7th May 2007, 12:40 | #721 | Link |
Arf the window width resizing bug is still there, but the sliders section automatically hides again when I don't use any
btw a funny thing is when I close avsp, both windows disappear (also from the task bar), and for some reason the preview window flashs back (in the task bar as well) and disappear again. Not a big issue, just thought to mention Last edited by Alain2; 7th May 2007 at 12:44. |
9th May 2007, 08:04 | #724 | Link | |
Thanks for the updated translation, I've updated the links accordingly. Just as a reminder to those using translation files, there's a bug in v1.3.9 that requires you to add the translation.py file in the library.zip file (in the lib directory, just drag and drop). This too will be fixed in the next version, sorry about the inconvenience. Huh? If you mean can AvsP work with wmv files, a simple script like DirectShowSource("test.wmv") should do the trick. You can read the overview if you want to find out about what AvsP is and what it isn't. Last edited by qwerpoi; 9th May 2007 at 08:13. |
11th May 2007, 20:41 | #726 | Link |
Feature request: when using a separate video window, fully separate its behaviour from the script window. At the moment:
- minimising the script window minimises the video window as well - if script window is minimised and video window maximised, making the script window appear again change the video window to a flotting one (not maximised) and refreshes it |
11th May 2007, 23:03 | #727 | Link | ||
Incidentally, I won't be in town for the next week or so, my internet access there will be limited, so I may not be able to reply during that time. But I wanted to give you guys something to look forward to, so check out this screenshot of the next version of AvsP. There's a lot of details that still need ironing out, but what you're looking at is user sliders that have been automatically generated without any manual input. That means you just write a script, show the video, and you'll automatically get user sliders for every specified argument in the script. Not just user sliders, but string list selectors, boolean radio boxes, and filename pickers. Without any manual input. And if you're worried that there will be too many user sliders, you can hide user sliders for any filter by clicking the filter name, and there will be ways to customize which user sliders to automatically create. This version will hopefully be released within the month, it's going to be smoking... Last edited by qwerpoi; 11th May 2007 at 23:17. |
12th May 2007, 23:47 | #730 | Link |
Wow, that looks awesome!
Feature request though: Could we get some hotkeys for the DeleteFrame() and DuplicateFrame() functions? Sometimes there will be frames in the video that are just screwed up for some reason, and those functions are useful for cleaning up areas like that. Also, would it be possible to give the interface higher priority than the video display? The reasoning being, you might make a mistake and do something which will take avisynth a LONG time to process a frame. In this situation it would be nice to be able to turn off the video display so you could fix your mistake immediately instead of having to wait on the frame to render. Last edited by Zarxrax; 13th May 2007 at 00:17. |
14th May 2007, 02:02 | #731 | Link | ||
frame = avsp.GetFrameNumber() avsp.InsertText('\nDeleteFrame(%i)' % frame) avsp.ShowVideoFrame(forceRefresh=True) Quote:
15th May 2007, 09:42 | #732 | Link |
@qwerpoi
CT software collection 11.05.2007 with AvsP http://www.heise.de/ct/ (German) Software-Kollektion 3/07, c't 11/07 http://www.heise.de/software/default.shtml?s=cdd&id=51
Henrikx |
19th May 2007, 13:40 | #734 | Link |
plebian
I'm not sure if this has been asked but here goes:
If I decided to use the "slider" feature, would AvsP automatically remove the extra text I typed? for example: deen("w3d", 3, 3, [<"ti", 0, 10, 5>]) would become deen("w3d", 3, 3, 5). Thanks for the replies. |
19th May 2007, 14:14 | #735 | Link |
@qwerpoi
Could you consider in a future release an additional category, "external function", in dialog "Options"|"Avisynth function definition...", "Function type" field ? Although not that important, it would help to better classify the functions of my library. Thanks anyway for this great app; I have at last found my Avisynth editor of choice .
AVSLib, a free extension library for Avisynth. Current version: 1.1.0 (beta), 14/05/2007. [ Home page | Download page ] |
19th May 2007, 15:23 | #737 | Link | |
Sounds like a donation button is in order! Thank you for all your hard work. Last edited by BruceL; 19th May 2007 at 15:30. |
26th May 2007, 02:33 | #740 | Link |
I don't know if anyone else encounters this problem, but most of the time if I try to use the save avi feature it wont work. Sometimes it works, but usually it doesn't. There is no error or anything... it simply doesn't encode anything.
If avsp had some better encoding options, this thing could take over vdub for almost all of my video processing tasks |
