Old 5th May 2007, 20:39   #101  |  Link
joseph5
Originally Posted by burfadel View Post
Another example of this is the image view Irfanview, its great but with an old interface it puts new people off using it.
In the latest versions, IrfanView has skin support.
Originally Posted by foxyshadis
Further user interface discussion is fairly pointless until someone decides to do something with the (good) suggestions, though.
It's not pointless, because if someone decides to continue the player's development, (s)he
will read the suggestions, and maybe there will already be an agreement about if there should be skin support. Like I posted before, there should be a poll about it.
joseph5 is offline
Old 5th May 2007, 21:59   #102  |  Link
clsid
Improvements I would like to see:
- better performance of VSFilter (vobsubs often use a lot of cpu power, no problems with srt)
- Winamp style playlist
- better error message for 'save image' function when an unsupported renderer is used
- support for EVR renderer
- more efficient way of reading the options from the .ini file
- better support for DVD, so including deccs
- better support for .asx
- updating the QT and RealMedia APIs (if newer ones exist)
- support for longer filenames of .mov files (current max is 63 chars)
- better support for filenames of .rm files (now certain characters like '#' cause problems), similar problems exist for urls (e.g. '&' char)
- More comprehensive file extension list
- More detailed overview of the DS filters used during playback (filenames, version, etc)
- Option to export this graph information to text (file/clipboard). Would be useful for helping people with problems.
- Automatically exclude VSFilter from the graph when the internal sub renderer is enabled. Prevents n00bs from seeing double subs.
- Fix crash when opening a 0 byte file.
MPC-HC 2.2.1
clsid is offline
Old 5th May 2007, 23:03   #103  |  Link
Casimir666
Hello,
I've just release my own unofficial MPC modify for home theater usage. It include Vista EVR support, D3D fullscreen option to prevent tearing, improved open DVD dialog box, subtitles synchronisation mechanisme and PN31 remote control support.
All explanations on my web site : http://tibrium.neuf.fr/
Enjoy
Casimir666 is offline
Old 5th May 2007, 23:12   #104  |  Link
_xxl
ffdshow user
_xxl's Avatar
Maybe you could add some patches:
VSFilter clipping bugfix,
VSFilter fax/fay parameters,
MPEG2DecFilter Patch (by Haali),
MPEG2DecFilter Patch m2ts (by Haali),
SSF Patch ...
_xxl is offline
Old 6th May 2007, 02:46   #105  |  Link
Kado
Otaku
Kado's Avatar
@Casimir666
After some testing of your MPC version it looks good. EVR renderer tears a lot in XP (maybe crappy renderer, using forceware 158.22/6800GS), EVR renderer displays nothing if RGB colour space is forced (YUY2 and YV12 are ok), osd looks great, the VMR Colour controls are a good add on too.
I don't see me using this player build though, because I use Haali renderer (no osd support), no much use for the other extras, just done a light test on the player, I like drevil's build better because of the patches. Anyway you should add the patches used in drevil's build to enhance the player even more like drevil_xxl said. Good work anyway.
Kado is offline
Old 6th May 2007, 04:51   #106  |  Link
burfadel
Yeah irfanview does have skin support now, I think on of the new skins should be the default! I think with just some new larger, artistic buttons and a change away from the beige would be a good start!
burfadel is offline
Old 6th May 2007, 08:49   #107  |  Link
Casimir666
SSF Patch ...
Where can i find your patches, the "mytempdir" link on the first page of this thread seems to be down
Old 6th May 2007, 11:46   #108  |  Link
clsid
Nice changes!
Here are the patches used by drevil_xxl:
http://www.zshare.net/download/guliv...tches-rar.html
The only one I think is missing is a patch to add VP6 support (which is very useful for playing .flv files). PM him for it.
Could you make available for us the patches for your modifications? Preferably a separate patch for each mod.
MPC-HC 2.2.1
clsid is offline
Old 6th May 2007, 12:15   #109  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Well, his SourceForge project has a (used) SVN repository, so you could just grab a diff between the initial checkin and the current version, but of course separate patches are easier to grok...
np: Radical Face - Welcome Home (Ghost)
now playing: [artist] - [track] ([album])
Leak is offline
Old 6th May 2007, 13:12   #110  |  Link
Casimir666
@clsid
It will be difficult to make patchs files because there is quite much files modified. But almost all my changes are located in main project (mplayerc), and i didn't make any changes in build in filters.
