cover                                    : Yes
Cover description                        : Picture
Cover type                               : Cover (front)
Cover MIME                               : image/jpeg
Album Artist                             : JoAnn Falletta
Tool Name                                : HDtracks Downloader
Tool Version                             : 20.0.32
Audio
Count                                    : 272
Kind of stream                           : Audio
Format                                   : PCM
Commercial name                          : PCM
Format settings                          : Little / Signed
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : 1
Codec ID/Url                             : http://www.microsoft.com/windows/
Codec                                    : PCM
Codec                                    : PCM
Codec/Family                             : PCM
Codec/Info                               : Microsoft PCM
Codec/Url                                : http://www.microsoft.com/windows/
Codec/CC                                 : 1
Codec settings                           : Little / Signed
Codec settings, Endianness               : Little
Codec settings, Sign                     : Signed
Duration                                 : 1329205
Duration                                 : 22mn 9s
Duration                                 : 22mn 9s
Bit rate mode                            : CBR
Bit rate mode                            : Constant
Bit rate                                 : 16934400
Bit rate                                 : 16.9 Mbps
Channel(s)                               : 2
Channel(s)                               : 2 channels
Sampling rate                            : 352800
Sampling rate                            : 352.8 KHz
Samples count                            : 468943520
Resolution                               : 24
Resolution                               : 24 bits
Bit depth                                : 24
Bit depth                                : 24 bits
Stream size                              : 2813661378
Stream size                              : 2.62 GiB (100%)
Stream size                              : 3 GiB
Stream size                              : 2.6 GiB
Stream size                              : 2.620 GiB
Proportion of this stream                : 0.99970
Here is an audacity screen shot of the "noise" at the end of an eac3to 352-176 down sampled wav -- it's about 1/2 second. Again, the issue occurs when applying a gain. The source 352 wav is clean in audacity.
https://www.dropbox.com/s/ob7781uqvd...nshot.jpg?dl=0
Old 26th June 2016, 23:54   #13991  |  Link
manolito
manolito's Avatar
Thanks Stax,
I already did exactly this...
Obviously there is no way in StaxRip to use BeSweet for AC3 audio (except using the commandline profile). This is too bad because I think that for AC3 target format BeSweet is superior to eac3to. If you use the latest bsn.dll and aften.exe by KurtNoise BeSweet is much more versatile than eac3to.
Thanks and cheers
manolito
Old 27th June 2016, 00:57   #13992  |  Link
stax76
stax76's Avatar
do you have a link to the latest bsn.dll and aften.exe?
Old 27th June 2016, 02:11   #13993  |  Link
manolito
manolito's Avatar
The original Kurtnoise free.fr site seems to be down. I uploaded the two files here:
http://www13.zippyshare.com/v/SkBAb6Av/file.html
For Aften I believe that the latest Wisodev builds also work, but the safest bet is to use the latest Kurtnoise builds.
Cheers
manolito
Old 27th June 2016, 03:25   #13994  |  Link
Ripman
Thanks. I tried SoX 14.4.2 and it works just fine. Here is the sox command line I used to replicate the one I used with eac3to.
sox -V4 352.wav --rate 176400 176.wav gain -3.5 2>sox_log.txt
Old 27th June 2016, 12:16   #13995  |  Link
tebasuna51
tebasuna51's Avatar
No way to use BeSweet for that job.
1) BeSweet can't decode AAC audio
2) BeSweet can't manage wav's (the decoded AAC) bigger than 2GB.
A track 5.1 from a movie is always bigger than 2 GB.
3) The encoded AC3 is the same, not superior, to eac3to output because both use Aften.exe like encoder (using the last bsn.dll in BeSweet).
The solution proposed by Stax76 must work.
I know than eac3to can be improved with this behaviour because if you try directly:
eac3to input.aac output.ac3 -normalize -2dB
first do the -2dB gain an after normalize, then the first operation is useless.
If first normalize and after apply -2dB, or better if take the value -2dB to limit to normalize, the process can be solved with only one pass.
