Old 22nd December 2014, 14:44   #12881  |  Link
XadoX
XadoX's Avatar
Originally Posted by LigH View Post
Did you really search this thread for "Atmos" before asking this, XadoX?
No I don't. But now I did.
My problem is not relatet in playing those files. I'm having problmes while demuxing a disc containing Dolby Atmos.
XadoX is offline   Reply With Quote
Old 27th December 2014, 16:40   #12882  |  Link
Boulder
Pig on the wing
Boulder's Avatar
(Does anyone have a new libFLAC.dll to use with eac3to? FLAC version 1.3.1 has some improvements to encoding efficiency and speed, which is always a good thing.)
EDIT: found this thread after some more searching: http://forum.doom9.org/showthread.php?t=171480
Old 27th December 2014, 16:45   #12883  |  Link
Lenmaer
Check here http://www.rarewares.org/lossless.php
Lenmaer is offline   Reply With Quote
Old 31st December 2014, 14:10   #12884  |  Link
Anakunda
HI!
what output format should I use to extract MPEG-2 video stream from Bluray? (without any conversion)
I tried .mpeg .mpg .vob .m2ts .mts, everything fail. Does even eac3to support extracting MPEG-2 video from bluray?
Anakunda is offline   Reply With Quote
Old 31st December 2014, 14:20   #12885  |  Link
LigH
LigH's Avatar
In general, eac3to is an audio converter. It will probably not process video streams.
New German Gleitz board
Old 31st December 2014, 14:24   #12886  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Won't it demux it to a Matroska container?
Old 31st December 2014, 14:33   #12887  |  Link
Anakunda
It does. If they're organized into Bluray structure. For DVDs you're right, however I'm demuxing Bluray.
MakeMKV can do this but I'd prefer to use eac3to to demux into bare streams (ie. separate video, separate audio track etc., this is the best for further processing)
Old 31st December 2014, 14:43   #12888  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Use TsMuxeR. It can demux everything from a blu-ray. However, it can't properly demux the video streams from a multi-angle MPLS.
r0lZ
Old 31st December 2014, 14:55   #12889  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I also recommend TsMuxeR, but if you insist on using eac3to, what is the error that you have? eac3to does support muxing MPEG-2 to mkv.
Old 31st December 2014, 15:29   #12890  |  Link
Anakunda
It's the error
H:\video\(workset)\Pulp fiction>eac3to 2) 1:bonus1\source.mpeg
M2TS, 1 video track, 1 audio track, 1 subtitle track, 0:55:26, 50i
1: MPEG2, 576i50 (4:3)
2: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
3: Subtitle (PGS), Czech
This video conversion is not supported.
Old 31st December 2014, 15:33   #12891  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Try "eac3to 2) 1: bonus1\source.mkv" (note the space after "1:")
Old 31st December 2014, 15:39   #12892  |  Link
Anakunda
Yes eac3to 2) 1:bonus1.mkv works but I was hoping that raw demuxing like on Bluray formats will work too. Issue closed, thanks to everybody.
Old 31st December 2014, 16:26   #12893  |  Link
madshi
Use ".m2v".
Old 31st December 2014, 18:59   #12894  |  Link
Anakunda
Use ".m2v".
.m2v is accepted by eac3to. Thanks madshi.
Btw your renderer has problem to render properly subtitles muxed in MKV (not so with subtitles placed aside the mkv)
Old 1st January 2015, 02:28   #12895  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
That should be posted in the MadVR thread, along with a sample (and check the bugtracker).
Win10 (x64) build 18362| GPU Caps Viewer 1.42.4.0
NTSC | DVD: R1 | BD: A
Intel Xeon X5660 @2.80GHz
Old 1st January 2015, 09:34   #12896  |  Link
73ChargerFan
73ChargerFan's Avatar
When you need to know what extension to use for a particular stream, try the -demux option then cancel after 5 seconds, and look at the files it created.
73ChargerFan is offline   Reply With Quote
Old 2nd January 2015, 12:15   #12897  |  Link
whitey1977
whitey1977's Avatar
I recently had 2 drives fail on my RAID5 array so I'm now having to re-rip all my movies. In my collection I have a few HD-DVDs which I converted to blu-rays for easier playback. Since it was over 6 years ago when I originally did this I can't quite remember how I did it.
I've used eac3to to demux amd convert the DD+ tracks and then TSMuxer to combine them into blu-ray structure and this has all worked great, the problem is with the HD-DVDs that have TrueHD audio tracks. These discs show no streams when loaded into eac3to so I can't select them for demux. I'm sure this is the method I used 6 years ago and it may simply be that I'm using a newer version of eac3to that has a bug or no longer supports TrueHD from HD-DVD.
Can anyone help?
whitey1977 is offline   Reply With Quote
Old 2nd January 2015, 12:31   #12898  |  Link
Music Fan
Try HdBrStreamExtractor (GUI for eac3to), it will perhaps detect the True HD track. Or try an old eac3to version.
For the DD+ tracks, I'm not sure you have to make conversion, my Oppo BDP-83 plays DD+ ripped from HD-dvd.
Music Fan is offline   Reply With Quote
Old 2nd January 2015, 12:41   #12899  |  Link
LigH
LigH's Avatar
One source for older eac3to versions should probably be the VideoHelp archive.
Old 2nd January 2015, 12:44   #12900  |  Link
Hitesh12
Is this possible ?
Hey guys I'm very new here so please go easy
So this what I'm trying to do -
Convert a .mkv file with 5.1 DTS audio -
to a .mkv file with 2 audio tracks -
Track no.1 - Encoded flac audio
Track no.2 - Original 5.1 DTS track
Is this possible with a single command (what I mean is that everything occurs in one go; I don't have to extract audio then convert it then mux it; I hope it is clear) ?
If yes, then what should be the commands ?
OT : Just read that post mentioning new FLAC, so I was wondering if there are any other new versions of the default encoders that I should update ?
Hitesh12 is offline   Reply With Quote
eac3to
