28th May 2010, 18:27 | #1081 | Link | |
28th May 2010, 18:33 | #1082 | Link |
Thanks zelenin!
Zathor: can you update this line of code Code:
qualityCodecModifiers.Add(mod.Split('=')[0], float.Parse(mod.Split('=')[1]); Code:
qualityCodecModifiers.Add(mod.Split('=')[0], float.Parse(mod.Split('=')[1], System.Globalization.CultureInfo.InvariantCulture));
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server |
28th May 2010, 23:57 | #1083 | Link | |
I thank you! |
29th May 2010, 21:24 | #1084 | Link |
One Click for bluray movies
Hi:
I've tried to use oneclick for blurays movies. I have a main movie stream .m2ts as input file When using oneclick megui tries to create a d2v file (idx, from 0000.m2ts to 0000.d2v), not a dgi file as when using file indexer, and then stops in error. Am I doing anything wrong? Is there an option to use oneclick fot HD streams? Thanks! Note: I have licensed neuron2 dgindexnv |
30th May 2010, 13:52 | #1085 | Link |
I havent used MeGUI now some time and Upated today.
Now i have one strange thing... I have a .TS File (h264 50 fps + ac3 file) 2 hrs 30 approx... I used Neurons DGIndexNV (2009) to Index it. Now the Big Problem: When i start AVI Script Creator and load that DGI File .... a looooooooooooooooong Time nothing happens. Up to 2-3 Minutes. Then i can do all cropping/resizing things and save the AVS. Then AGAIN i have to wait upto 3 minutes until MeGui becomes aviable again. After loading Audio and pressing "Auto Encode" .... Same thinggy again... 2-3 minutes until i can choose my Bitrates. Guess what? .... Continuing does same...2-3 Minutes until MeGui comes Aviable to start Cue. Starting the Encode i have to wait 5 minutes until even the Status Window pops up... not speaking of again waiting then 5 minutes until it really starts encode. (pass 1).... I guess on Part 2 same thing. Im Not sure if this is a fault of DGToolsNV or MeGui... I remember that i got the same behaviour with an older Version of the DGToolsNV when using DGMultiSource..... So what to do? Chris Last edited by MOS-Marauder; 30th May 2010 at 14:02. |
2nd June 2010, 13:29 | #1086 | Link |
0.3.4.15 - DGIndexNV will use DGMultiSource instead of DGSource as default setting - [JobControl] fixed a crash if an unknown job type is used - [JobControl] old D2V and DGI jobs will be updated - [BitrateCalculator] add 1½ DVD target size and adjust others to safe values. Patch by JarrettV (#2999751) - [BitrateCalculator] fix calculation accuracy by total file size and by BPP to account for constant video overhead. Patch by JarrettV (#2999751) - [BitrateCalculator] simplify audio bitrate inspection to assume bitrate from video duration and audio file size. Patch by JarrettV (#2999751) |
2nd June 2010, 13:31 | #1087 | Link | |
5th June 2010, 06:41 | #1088 | Link |
thank you for your great job, keeping megui alive, zathor!
a long time i didn't open the bitrate calculator, but today i have to say, it's very well thought out logically! if i want to encode multiple streams for a blu ray, i have to use a tiny exel sheet to set the same video bitrate for all streams. but this sheet doesn't calculate very accurate (m2ts overhead is complicated to calculate for me). maybe you could extend megui's bitrate calculator for multiple video streams, if it is possible and less complicated. Last edited by VincAlastor; 5th June 2010 at 06:46. |
6th June 2010, 06:53 | #1089 | Link | |
6th June 2010, 14:09 | #1092 | Link | |
7th June 2010, 03:43 | #1093 | Link | |
Thanks. |
7th June 2010, 03:58 | #1094 | Link |
3GP file?
I got a new HTC EVO on friday. I am trying to put together some HD video files it can play. It has HDMI output for 720p video and a 720p camcorder built in.
Very little is known about the internal capabilities but looking at an output file from the camcorder, it creates files with extension 3GP and mediainfo reports the video codec as mpeg-4 3GPP. Is it possible to create such files with MeGUI? If not, can someone recommend a tool that can? |
7th June 2010, 12:23 | #1096 | Link |
Big Bit Savings Now !
The matching ICSharpCode.SharpZipLib.dll Version 0.85.5.452 seems to be missing from the 0.3.4.15 development.zip.
Trying an older version of this dll results in the same error. Where can I get this dll if I intend to make a virgin setup from the development package ?
7th June 2010, 13:30 | #1097 | Link | |
7th June 2010, 14:40 | #1098 | Link |
--profile and --level should remain a part of basic x264 settings.
and i think evo 4g supports h264 video, level 3.1, ref 3, and profile baseline and aac audio in a mp4 container. edit i'd like to add too that i think the new complexity slider is a waste of space, because asking a novice to judge the complexity of a video is inherently flawed. just saving previous settings or a slider for selecting crf values would be much more worthwhile additions imho. basically i just find it to be more confusing then helpful. running a --crf ? --pass 1 --slow-firstpass...outputting to a file and saving the stats is the better way to judge compressability and dealing with the occasional unwelcome result of a crf encode. edit2 to make it more clear. if target filesize after first pass is greater than or less than specified values, automatically run the 2nd pass adjusting the bitrate and overwriting the previous file. Last edited by quantum5uicid3; 7th June 2010 at 15:34. |
7th June 2010, 15:29 | #1099 | Link |
Many thanks, Zathor !
9th June 2010, 12:53 | #1100 | Link |
Thanks quantum5uicid3! Tried and those setting worked PERFECTLY the first try. WOOT!
Now I cannot wait to get the hdmi cable for this phone. Amazing for a pda/phone. Next question, is there a way to extract tracks from an mp4 in meGUI? eac3to does not handle extraction from mp4 so the hd stream extractor does not work on mp4s. mp4box can do it from a command line, just did not see a way inside meGUI to do it. If its not there, any chance it could be added? Last edited by Rat Killer; 9th June 2010 at 17:54. |
