9th January 2010, 01:46 | #901 | Link |
@neuron2
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
9th January 2010, 01:47 | #902 | Link |
@neuron2
you can move the loadplugin to the top of the filter chain plus disable whatever filter before opening source
9th January 2010, 01:49 | #903 | Link |
@neuron2
from inside the filter box click on the filter and move it up or down
9th January 2010, 01:59 | #904 | Link |
@neuron2
make filters look like this before opening source
9th January 2010, 02:05 | #905 | Link |
OK, I add the source filter and move it to the top.
Now everything appears to work and I encoded an MKV file. So with just the fix to add .dgi on the CLI -o parameter, things appear to be working fine with DGMultiSource. What else? |
9th January 2010, 02:11 | #906 | Link |
@neuron2
what kind of file you loaded you into StaxRip? no errors show up in log?
9th January 2010, 02:24 | #908 | Link |
@neuron2
DGIndexNV does'nt crash with cli fix but right after indexing and closing upon loading the .dgi StaxRip crashes with the following error Code:
Problem signature: Problem Event Name: BEX Application Name: StaxRip.exe Application Version: 1.1.3.0 Application Timestamp: 4b40797d Fault Module Name: nvcuda.dll_unloaded Fault Module Version: 0.0.0.0 Fault Module Timestamp: 4b076cd3 Exception Offset: 07cc648b Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
9th January 2010, 02:33 | #910 | Link | |||
It includes two applications with setup which is AviSynth and XviD but it will only ask to install XviD if it's actually needed. It will also ask for a YV12 decoder in case ffdshow, XviD or Helix isn't registered as YV12 decoder though the user has to download and install it manually but it helps to register it since it's not easy to register XviD or ffdshow as YV12 decoder. StaxRip also creates a registry key pointing to it's settings directory as the location can be customized and a few included application will create registry keys, VirtualDubMod for instance. All other annoyances like copying plugins to the plugin dir have been removed so it's as light on the system as possible. Quote:
It needs .NET 3.5 instead of 3.0 which would be included in Vista mostly because of a feature called Extension Methods which is extremely useful. There are web installers and offline installers of .NET and there is a full version and a trimmed down client profile version. StaxRip requires only the small client profile version, the web installer versions download only things not already installed so if 2.0 or 3.0 is already installed then it should be really quick. The link to the client profile web installer is in the readme file. Quote:
@MuLTiTaSK I'm not sure if putting load LoadPlugin in front of the source filter would work since StaxRip often generates scripts taking only filters of certain categories, just use: [Source] Automatic = FFMS2 = LoadPlugin("D:\Unsortiert\ffms_test_r257\ffms2.dll") FFVideoSource("%source_file%") or FFMS2 = LoadPlugin("D:\Unsortiert\ffms_test_r257\ffms2.dll")%newline%FFVideoSource("%source_file%")
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 9th January 2010 at 02:39. |
9th January 2010, 02:34 | #911 | Link |
@neuron2
i load .m2ts into StaxRip it indexes, demuxes with DGIndexNV everything goes fine DGIndexNV closes without crashing and i have my .dgi file demuxed audio tracks but right after StaxRip crashes with the error posted
9th January 2010, 02:44 | #914 | Link |
@neuron2
open the .dgi file DGIndexNV created 00054_StaxRip.log Code:
------------------------------------------------------------ Source file info ------------------------------------------------------------ J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.m2ts General ID : 0 Complete name : J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 200 MiB Duration : 1mn 2s Overall bit rate : 26.7 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : AP@L3 Duration : 1mn 2s Bit rate : 18.2 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.367 Stream size : 137 MiB (68%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1mn 2s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 4.73 MiB (2%) Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : TrueHD Duration : 1mn 2s Bit rate mode : Variable Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 4.74 MiB (2%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1mn 2s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 4.73 MiB (2%) Audio #4 ID : 4355 (0x1103) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1mn 2s Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Stream size : 4.73 MiB (2%) Audio #5 ID : 4356 (0x1104) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Duration : 1mn 2s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size : 1.43 MiB (1%) Audio #6 ID : 4357 (0x1105) Menu ID : 1 (0x1) Format : PCM Format settings, Endianness : Big Format settings, Sign : Signed Muxing mode : Blu-ray Duration : 1mn 2s Bit rate mode : Constant Bit rate : 4 608 Kbps Channel(s) : 6 channels Channel positions : Front: L R C, Rear: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 34.5 MiB (17%) Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Text #3 ID : 4610 (0x1202) Menu ID : 1 (0x1) Format : PGS Text #4 ID : 4611 (0x1203) Menu ID : 1 (0x1) Format : PGS ------------------------------------------------------------ DG NV tools - Demux audio and index ------------------------------------------------------------ "I:\dgdecnv2001\DGIndexNV.exe" -i "J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.m2ts" -y 