Old 27th June 2016, 14:31   #13996  |  Link
tebasuna51
tebasuna51's Avatar
Nope, was just a sample than show how eac3to manage the resampling.
Here:
Reading WAV...
Writing WAV...
Cover                                    : Yes
Audio
Duration                                 : 1329205 ms
Bit depth                                : 24 bits
Here is an audacity screen shot of the "noise" at the end -- it's about 1/2 second.
The included Artwork tag seems the problem, the WAV structure is not designed to support that metadata. Without a sample I can't know if is a violation of WAV specs or a eac3to bug.
At least eac3to don't support that (incorrect duration calculated) and artwork data considered like audio data (last noise).
Audacity show noise from original file or from the eac3to converted?
Check if Audacity support the Artwork metadata or show also noise from original wav.
Then problem solved.
Old 27th June 2016, 14:39   #13997  |  Link
LigH
LigH's Avatar
I am curious about such a WAV file too, I wrote a RIFF header analyzing tool long ago (originally MS-DOS based, rebuilt for Win32 with Lazarus) and wonder which RIFF chunks it would report (the "data" chunk is not always "the whole rest of the file after the header")... Downloading Gigabytes to obtain a sample is insane, though. Possibly.
New German Gleitz board
Old 27th June 2016, 15:23   #13998  |  Link
Ripman
Thanks for he responses. I don't think the custom artwork field is the problem - the source 352 wav files play fine through my gear, and there is no static at the end that can be heard or seen with audacity. (I put a Dropbox link to a screen shot from audacity in my prior post.) I have previously processed wavs with embedded artwork from hdt in the 44khz-192khz range without issue using eac3to and a gain command line argument.
The problem only occurs when a gain is applied via the #dB command line option. I wonder if it isn't caused by expanding to 32bits to apply gain.
I have a 352khz file that's about 650mb. I'll upload the whole thing when I get in later so people can experiment.
Old 27th June 2016, 18:22   #13999  |  Link
manolito
manolito's Avatar
Sorry I am not sure if I understand you correctly...
I did try your command line with "-normalize -2dB", and the result is that eac3to first applies a -2db gain decrease and afterwards normalizes to 0dB again. Here is the log:
eac3to v3.31
command line: "E:\Programme\StaxRip\Applications\eac3to\eac3to.exe" "I:\test temp files\test ID1 - iv-Undetermined 18ms.wav" "I:\test temp files\test ID1 - iv-Undetermined 18ms_Output.ac3" -448 -normalize -2dB -down16 -progressnumbers
WAV, 5.1 channels, 0:05:00, 16 bits, 4608kbps, 48kHz
Reading WAV...
Reducing depth from 64 to 16 bits...
Writing WAV...
Applying -2dB gain...
Creating file "I:\test temp files\test ID1 - iv-Undetermined 18ms_Output.ac3.pass1.wav"...
The processed audio track has a constant bit depth of 16 bits.
Starting 2nd pass...
Reading WAV...
Remapping channels...
Encoding AC3 <448kbps> with libAften...
Applying 3.8dB gain...
Creating file "I:\test temp files\test ID1 - iv-Undetermined 18ms_Output.ac3"...
eac3to processing took 2 minutes, 2 seconds.
Done.
I want to limit the normalize gain to a max peak value of -2dB, how can I achieve this with eac3to?
Another question about the command line generated by StaxRip:
Is the "down16" parameter meaningful? Does libaften cause problems with an input which has a higher bit depth?
Cheers
manolito
Old 27th June 2016, 19:20   #14000  |  Link
tebasuna51
tebasuna51's Avatar
I test, with eac3to, wav files with extra chunks after the data chunk without problems. For instance cue points created with GoldWave editor.
But, maybe, the eac3to behaviour can change with wav files greater than 2 GB, like here. Is know than there are soft than don't support this limit.
I can't understand how eac3to show a duration of 0:06:29 when seems (by size, channels, bitdepth and samplerate) the correct duration is 00:22:09.205 like show MediaInfo.
eac3to
