Old 11th March 2010, 14:13   #1321  |  Link
XadoX
XadoX's Avatar
Thx for your ongoing work & the Update
XadoX is offline   Reply With Quote
Old 12th March 2010, 16:13   #1322  |  Link
gwaitsi
i have an ati 3200HD onboard graphics controller.
I am trying to convert a bluray vc1 movie using megui.
when i try to use directshow filter as the input, megui queue item crashes.
Am i right in assuming DGIndexNV will not work in my system.
thanks
gwaitsi is offline   Reply With Quote
Old 12th March 2010, 16:39   #1323  |  Link
rack04
Your assumption is correct.
rack04 is offline   Reply With Quote
Old 12th March 2010, 18:07   #1324  |  Link
Have you tried Zathor's latest patched MEGUI build?
DGDecNV will not run on ATI cards.
Old 17th March 2010, 06:10   #1325  |  Link
VincAlastor
there is a DgDecode 1.5.8 x64 version. would you support JoshyD with an dg nv tools x64 version, please?
VincAlastor is offline   Reply With Quote
Old 17th March 2010, 06:45   #1326  |  Link
If you buy me a 64-bit OS I will consider it.
Old 17th March 2010, 09:00   #1327  |  Link
VincAlastor
what did you do with my donation?!?! ...it was just a question, sorry
Old 17th March 2010, 14:13   #1328  |  Link
More seriously, I have never made a 64 bit anything in my life. If you can make it easy for me by telling me what I have to do, then it could happen. Please use PM for that.
Old 17th March 2010, 14:21   #1329  |  Link
stanjr
Linux Encoder
It's a Windows application!
Yeah, well there is Wine and Crossover and Cedega to get Windows things to run on Linux. I was just wondering if any of those worked, that's all. I guess I'll go to Wine and whine...
stanjr is offline   Reply With Quote
Old 18th March 2010, 16:36   #1330  |  Link
turbojet
Concerning an x64 OS, I don't know if this helps but microsoft offers windows 7 90 day enterprise edition. It won't be good as a primary os/upgrade but you could dual boot without affecting your current OS by making another partition and restore the space an app like easeus partition manager.
Old 18th March 2010, 17:16   #1331  |  Link
hajj_3
ah yeah i forgot about the 90day trials of windows 7. If there was a 64bit dgNV then we'd have 64bit x264, avisynth, dgnv and deinterlacers. I reckon we'd have quite a speed improvement using all these instead of 32bit versions of each.
So much 64bit development over the past 2 months, alot of hard work by everyone
Old 18th March 2010, 18:26   #1332  |  Link
swinokur
Hi there,
I've found a MPEG-2 Program stream which DGIndexNV cannot decode. (I see a green video window with a few randomly colored macroblocks in it).
I had a copy of DGIndex 1.5.2 here, so I tried that. It shows video in the window properly.
The video is MPEG2 Program, profile esc (0@5), 720 x 512 px, 4:3 [2], 29.97fps, NTSC, Interlaced, BT.470-2 B,G, Frame, Top Field.
Let me know if you'd like me to send it to you.
swinokur is offline   Reply With Quote
Old 18th March 2010, 19:06   #1333  |  Link
Yes, I would like that.
Old 18th March 2010, 19:46   #1334  |  Link
swinokur
Sure thing:
cpr-CPR_SignLanguage_01-orig.mpg - 78.36MB
Old 19th March 2010, 06:37   #1335  |  Link
XadoX
XadoX's Avatar
Bug:
Better interaction of DGMultiSource() with AvspMod:
Refering to my post in the AvsPmod thread.
Old 19th March 2010, 13:56   #1336  |  Link
@XadoX
Your cited post does not mention any "bug" in DGDecNV.
Old 19th March 2010, 14:00   #1337  |  Link
XadoX
XadoX's Avatar
You are right. But I am not sure on which side the error belongs.
...If I am using DGMultiSource ... AvsPmod often crashes...
On AvspMod or the DGMultiDecodeNV.dll side?
Edit:
Somehow I always have the feeling that you are angry/huffy about my posts?
Old 19th March 2010, 14:06   #1338  |  Link
osgZach
I don't think it's personal, he's just a very blunt person and gets to the point.
osgZach is offline   Reply With Quote
Old 19th March 2010, 14:56   #1339  |  Link
If AvsPmod is crashing you need to speak to its author.
Edit:
Struck for rule 3.
Old 20th March 2010, 11:59   #1340  |  Link
Rat Killer
Just aquired a licence for DGIndexNV and trying to get it working. Attepting to load an mpeg2 ts file directly in DGIndexNV results in the following error:
GPU decoder: Failed to create video decoder (100)
My GPU is NVIDIA Quadro NVS 160M and I am running Windows XP with the latest service packs and updates.
Video Driver version reports as 4.00.6163.1000
Any suggestions or other information needed to get me going?
Thanks
Rat Killer is offline   Reply With Quote
