6th June 2019, 15:26 | #241 | Link | |
See edit in my prev post.
Those are for your 64 bit version of avs, you must have used a dual setup installer. The 64 bit avs requies ALL 64 bit dll's and runtimes. Can check with eg AvsMeter64 avsinfo Quote:
By the Way, 32 bit MeGUI requires 32 bit AVS, 64 bit MeGUI requires 64 bit AVS (and all associated dll's etc). The GetSeq thing just replaces you source filter eg AviSourcE(Filename) or ffms(Filename), just substitute remainder of your script after tha Getseq call (using your filename in GetSeq)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th June 2019 at 15:32. |
6th June 2019, 15:33 | #243 | Link | |
Just leave it alone. You may later want to upgrade to x64 or use sometimes, and use 32 bit other/most times.
Again, see above edit. EDIT: Quote:
6th June 2019, 15:39 | #244 | Link |
So in full something like this
Function GetSeq(String vFn,String "aFn") { Function IsISOFileName(String s) {s=RT_GetFileExtension(s) Return(s==".mov"||s==".mp4"||s==".m4v"||s==".3gp"||s==".3g2"||s==".mj2"||s==".dvb"||s==".dcf"||s==".m21")} Function IsRiffFileName(String s) {s=RT_GetFileExtension(s) Return(s==".avi"||s==".wav")} myName="GetSeq: " aFn = Default(aFn,"") aFn = (aFn=="") ? vFn : aFn Assert(vFn!="",RT_String("%sVFn Cannot be ''",myName)) vFn = vFn.RT_GetFullPathName IsRiffV = vFn.IsRiffFileName IsIsoV = vFn.IsISOFileName Assert(aFn!="",RT_String("%saFn Cannot be ''",myName)) aFn = aFn.RT_GetFullPathName IsRiffA = aFn.IsRiffFileName IsIsoA = aFn.IsISOFileName c=0 a=0 Try { # 1st Try specialized AVI c = (IsRiffV) ? vFn.AviSource : NOP (c.IsClip) ? RT_DebugF("AviSource opened Video\n '%s'",vFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } Try { a = (c.IsClip && c.HasAudio && aFn==vFn) ? c : (IsRiffA) ? aFn.WavSource : NOP (a.IsClip && a.HasAudio) ? RT_DebugF("%s opened Audio\n '%s'",(c.IsClip && c.HasAudio && aFn==vFn)?"AviSource":"WavSource",aFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } # Next try specialized ISO LSMash Try { IsOpenV=(c.IsClip && c.HasVideo) c = (IsIsoV) ? LSMASHVideoSource(vFn) : c (IsIsoV) ? RT_DebugF("LSMASHVideoSource opened Video\n '%s'",vFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } Try { IsOpenA=(a.IsClip && a.HasAudio) a = (IsIsoA) ? LSMASHAudioSource(aFn) : a (IsIsoA) ? RT_DebugF("LSMASHAudioSource opened Audio\n '%s'",aFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } # Next try FFMS2 Try { IsOpenV=(c.IsClip && c.HasVideo) (!IsOpenV) ? FFIndex(vFn) : NOP c=(!IsOpenV) ? FFVideoSource(vFn) : c (!IsOpenV) ? RT_DebugF("FFVideoSource opened Video\n '%s'",vFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } Try { IsOpenA=(a.IsClip && a.HasAudio) a=(!IsOpenA) ? FFAudioSource(aFn) : a (!IsOpenA) ? RT_DebugF("FFAudioSource opened Audio\n '%s'",aFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } # Next try LSmash non ISO Video Try { IsOpenV=(c.IsClip && c.HasVideo) c = (!IsOpenV && !IsIsoV) ? LWLibavVideoSource(vFn) : c (!IsOpenV && !IsIsoV) ? RT_DebugF("LWLibavVideoSource opened Video\n '%s'",vFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } Try { IsOpenA=(a.IsClip && a.HasAudio) a = (!IsOpenA && !IsIsoA) ? LWLibavAudioSource(aFn) : a (!IsOpenA && !IsIsoA) ? RT_DebugF("LWLibavAudioSource opened Audio\n '%s'",aFn,name=myName) : NOP } catch (msg) { RT_DebugF("Catch: %s",msg,name=myName) } Assert(c.IsClip, RT_String("%s failed open on\n '%s'",myName,vFn)) (!c.HasAudio && a.IsClip && a.HasAudio) ? AudioDubEx(c,a) : c (!HasAudio) ? RT_DebugF("Audio failed Open on\n '%s",aFn,name=myName) : NOP return Last } FN="C:\Users\padge\Documents\test video.mp4" GetSeq(FN) FrameRateConverter() # defaults FrameRate * 2, both takes and produces clip Last return Last (the part before FN="... etc") And use eg just this Code:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th June 2019 at 15:42. |
6th June 2019, 15:41 | #245 | Link |
I tried this code and it said i have a syntax error on line 60 column 7
EDIT: in case you were wondering what the error was... there was an extra quotes mark. FN=""C:\Users\padge\Documents\test video.mp4" Last edited by hfrforever; 6th June 2019 at 15:49. |
6th June 2019, 15:49 | #247 | Link |
Yep, sorry I already fixed it. Is doubled Double Quote at beginning of FN, remove one.
FN=""C:\Users\padge\Documents\test video.mp4" EDIT: Put these two dll's in your SysWOW64 folder [req by FFT3DFilter and DftTest, and MvTools when arg DCT!=0]] http://www.mediafire.com/file/hv1y09...uz/FFT.7z/file (Groucho likes to put them somewhere else, but I prefer above [at least for now]).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th June 2019 at 16:03. |
6th June 2019, 15:54 | #249 | Link |
Only in 64 bit plugins, and only with x64 avs (one or other cannot use both at same time, windows thing).
See prev edit.
6th June 2019, 16:06 | #252 | Link |
Yes, thats Masktools2.
Didnt we have a wonderful day, the day we went to Bangor, A beautiful day, we had lunch on the way, and all for under a pound you know, and on the way back, I cuddled with Jack and opened a bottle of cider, singin' a few of our favourite songs as the wheels went round ... EDIT: Fiddler's Dram - "Day Trip to Bangor (Didn't We Have a Lovely Time ... https://www.youtube.com/watch?v=wfwQi8L9h8M
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th June 2019 at 16:30. |
6th June 2019, 16:08 | #253 | Link |
it was mask tools 2. It still says that there is no function named 'RT_String'.
EDIT: I am officially to the ripping hair out stage. thank you very much for your infinite patience Last edited by hfrforever; 6th June 2019 at 16:13. |
6th June 2019, 16:15 | #254 | Link |
Comment out the FrameRateConvert line (precede with '#' character)
Try in VDub (NOT x64 version, not x64 version media player, MUST use ALL 32bit or ALL 64 bit), if complaining about RT_string, its because its the very first used external function from dll, I'm guessin' because you are using x64 AVS via x64 player, and ALL plugins are 32 bit, so ALL will fail, its just that RT_string is first in line pending fail. EDIT: Probably Vdub2 is your favourite bet, as has both x86 and x64 versions. If works OK, then uncomment.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th June 2019 at 16:18. |
6th June 2019, 16:33 | #258 | Link |
Have you tried in MeGUI since now got it working ? Should work OK unless you have installed 64 bit MeGUI, (which is not quite stable as yet).
EDIT: And yes, motion compensated processing can be slow. (A few years back I spent 3 days rendering a movie [LOTR-ROTK]).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th June 2019 at 16:35. |
6th June 2019, 16:43 | #260 | Link |
Check [expand] first line in log, Versions.