Did anybody knows where i can find AP4 library, i have remove mp4splitter because i was unable to compile it?
Edit : Oups i haven't seems i should unzip lib and apply Gabest patch. It's ok now
Old 7th May 2007, 02:39   #111  |  Link
B.F.
B.F.'s Avatar
About interface.
There is no need for skin support or some ultra cool look interface.
But I think MPC need a bit different look for 2 reasons:
1) Look less MS mplayer2 like.
2) Add some features like double size buttons for high resolutions.
B.F. is offline
Old 7th May 2007, 07:30   #112  |  Link
madshi
This one sounds interesting! Unfortunately your website currently doesn't open for me. Will try again later...
madshi is offline
Old 7th May 2007, 10:36   #113  |  Link
burfadel
Originally Posted by B.F. View Post
About interface.
Yeah thats along the lines of what I mean! Along with the aforementioned name change to just 'MPC Player' which is not contradictory as MPC is just a name and no longer an acronym!, and version numbering change, which could even start with 1!
burfadel is offline
Old 7th May 2007, 15:20   #114  |  Link
vcmfc
mp4 splitter is Update.
bento4: v0.6.3 -> Bento4-0.9.4-002
http://sourceforge.net/projects/bento4/
i update to 0.9.4 is fail.
vcmfc is offline
Old 7th May 2007, 15:33   #115  |  Link
Casimir666
I've just uploaded v1.0.6.0 on SourceForge : include all drevil_xxl patches, activation of VP62 and Mpeg4 splitter internal filters.
About "ffdshow queueing" patches i have done it manually because of my previous modifications : can someone tell me if it's working or not ?
Casimir666
Old 7th May 2007, 15:43   #116  |  Link
_xxl
ffdshow user
_xxl's Avatar
http://www.cccp-project.net/wiki/ind...tle=Guliverkli
Please use them.
This patches could be useful:
mpeg2decfilter_dsutil_interlaced_fix.patch
vsfilter_clipbug-patch-take3.patch
vsfilter_fax_fay-svn611v2.patch
Other Patches:
mpc_ffdshow20061015.patch
mpc_ffdshow20061222.patch
dts.patch
faad2.25.patch
faad2.26.patch
libmad.patch
libpng.patch
I can't update to latest SVN:
"Error: Failed to add directory 'H:\mpc_hc\trunk\src\apps\ShuttlePN31': object of the same name already exists"
_xxl is offline
Old 7th May 2007, 16:11   #117  |  Link
Casimir666
Please use them.
I have include all you patches :
- basemuxer-ssf-removal.patch
- basevideofilter.patch
- dts.patch
- dtsac3patch.patch
- dvobsub.patch
- faad2.25.patch
- faad2.26.patch
- faad2.latest.patch
- libmad.patch
- libpng.patch
- mpc_ffdshow20061015.patch
- mpc_ffdshow20061222.patch
- mpeg2decfilter_dsutil_interlaced_fix.patch
- mpegsplitterfile.patch
- vsfilter_clipbug-patch-take3.patch
- vsfilter_fax_fay-svn611v2.patch
But i haven't tested ffdshow20061015 and ffdshow20061222 (you site didn't explain thoses patches).
Old 7th May 2007, 16:17   #118  |  Link
_xxl
ffdshow user
_xxl's Avatar
http://sourceforge.net/tracker/index...03&atid=565651
_xxl is offline
Old 7th May 2007, 17:28   #119  |  Link
mariner
Hi Casimir666,
Greetings and congratulations to you on the excellent piece of work.
EVR works wonderfully on Xp now, so you can the vista next to it. It would be great to get tearing test workihng with EVR, as reclock does not seem to function with the new renderer.
Once again, well done.
best regards.
mariner is offline
Old 7th May 2007, 19:24   #120  |  Link
Rash
Rash's Avatar
Sorry Casimir, maybe I've missed it. What Sourceforge project?
[EDIT] I've missed it indeed. This project, right?
http://sourceforge.net/project/showf...roup_id=170561
Sorry and thank you
Rash is offline
dxva, h264, home cinema, media player classic, mpc-hc
