Old 20th September 2018, 15:09   #52581  |  Link
Klaus1189
Originally Posted by mclingo View Post
Hi, no point really, its immediately apparent with any movie you play when you have the problem, the colours are very saturated especially red.
to recap - to reproduce this with your setup you will need:
TV - setup in BLURAY mode rather than PC
TV - deep colour must be on
PC - desktop must be 4:4:4 FULL RGB 8bit - 2160p
PC - Movie must be SDR and play at 2160p@23hzhz (23,976)
AMD RX card, any driver.
MADVR - TV output set to 10 bit
MADVR - FSE has to be on (I think, i'll test this later)
MADVR - tick use DIRECT3D11
Everything checked, but unsure about deep colour, I have checked "HDMI UHD Color" in TV, is it that feature?
Can not reproduce.
Old 20th September 2018, 15:11   #52582  |  Link
@mclingo
this problem happens with MPDN if i remember correct yes?
first issue i see here. you tell people to use 8 bit output at the GPU but madVR is supposed to output 10 bit.
the issue i see here is that AMD is going to "fix" this and there is nothing madVR can do about it.
the steps i see to isolate this issue are:
GPU at 23p 10 bit RGB madVR at 8 bit
GPU at 23p 10 bit RGB madVR at 10 bit
GPU at 23p 8 bit RGB madVR at 10 bit
GPU at 23p 8 bit RGB madVR at 8 bit
everything points at the GPU driver or display but...
Old 20th September 2018, 15:14   #52583  |  Link
suanm
Originally Posted by SamuriHL View Post
What is your target NIT level set to?
No matter level I set nit to,the images of HDR movies look always very dark.
I do these tests from 599 nits to 1099 nits.The tagert nit value doesn't work
suanm is offline   Reply With Quote
Old 20th September 2018, 15:18   #52584  |  Link
suanm
I have to roll madvr0.92.14 back due to too dark images in madVR 0.92.16
Old 20th September 2018, 15:23   #52585  |  Link
SamuriHL
SamuriHL's Avatar
Stupid question....you're not on the nVidia 4xx driver are you?
Old 20th September 2018, 15:28   #52586  |  Link
suanm
Ah ,nvidia 4xx driver is a must? I don't know really .I'm using nvidia 398.xx driver.So i have to download 4xx driver。Thank you very much
Old 20th September 2018, 15:37   #52587  |  Link
mclingo
double check you PC levels havent changed in MADVR, mine are set to 0-255 and my PC desktop is set to FULL RGB 4:4:4
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions
Old 20th September 2018, 15:44   #52588  |  Link
mrmojo666
same here, but my desktop is 10 bit
mrmojo666 is offline   Reply With Quote
Old 20th September 2018, 15:53   #52589  |  Link
BluesFanUK
I'm sure I read here you can get 10bit in windowed mode on Windows 10... how?
BluesFanUK is offline   Reply With Quote
Old 20th September 2018, 15:59   #52590  |  Link
by setting madVR to 10 bit using d3d11 and only in boarderless windowed.
Old 20th September 2018, 16:00   #52591  |  Link
mclingo
Hi, its worth getting some info about what PC and kit you have onto your SIG mate.
Old 20th September 2018, 16:03   #52592  |  Link
Klaus1189
but not at 3840x2160@50/59/60 Hz if you are using HDMI.
We must wait for HDMI 2.1
1. You need 10 bit display -> see EDID in madVR options in properties of device.
2. If your display supports 10 bit, madVR should with default setting "auto" 10 bit windowed. It does it also here, so it is working fine.
Old 20th September 2018, 16:07   #52593  |  Link
the display edid or bit deep has nothing todo if you are able to use 10 bit windowed.
in the end madVR is not sending the image to your display it is sending to the GPU driver.
Old 20th September 2018, 16:13   #52594  |  Link
brazen1
Originally Posted by brazen1 View Post
I've been using madVR v0.92.14 with no problems. I just installed the new madVR v0.92.15 released today carrying over settings from v0.92.14. MPC-HC starts with a black screen and no OSD. I assume it is paused which it is and I press play even though there is no OSD. My display flashes into HDR mode. Audio begins and the picture is frozen on a single frame. If I navigate forward or reverse, the movie begins to play normally. So I start with MPC-BE instead and none of this funny business occurs. It just starts and plays like it should. Both MPC players use identical settings. I'm using the latest current nightly builds of each. Both players performed as expected before upgrading to v.0.92.15 fwiw.
I have upgraded to v.0.92.16. The above ^ still occurs and there is no change. This behavior occurs on all formats and containers (HDR, SDR, ISO, MKV, etc).
I have always used LAV D3D11/auto. If I switch to DXVA 2 copy back/GTX 960, at least the MPC-HC OSD is present but without fail, it starts paused.
To be clear, this is not a complaint and just presenting a bug. Very appreciative madshi continues development and all of us hamsters would be lost without madVR and madshi's continued dedication. Thank you.
W11 Pro 24H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI 22 MPC-HC/BE 82" Q90R Denon S720W
Old 20th September 2018, 16:38   #52595  |  Link
SamuriHL
SamuriHL's Avatar
No no no! LOL Don't do that. Sorry I got pulled away and didn't get a chance to respond til now. I wanted to make sure you're NOT on 4xx!!!!
Old 20th September 2018, 16:46   #52596  |  Link
Klaus1189
What splitter and decoder do you use?
Try external LAV Filters latest nightly, prefer all 4 filters.
Old 20th September 2018, 16:58   #52597  |  Link
suanm
It seems not to work yet even if i set tv-level(16-235).
I've uninstalled madVR 0.92.16 version.Reinstalled old madVR0.92.14 version.All is normal as usual.
Thank you very much.
Old 20th September 2018, 16:59   #52598  |  Link
brazen1
As stated, I am and always have used LAV Filters and yes of course, they are all set to preferred. They are updated and replaced into the MPC-HC LAV Filter x64 install folder as well. Fwiw, I have always used 5 players for testing and usage over the years and have a fair idea of the basics for all of them. Everything I use is the latest release preferring its nightly except nVidia GPU drivers which continue to be flawed since v.385.28.
Old 20th September 2018, 17:01   #52599  |  Link
mrmojo666
sometimes you guys makes me crazy , it's pretty obvious that my desktop is 10 bit @23,9.... to watch hdr movie......
my tv accepts 8/10/12 bit signals by edid.... c'mon guys......
Old 20th September 2018, 17:06   #52600  |  Link
Klaus1189
I don't know anything else that I can do, let me know if you know something.
