5th July 2010, 17:44 | #1241 | Link |
Mr. Sandman
assuming the source and the destination files are in the same folders there will be also the stats too.
just add --stats and the drive:\path\filename to the custom commandline options for both presets. that will suffice to replace the megui stats handling.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 5th July 2010 at 17:46. |
6th July 2010, 16:33 | #1243 | Link |
Mr. Sandman
im gradually adding newer x264 options such as the new Open GOP, NAL-HRD, infinite KeyInt etc.
that may break the ACTUAL presets, but if necessary i will publish updated ones together with the new megui version (still dev version)
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th July 2010 at 17:21. |
6th July 2010, 18:15 | #1244 | Link |
Mr. Sandman
Megui dev version 0.3.5.2 BREAKS the x264 PRESETS.
Please BACKUP ALL YOUR x264 PRESETS BEFORE UPDATING.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th July 2010 at 19:07. |
6th July 2010, 22:24 | #1245 | Link | |||
Just another User
System is Xp x64 and MeGUIx64 has its own directory now... BTW I'm wondering why there are no x64 builds of the DLLs?! Am I missing something |
7th July 2010, 00:19 | #1247 | Link |
HD Encod3r
I've updated it without backup and all x264 presets have been lost.....
Now I'am starting tests with new version with new self generated "Unrestricted (DXVA) Very High Profile" for x264. OS: Win 7 32 Bit Ultimate. Everythings look fine... Last edited by doc_dvxm; 7th July 2010 at 00:30. |
7th July 2010, 01:03 | #1248 | Link | |
Mr. Sandman
7th July 2010, 01:04 | #1249 | Link | |
Mr. Sandman
read this post if you need your old presets: http://forum.doom9.org/showthread.ph...79#post1415179
7th July 2010, 10:30 | #1250 | Link |
sorry but imho the change in the profiles was a regression, why break them now? the same problem exists as before, device compatibility isn't maintained when changing the speed --preset and now there's going to be a hundred questions about why i lost my profiles.
7th July 2010, 10:42 | #1251 | Link | |
HD Encod3r
Thanx.. Fixed. |
7th July 2010, 11:18 | #1252 | Link |
Very good work, developpers. I wonder why you wait so long to add the bits*pixels ratio in the bitrate calculator. Anyway you did and you will continue doing an incredible work for people like me who wants to control anything while encoding videos (I used to encode with Gordian Knot few years ago), update feature is amazing (I replace stable url by developpement url in the settings, I like to have newest and fresh tools to encode my videos) many thanks !
9th July 2010, 03:58 | #1254 | Link |
Mr. Sandman
new megui dev build:
0.3.5.3 - (sharktooth) [x264ConfigurationPanel] Trigger GenericUpdate() on macroblockOptions.SelectIndex change to keep coherency between macroblock options checkboxes and commandline generation - (sharktooth) [x264] Added --pic-struct support - (sharktooth) [x264] Added --fake-interlaced support - (zathor) [x264] old nal-hrd profile values will be migrated
9th July 2010, 04:15 | #1255 | Link |
Mr. Sandman
for a stupid copy&paste mistake please re-download the 0.3.5.3 update otherwise the newly added x264 settings wont be saved into your presets...
12th July 2010, 03:02 | #1256 | Link |
I'm probably stupid but update does not work for me. It does the update and restarts but it's still the old version (0.3.1.1058) and it asks me to update again. Also, I got LOTS of silly profile import errors and had to hit LOTS of cancel buttons.
Seems like this should be easy. Just think what Joe Six-Pack will experience if I can't figure it out. Usually I'm pretty good at this computer gig. Last edited by Guest; 12th July 2010 at 03:04. |
12th July 2010, 06:11 | #1257 | Link |
Delete all the MeGUI-core files in your update cache and try again.
there was a check put in place to see if the updates downloaded correctly, if it wasn't the user would be prompted to download it again after MeGUI was restarted
A Man Eating Duck |
12th July 2010, 07:27 | #1258 | Link |
Unreasonable User
Despite the fact that I have "Use CUVID Server" unchecked, MeGUI still uses it whenever I open a .dgi file with the AVS Script Creator. It wouldn't be such a big deal except that in the latest build of DGindexNV, Graft has fixed the memory leak that allows him to deep-six the CUVID server forever, which he has now done. So this behavior of the AVS script creator could become a problem in the future.
Also, MeGUI x64 probably shouldn't have the --open-gop bluray option until an x64 build of x264 r1666 is available, no? |
12th July 2010, 15:14 | #1260 | Link |
Mr. Sandman
@Lyle_JP: i didnt develop the dgindexnv support, so i cant answer right now. i need to check the code. x264 r1666 x64 is in the megui update server... what are you talking about?
@RyaNJ: probably yes.