1 -o "J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054 temp files\\00054.dgi" -a -e Demuxer: DG NV tools - Demux audio and index Start: 8:29:15 PM End: 8:29:27 PM Duration: 00:00:11 ------------------------------------------------------------ opening avs/avi ------------------------------------------------------------ thread id: 1 8:29:27 PM 529 DGMultiSource("J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054 temp files\00054.dgi") Width % 8 != 0 || Height % 8 != 0 ? Crop(0,0, -Width % 8,-Height % 8) : last IsYV12(last) ? last : ConvertToYV12(last) at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at StaxRip.AVIFile.Open(String path) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) at StaxRip.MainForm.OpenAnyFile(List`1 l) at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at StaxRip.Startup.Main() ------------------------------------------------------------ avs/avi closed ------------------------------------------------------------ thread id: 1 8:29:30 PM 110 at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at StaxRip.AVIFile.Close(Boolean realClose) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) at StaxRip.MainForm.OpenAnyFile(List`1 l) at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at StaxRip.Startup.Main() ------------------------------------------------------------ opening avs/avi ------------------------------------------------------------ thread id: 1 8:29:30 PM 345 LoadPlugin("I:\dgdecnv2001\DGMultiDecodeNV.dll") DGMultiSource("J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054 temp files\00054.dgi") Width % 8 != 0 || Height % 8 != 0 ? Crop(0,0, -Width % 8,-Height % 8) : last IsYV12(last) ? last : ConvertToYV12(last) at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at StaxRip.AVIFile.Open(String path) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.AviSynthDocument.GetFrames() at StaxRip.Calc.GetOverheadAndSubtitlesKBytes() at StaxRip.Calc.GetTotalBitrate() at StaxRip.MainForm.tbSize_TextChanged() at StaxRip.MainForm.SetTargetLength(Int32 seconds) at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) at StaxRip.MainForm.OpenAnyFile(List`1 l) at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at StaxRip.Startup.Main()
9th January 2010, 02:55 | #915 | Link | |
@neuron2
You don't have to configure the filter profiles, filter setup profiles or templates to use certain AviSynth filters, you can just use a AviSynth script as source file. Quote:
9th January 2010, 03:04 | #916 | Link |
@neuron2
using .dgi as source into StaxRip crash Code:
Problem signature: Problem Event Name: BEX Application Name: StaxRip.exe Application Version: 1.1.3.0 Application Timestamp: 4b40797d Fault Module Name: nvcuda.dll_unloaded Fault Module Version: 0.0.0.0 Fault Module Timestamp: 4b076cd3 Exception Offset: 07ca648b Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt Code:
------------------------------------------------------------ Source file info ------------------------------------------------------------ J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.dgi General Complete name : J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.dgi File size : 21.2 KiB ------------------------------------------------------------ opening avs/avi ------------------------------------------------------------ thread id: 1 9:00:30 PM 468 DGMultiSource("J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.dgi") at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at StaxRip.AVIFile.Open(String path) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) at StaxRip.MainForm.OpenAnyFile(List`1 l) at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at StaxRip.Startup.Main() ------------------------------------------------------------ avs/avi closed ------------------------------------------------------------ thread id: 1 9:00:32 PM 939 at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at StaxRip.AVIFile.Close(Boolean realClose) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) at StaxRip.MainForm.OpenAnyFile(List`1 l) at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at StaxRip.Startup.Main() ------------------------------------------------------------ opening avs/avi ------------------------------------------------------------ thread id: 1 9:00:33 PM 146 LoadPlugin("I:\dgdecnv2001\DGMultiDecodeNV.dll") DGMultiSource("J:\_BACKUPS\BR\VOLUME_SET_ID\BDMV\STREAM\00054.dgi") at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at StaxRip.AVIFile.Open(String path) at StaxRip.AviSynthDocument.Synchronize() at StaxRip.AviSynthDocument.GetFrames() at StaxRip.Calc.GetOverheadAndSubtitlesKBytes() at StaxRip.Calc.GetTotalBitrate() at StaxRip.MainForm.tbSize_TextChanged() at StaxRip.MainForm.SetTargetLength(Int32 seconds) at StaxRip.MainForm.OpenVideoSourceFiles(List`1 files, Boolean autoMode) at StaxRip.MainForm.OpenAnyFile(List`1 l) at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at StaxRip.Startup.Main()
9th January 2010, 05:44 | #918 | Link |
I agree with on this point. I'll expand on it a little bit. As soon as a program says that it doesn't work, or not work well, with XP, it is off my list of usable programs.
Vista was a nightmare that never really made it and Win 7 is too new. XP is the choice Windblows OS by many. I have a very viable OTA tuner card that is never going to be updated. IMHO, dropping support for XP is not a good idea. |
9th January 2010, 05:56 | #919 | Link | |
StaxRip works with XP most problems reported are only cosmetic nothing to sweat many StaxRip users are running XP
