1st October 2009, 11:08 | #8261 | Link | |
1 and 2 (General Info). 3 (DD+) 4 (If it includes DTS-MA, not sure about that though) 9 (TrueHD) Which would be almost 400 purchased separately. Time to set up a special fund? Yup. ATI drivers. I forgot to switch back. |
1st October 2009, 21:44 | #8264 | Link | |
Hi guys; i've noticed nobody has selected "HDMI" ; not sure whether you see this option or not?
2nd October 2009, 00:52 | #8268 | Link |
No problem. Anything I can do to aid in this endeavor. I think we're in a holding pattern right now until he gets some more information. Hopefully that happens soon. I'm also hopeful that ArcSoft will work on proper bitstreaming support for the 5xxx cards in TMT3. For me, that'd be my ideal solution. But I would like to see an open bitstreaming solution that any program can use, as well. That'd be sweet.
2nd October 2009, 07:27 | #8270 | Link |
Yeah, I figured that much, but somehow before I installed this beta I had it working by just enabling "all supported" on the video decoder's RAW options, but I tried on another computer and I also had to force it, so maybe I inadvertently had some strange settings enabled on the first PC. No big deal.
2nd October 2009, 11:32 | #8271 | Link |
The same 'trick' is also sometimes needed to make DirectVobSub load in MPC on Windows 7. This is a Windows 7 specific issue. It does not seem to like filters that process raw video.
MPC-HC 2.2.1 |
2nd October 2009, 12:02 | #8272 | Link |
I remember running into similar trouble with DirectVobSub too, but IIRC it was on Vista 32, and the problem was either the splitter or the video renderer. No problems on Win 7 though, on two computers.
ffdshow's RAW processor does connect in GraphStudio, so I was thinking maybe MPC-HC might be at fault, or some obscure option I missed in one of the programs. |
2nd October 2009, 14:54 | #8273 | Link |
Media Control author
I have made a new build based on some reverse engineering. There are some speculations on the implementation, so I am not sure that it will work What have been done :
Link FFDShow HD bitstream beta 8 Expected tests : Common settings For all those tests, check all bitstreams checkboxes in output section of FFDShow audio. Also let the multichannel device drop-down list to "Default device". This feature is unstable and should probably be removed if not improved, except if HDMI devices are hidden and could be accessed with this way Tests
For all those tests, you should verify that the format is correctly detected by FFDShow for 2 reasons : 1/in some cases the splitter could strip off the HD audio data 2/FFDShow implements revert rules : if for example TrueHD is detected but the output renderer won't accept the format, FFDShow will revert to AC3 core To do this check, let your mouse over the FFDShow tray icon twice (the first time nothing is displayed). The second time you should see the bitstream format detected Thank you for your time & help ! Last edited by albain; 2nd October 2009 at 14:56. |
