22nd October 2012, 20:10 | #15001 | Link |
Hey these two at the same time don't make sense, anyway I never notice a loading time even just using a SSD. Give it a try, it is much easier and faster than it was in the first versions. It seems pointless for madshi to implement different gamut mapping options to me, unless something really is wrong with yCMS.
22nd October 2012, 20:24 | #15002 | Link | |
Jinc has to be done in 1-pass 2D. It doesn't work any other way, because the true distance "Sqrt(xDist*xDist + yDist*yDist)" is used to calculate the weight of the source pixels around the destination pixel. For Jinc3 you basically use a circle of source pixels with a max distance of 3.0 around the destination pixel. Here are test results with a very artificial test pattern. It shows quite nicely the key difference between Lanczos and Jinc, IMHO. You can see that the whole "look" (including ringing artifacts) is more rectangular with Lanczos and more round with Jinc: original image -|- Lanczos4 -|- Jinc4 -|- Jinc4 AR As you can see, there are still some artifacts in the Jinc4 AR algorithm, so it still needs some improvement. |
22nd October 2012, 20:31 | #15003 | Link |
Nicolas Robidoux
@Eric: What colorspace to use is not fully dependent on the filter. See http://www.imagemagick.org/discourse...p?f=22&t=21804, which unfortunately does not include Y'CbCr, and uses a variant of tensor Lanczos 3 that I like more.
22nd October 2012, 21:12 | #15004 | Link | |
Thanks for your time. I have one somewhat personal request: Can you check this ticket https://sourceforge.net/apps/trac/mpc-hc/ticket/2671 I opened in the MPC bug tracking system and share your opinion on the subject? In short it's about a problem with VSFilter which "clears" the deinterlace flags in the video and thus cheating madVR into not deinterlacing a perfectly interlaced 1080i50 video captured with a digital camera. Do you think it's possible for madVR's "detection engine" to ignore the value of dwInterlaceFlags that VSFilter sets and read it from the decoder/filter which is before VSFilter in the graph? After all we know that VSFilter can't do deinterlacing so I think it can't be a reliable source for this flags, right?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 Last edited by pankov; 22nd October 2012 at 21:59. |
22nd October 2012, 21:17 | #15005 | Link |
QuickSync Decoder author
@Nicolas
Thank a lot.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
22nd October 2012, 21:27 | #15006 | Link |
@pankov, please use xy-vsfilter and if that has the same problem, report it there. The xy-vsfilter developer actually does fix bugs, so you have a pretty good chance to getting it fixed there. Of course it would be possible to work around the problem in madVR, but it would cost me extra time, so I'm reluctant. Soon, madVR + xy-vsfilter will be the best subtitle solution, anyway, and will totally bypass the normal DirectShow connection chain.
22nd October 2012, 22:05 | #15007 | Link |
madshi,
I was actually using xy-vsfilter and it has the exact same problem. I was advised (by cyberbeing) to report it to the MPC team because the xy-vsfilter developer is alone and doesn't have much experience with such interlaced files. I guess I'll wait for the real solution (the one that bypasses the DirectShow chain) and use the new keyboard shortcuts that I'm now able to control via Girder (thanks again) till then. I just wanted your expert opinion on the matter. Thanks again.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
23rd October 2012, 03:45 | #15008 | Link |
Nicolas Robidoux
Eric:
Here is an example of EWA LanczosSharp (a.k.a. Jinc 3) used with an alternate method, namely sigmoidization, that reduces halos and that Mathias found does not work well in some circumnstances. (And I'm going to have to double check on this, because it's worrisome. I'm actually not sure at all it would work well with Y'CbCr. And, after Mathias comments, I'm not even sure it always works well with sRGB pngs.) http://web.cs.laurentian.ca/nrobidou...sSharp.7p5.png Last edited by NicolasRobidoux; 23rd October 2012 at 03:51. |
23rd October 2012, 04:38 | #15009 | Link |
Kid for Today
Quite frankly what I hate with new computer parts is that they lose 50% of their value in 1 year, and 2 years later they can only be sold as paper weights...there's also a large number of ppl who constantly upgrade being desperate to sell their 1yo board for cheap , but the 650Ti seems to provide a much higher bang for bucks ratio -even brand new- so buying used doesn't seem to make much sense.
