30th March 2019, 15:23 | #341 | Link | |
SuperVirus
what is the error message(s) that Windows XP returns? |
30th March 2019, 21:02 | #342 | Link | |
typeperf "\Process(mkvmerge)\% Processor Time" -si 10 -o mkvmerge.txt For the command line, directly cut pasted form the GUI, I got a file that looks like: Code:
"(PDH-CSV 4.0) (Romance Standard Time)(-60)","\\NT\Process(mkvmerge)\% Processor Time" "03/30/2019 19:58:15.817"," " "03/30/2019 19:58:25.822","96.552356850679971" "03/30/2019 19:58:35.824","96.859476872593547" "03/30/2019 19:58:45.826","98.107263033370458" "03/30/2019 19:58:55.828","97.327396077620293" ..... "03/30/2019 20:28:15.975","97.483370443431511" "03/30/2019 20:28:25.977","98.107263033370458" "03/30/2019 20:28:35.978","98.112168754568174" "03/30/2019 20:28:45.981"," " "03/30/2019 20:28:55.983"," " Elapsed time was 19:58:25 -> 20:28:45, 32m20s Then, I ran the GUI, after a "sync" command and got: Code:
"(PDH-CSV 4.0) (Romance Standard Time)(-60)","\\NT\Process(mkvmerge)\% Processor Time" "03/30/2019 20:51:55.756"," " "03/30/2019 20:52:05.760","35.717906573357453" "03/30/2019 20:52:15.762","31.818571794606637" "03/30/2019 20:52:25.774","28.514617588198405" ..... "03/30/2019 20:57:25.883","34.470119444157191" "03/30/2019 20:57:35.885","37.121667093707742" "03/30/2019 20:57:45.888"," " Elapsed time was 20:52:05 -> 20:57:45, 5m40s As you can see, both the elapsed time and the CPU usage are way lower from the GUI. |
30th March 2019, 21:33 | #343 | Link | |
1: x264 doesn't optimize global stream headers 2: x264 does optimise global stream headers 3: Users complain about not being able to append encoded video 4: --stitchable added to prevent x264 from optimising global stream headers 5: Fewer users complain about not being able to append encoded video --stitchable became a thing in 2013, so if you created the original silence clip before then, it'd make sense. If not, I don't know......... I've definitely had problems appending encoded video in the past, even when the same x264 build was used and the same settings. Although --stitchable has always prevented the warning when appending constant frame rate encodes. For variable frame rate encodes it's still a little hit and miss. That could be because x264 is writing directly to MKV (for reasons I don't understand) as if MKVToolNix has warned about the codec's private data when appending VFR video in MKVs, extracting the raw streams and appending those instead has always worked. An SSE2 requirement isn't an issue for me, but if x264 could find that missing entry point in kernel32.dl and obsess over bcrypt.dll a little less, I wouldn't complain. That started sometime after build 2091. Cheers. Last edited by hello_hello; 30th March 2019 at 21:35. |
30th March 2019, 22:29 | #344 | Link |
You already asked about fps in the past. It changed headers.
https://forum.doom9.org/showthread.php?p=1822942 |
31st March 2019, 01:26 | #345 | Link | |
SuperVirus
(or at least I think so). I don't have a XP machine anymore, so I cannot test my hypothesis... |
31st March 2019, 03:15 | #346 | Link |
Sorry filler56789,
I missed your earlier post. I can't remember if Windows offered an error message as such, but the first hurdle was x264 not being able to find bcrypt.dll. I downloaded it just to see what'd happen, then the next hurdle was a procedure entry point in kernel32.dll, so I gave up. That's much the same as the latest ffmpeg compiled without XP support (and MKVToolNixGUI after version 10), and while I don't know what win32thread is just yet, I suspect you're on the right track. Cheers. |
31st March 2019, 03:18 | #347 | Link | |
Thanks. |
31st March 2019, 10:12 | #348 | Link | |
External library support: --disable-avs disable avisynth support --disable-swscale disable swscale support --disable-lavf disable libavformat support --disable-ffms disable ffmpegsource support --disable-gpac disable gpac support --disable-lsmash disable lsmash support Apparently, newer x264 -> newer ffmpeg -> no WinXP support. (sorry for offtopic) Last edited by lvqcl; 31st March 2019 at 12:11. |
12th April 2019, 18:02 | #349 | Link | |
MKVToolNix author
MKVToolNix v33 released
Hey,
another month, time for another release of MKVToolNix: v33.0.0. This is still a rather quiet time for MKVToolNix; hence this is another small bug fix release. There've been no changes regarding packaging since the previous release. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Quote:
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
12th April 2019, 20:24 | #350 | Link |
Thanks for the release. Minor cosmetic request for you or anybody else that posts markdown: BB code instead of MD code would be easier to read. It could be converted with a script that reads MD from the clipboard and copies BB back and for convenience the script could be started with a launcher like Alfred or Wox or via command line.
before: https://forum.doom9.org/showpost.php...1&postcount=88 after: https://forum.doom9.org/showpost.php...5&postcount=90 node script: https://pastebin.com/ru5xe4EE |
15th April 2019, 08:53 | #351 | Link |
MKVToolNix author
MKVToolNix v33.1.0 released
Hey,
well, I buggered up the handling of UNC paths on Windows in release 33.0.0. So… sorry? Here's a fix for that. As this is just an emergency hot fix release I'll include the news for v33.0.0, too. There've been no changes regarding packaging since the previous release. Here are the usual links: the MKVToolNix home page, the Windows installer/portable version & macOS DMG & Linux AppImage and the source code. The Windows and macOS binaries as well as the Linux AppImage are available already. The other Linux binaries are still being built and will be available over the course of the next couple of hours. Here are the NEWS since the previous release: Version 33.1.0 "Primrose" 2019-04-15 Bug fixes
Bug fixes
Have fun
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 15th April 2019 at 09:42. |
15th April 2019, 09:32 | #352 | Link |
MKVToolNix author
Well, the script as-is didn't work too well for me, but with a couple of changes (handle more headline tags, revert HTML escaping of " and &, removal of code tags, manually joining lines in order to avoid line breaks) it works well enough, I guess.
15th April 2019, 12:40 | #353 | Link | |
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
23rd April 2019, 04:43 | #354 | Link |
I am trying, unsuccessfully, to standardise order of tracks in output files generated by MKVToolNix so video comes first, then audio, then subtitles.
When I add --track-order 0:0,0:1 (by my understanding video first, then audio) as Default additional command line options in Multiplexer default values preferences, I get an error when muxing '--track-order' may only be given once. I can find only one instance of --track-order in mkvtoolnix-gui.ini, and nowhere else in MKVToolNix preferences to set track order, so I am at a loss to know how to achieve standardisation of track order in output files. Can anyone set me on the right path? |
23rd April 2019, 09:23 | #355 | Link | |
It's not possible to automatically make the GUI set 1. video 2. audio 3. subtitles. The GUI will always insert its own --track-order which cannot be disabled. Last edited by sneaker_ger; 23rd April 2019 at 09:25. |
23rd April 2019, 11:01 | #356 | Link | |
I know track order in output files can be changed around manually. |
25th April 2019, 16:53 | #358 | Link |
Is it possible to cut out a scene from a a videofile (key frame accurate is enough for that), but the two other parts (before and after the cut) should be one file again, without the need of more than one step.
I could cut on two points and then merge the two other parts together, but is there a one step possibility for that? |
matroska |
