17th April 2011, 01:13 | #7061 | Link | |
PS:my displayer refresh rate 50 or 60Hz,movies fratemate is 4 frame , 5 or 8 ,too |
17th April 2011, 13:28 | #7063 | Link |
after long 5 days
using: mpc-hc, ffdshow, lavsplitter, madvr i got problems with sounds playback of aac (lc) & pcm (big/unsigned) in mov and mp4 container the sound is scratchy and many clicks and pops when i change back to evr renderer i have a clear sound And now i have scratchy sound in some mkv with ac3 too, i got this terrible sound only in combination with madvr. but i like the damn good video quality with spline i do not like change back to evr in some files how can it possible that madvr destroy my sound http://www.megaupload.com/?d=0NYZMKP5 here is a sample of my sound it sounds to me when i use madvr |
17th April 2011, 14:04 | #7064 | Link |
3 eyed CRT supporter
madshi, the disable desktop composition setting (obviously when the PC has Aero enabled), drops it to 60i, rather than 96i. During the black flash Powerstrip is disabled somehow - in a similar fashion to when you install a program and it all goes dark for the prompt question.
My workaround is to turn of Aero completely, just thought you'd like to know. |
17th April 2011, 14:27 | #7065 | Link |
First of all, a big for this wonderful software!
A quick question, after updating my ffdshow, madvr, resetting MPC-HC I have everything working pretty well. Using the lavsplitter and Arcsoft HD audio decoder to get DTS-MA, too. My rather modest setup (ATI 5450, Win7, 2.4GHz CoreDuo CPU) can play all but the most demanding material (i.e. Avatar). My question is when I launch MPC-HC from within XBMC, it comes up in full screen, but not exclusive mode. If I bring up the settings window for one of the filters and then close it, it will switch to exclusive mode and all is well. Not sure if this is a madvr issue or MPC-HC? |
17th April 2011, 17:54 | #7066 | Link |
Some remarks about vc-1 stream in m2ts container.
.56, W7, 5750, 11.3, MPC-HC, Aero on 8 prepresented frames Cyberlink 10 decoder - madvr reports unknown fps, very smooth, no dropping frames MPC HC decoder - madvr reports 23.976, very smooth, no dropping frames WMV decoder - madvr reports 23.976, many dropped and delayed frames 4 prepresented frames Cyberlink 10 decoder - very smooth, no dropping frames MPC HC decoder - very smooth, no dropping frames WMV decoder - very smooth, no dropping frames 16 prepresented frames Cyberlink 10 decoder - very smooth, no dropping frames MPC HC decoder - very smooth, no dropping frames WMV decoder - many dropped and delayed frames madshi for all! Last edited by nlnl; 17th April 2011 at 17:57. |
17th April 2011, 18:24 | #7067 | Link | ||
17th April 2011, 20:11 | #7068 | Link | |
terrible glitches on your setup. Pls download this utitlity, run it with madVR and EVR a post both results: http://www.thesycon.de/deu/latency_check.shtml I have reported DPC issues with madVR a 2 months ago. Some sound chips can handle the sound also if DPC peaks are occuring - without any sound glitches. This is the case of my motherboards Realtek ALC889. But my main soundcard, RME Babyface does not like DPC latencies at all - I hear occasional dropouts ( not like yours ) when mpc-hc with madVR is running. The difference in DPC latency between EVR and madVR is here to see: http://img12.imageshack.us/f/evrcpdpclatency.png/ http://img220.imageshack.us/f/madvrdpclatency.png/ Till date I havent found out, what is madVR doing differently from EVR CP that these DPC latencies occur. My CPU is i7 980x where madVR setup runs on 5-7 percent (0.56) Pluto
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver Last edited by Plutotype; 17th April 2011 at 20:15. |
17th April 2011, 20:24 | #7069 | Link |
[QUOTE=6233638;1493608]What is your CPU usage like? Usually that is the cause of audio problems.
Test Video 1080p@6279Kbps, 23,976 fps 160 Kbps, 48,0KHz,2 channels, AAC (LC) nearest neighbor all trade of quality all marked average cpu -- 20% - 30% chroma softcubic soft 50 luma up spline 4tab luma down spline 4tab trade quality all unmarked average cpu -- 15% - 25% gpu load 24% the bad sound only comes with madvr i test the video with 4 cores my system must be handle this clip i do not have problems with dropped frames or something even the samsung Demo Oceanic Life runs without problems except the damn sound my soundcard is an creative x-fi fatality http://img17.imageshack.us/i/evrt.jpg/ http://img215.imageshack.us/i/madvrt.jpg/ another one http://img576.imageshack.us/i/anotheronef.jpg/ Last edited by moliko; 17th April 2011 at 21:16. |
17th April 2011, 21:02 | #7070 | Link |
Plutotype,
I've just checked it and the latest version of madVR is not giving me high DPC latency ... it's either fixed or it could be that I've recently changed my video card to NVIDIA ... if I have more time tomorrow I'll test with the old version of madVR, which I used when I had the problem a few months ago, and report
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
17th April 2011, 21:08 | #7071 | Link | |
Your new exclusive mode function doesn't work with my computer since madvr 0.51. Is it possible to correct this problem? With madvr 0.5 it works very well. |
17th April 2011, 22:50 | #7072 | Link |
@6233638
here another system pic in was i change my cpu back to X2 http://img215.imageshack.us/i/67136505.jpg/ as X2 he is still able to play 1080p vids with spline |
17th April 2011, 23:14 | #7073 | Link |
Kid for Today
running XPSP3/8800GS and a USB audio transport(Firestone Bravo), I only get spikes when going FSE<>FSW. They're not red, and they don't make audio glitches:
Have you tried to lock the clock speeds of your CPU/GPU? Last edited by leeperry; 17th April 2011 at 23:56. |
17th April 2011, 23:55 | #7074 | Link | |
Yes I have tried everything. Will try to swap the graphics for another model, because users Moliko and Pankov had also Sapphire graphics ( 5670/57xx ) and we all have experienced DPC latency spikes. Just an idea, dont want to discuss it here more. Anyway, 0.56 rocks, yesterday watched 140min movie a at the end pressed ctrl-j: zero dropped frames and 1 dropped frame in 15hours. Nice.
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
18th April 2011, 12:06 | #7080 | Link | |||||||||||||
The only options that impact quality are those in the "trade quality for performance" section (leave them all unchecked, if you want max quality) and of course the scaling algorithms (choose the algorithm which is most pleasing to your eyes, there's no "best" algorithm). All other options do not affect image quality. Unless you have tearing or non-smooth playback in windowed mode. In that case I would suggest to use the exclusive mode. Quote:
Not anytime soon. Too much other important stuff to do. Quote:
In theory madVR does not do anything to audio. Quote:
The *real* cause of the problem is a faulty splitter, though! Choose a good splitter, please, and you'll have perfectly smooth VC-1 playback with the MS VC-1 decoder + madVR with 8 or 16 pre-presented frames, too. Quote:
This seems to be caused by the VSync scanline reading stopping to work sometimes. I've done some changes in that regard in newer versions which actually improve things in certain situations. But it seems things got worse in other situations. I'm playing around with using a different scanline reading API now. Maybe that will fix things completely. Or not... |