So anyone's got an advice on a good nvidia board for 720p to 1080p Jinc3 AR chroma+luma upscale please? How about a $150 1GB GTX650Ti? I've got no idea how much crunching power this monster of an algorithm might require for 720p to 1080p....really the +1K SP's of the 660 But it's good to see that the 650Ti is a very power efficient GPU and that my 400W Corsair PSU will do nicely: http://www.tomshardware.com/reviews/...6,3318-18.html BTW, I advised Kazuya to try Jinc3 AR upscale and he's hooked! He ditched his ffdshow Spline upscale profile in a split second, figures OK, sounds good! I'll be running gamut mapping comparisons then Last edited by leeperry; 23rd October 2012 at 06:52. |
23rd October 2012, 05:29 | #15010 | Link | ||
Broadband Junkie
Since this was brought up here, what would you consider the 'correct' way VSFilter should handle interlaced video flags, considering it likely 'weaves' interlaced video to progressive (combing artifacts), alphablends progressive subtitles on top, and then outputs to a video renderer like madVR? Can such video actually be properly deinterlaced after VSFilter has had its way with it? If so, how should it be flagged? |
23rd October 2012, 07:05 | #15011 | Link |
Video is already "weaved" when you get it. DirectShow doesn't really do single interlaced fields, what you get is one image with both fields weaved together. As long as you don't modify the video itself (scaling or conversion to another pixel format unsupported by GPU deinterlacing), you should just output it as-is with the same flags as from the source (dwInterlaceFlags is usually 0x81, AMINTERLACE_IsInterlaced|AMINTERLACE_DisplayModeBobOrWeave, on many video decoders), and of course the per-frame flags should stay as well (they indicate field order, and which frames to deinterlace). In short, just pass-through the dwInterlaceFlags value and the per-frame flags.
23rd October 2012, 08:33 | #15012 | Link | |||
23rd October 2012, 10:51 | #15014 | Link |
Yes, of course. FPS makes one hell of a difference. Twice as much FPS means roughly twice as much work for every part of madVR. What I was trying to say is that GPU consumption does not depend on whether you're watching a soft and slow motion landscape or whether you're watching a sharp and high motion action movie.
23rd October 2012, 12:10 | #15015 | Link | |
Broadband Junkie
On my GT440, certain colorful high motions scene will cause a temporary +5-15% increase in GPU usage (i.e. 25%->30-40%), without any queue drops. The more powerful the GPU, the less change there is. Nothing new, as it's the same problem we discussed extensively in the past mostly related to my 7800GTX and that GTX460 I briefly tested. Still it's noteworthy for users of lower powered NVIDIA GPUs, as I know Fermi and prior generations suffered from this. No idea about Kepler. |
23rd October 2012, 12:32 | #15016 | Link | |
Kid for Today
I'm not a fan of debanding or sharpening, but diffusion/floyd-steinberg dithering would indeed kill IIRC, each pixel in games like Crysis 2 goes through like a thousand PS scripts, and simple video PS scripts in MPC barely require any GPU cycles. CUDA optimization would also be most welcome, but I can understand that this would be a waste of your time, considering that ATi provide better bang for bucks if you're willing to live without CUDA & CUVID. It's about time you cash-in on mVR and hire a bunch of ppl to assist you A major A/V nutcase who's given the taste of endless HTPC setup nitpicking to many ppl on HCFR. Apart from the red test pattern you used in the OP(that I cut from the end credits of "Les Bronzés font du ski"), he's the one who provided all the other video test patterns I use. I very much trust his judgment |
23rd October 2012, 13:50 | #15017 | Link | ||
23rd October 2012, 16:05 | #15018 | Link |
Hi, since it's the first time I post in madVR thread, I would like to state how worderful this software is and what a great and methodical job madshi has done in developing it! Thanks a lot!
Now, I am trying to calibrate a friend's lcd tv using some test patterns. While playing arround, I decided to create some paterns of my own using photoshop. So, the question is, which color profile should I choose for the images in Photoshop? Forgive my ignorance in such matters, but apart my pc monitor, I haven't calibrate any other digital display. The available ones are below: Should I choose sRGB, Rec.709 or something else? The calibration will be performed using a laptop (win7 and ati card, if that's important) connected via hdmi. I am keen on testing madVR's image displaying when support (through lav filters) is ready, as well. |
23rd October 2012, 16:05 | #15019 | Link |
Nicolas Robidoux
Mathias:
The http://madshi.net/housetop.png test image is a pain in the *ss. Enlarging through Lab, which has always looked slightly better in my tests than using straight sRGB, gives a result that is also more jaggy on the roof line (like the sigmoidized result at contrast=7.5). I'm reasonably sure that what is going on is that you want something which is "maximally good with dark halo" because the original has significant light halo next to sharp dark features, and in a sense you want to minimize the halo of this light halo. And, among the common options, it's sRGB, not sigmoidizing, not linear RGB, not Lab. I'm very tempted to chalk it up to "exception", just like the "cabins" image has dark letters which happen to be friendly to ... linear RGB. If you some time at some point, and you happen to know, please point me to other test images where sigmoidization "fails". At this point, I suspect that originals with haloing may not always be sigmoidization's friend. Last edited by NicolasRobidoux; 23rd October 2012 at 16:19. |
23rd October 2012, 16:12 | #15020 | Link |
Nicolas Robidoux
Ah ah! I think I see what's going on:
The original housetop.png has a very pronounced asymmetrical dark straicase on that roof line. It's actually in the original. Enlarging straight through sRGB happens to "paper over" this oscillation found in the original. I feel better now. (Not that sigmoidization is necessary safe from challenge. Far from it. But it's nice to see that actually sigmoidization and Lab are more faithful to a feature found in the original.) P.S. That is, the "antialiasing" of the roof line is only effective on the "light" end, right in the original. |
