24th May 2009, 22:01 | #2961 | Link |
Sorry if this questions been ask before i tried searching the thread and didn't come up with anything.
So im doing a multiAVCHD with anime files and the subtitles are getting cut off from the beginning to end if the line is to long. For instance if the first word was "What" i would only see like "hat" and it would end on the other side of the screen with a word cut half way off also. How do i fix this? i tried changing the font size smaller and it help a bit but there's some lines that are just to long. I have an sony z4100 screen option wide mode is on Full and display area is on Normal because it doesn't give me the option of full pixel while in vide |
24th May 2009, 22:07 | #2962 | Link |
Programmer (or just 教务长)
No matter how big your screen is - they will go off the sides.
Load your subtitles in Subtitle Workshop or any other subtitle-editor-application and make sure you don't have lines over 40 characters. In Subtitle Workshop you can simply do the line-split by: 1) Load .srt file 2) Select all subtitles (Ctrl-A) 3) Split long line (Ctrl-E) 4) Save (Ctrl-S) Dean |
24th May 2009, 22:08 | #2963 | Link |
@deank
grey alternative is ready. New graphics: background.png, bottom_lines.bmp, chapters.bmp, shadow.bmp, shadow_transparency.bmp http://www.mediafire.com/file/bvzdgb...vcmenu-grey.7z
24th May 2009, 22:12 | #2965 | Link | |
I forgot to compress bottom_lines.bmp to bottom_lines.png. You will save more than 830 KB without quality loss.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th May 2009 at 22:16. |
24th May 2009, 22:55 | #2966 | Link |
Hi Deank,
Me again. Have you solved the problem with Roman about TXMuxer? I re-post my problem: after having cut commercials (with different programs), I have a perfect .ts file. But, when passed through MultiAVCHD (or simply through TXMuxer) to build a BR disc, I have sound and image de-sync. Whatever I do! It's really annoying! |
25th May 2009, 01:50 | #2968 | Link |
Hi Deank,
Whatever I did, the subtitle is still not show up after down load the newest version. Can you show and tell me know how? Here is the log below [18:06:57] Log started for multiAVCHD v2.7 (build 611) [18:06:57] Current output mode will include [18:06:57] maximum of 252 titles. [18:06:57] Processing 1 input file/folder. [18:06:57] Temp folder does not exist. Set to C:\_TEMP. [18:06:57] Strict AVCHD folder mode is enabled... [18:06:57] Processing (C:\Temp\E13.mkv)... [18:06:58] Detected frame reference count: 5 (max:9). [18:06:58] Detected video: ID#1:V_MPEG4/ISO/AVC 1280x720, fps=29.970, ref=5 [18:06:58] Detected audio: ID#2:A_AC3 (48000Hz 2ch) Language: und [18:06:58] Added audio: A_AC3, "C:\Temp\E13.mkv", track=2, lang=und [18:06:58] Adding subtitles (E13.srt) (und) [18:06:59] Inserting auto chapters... [18:06:59] Creating clip and playlist info (tsMuxeR)... [18:08:59] Processing playlist files... [18:08:59] Title added: "E13" [18:09:01] Will use chapter marks: 00:00:00;00:04:55;00:09:50;00:14:46;00:19:41;00:24:36;00:29:32;00:34:27;00:39:23;00:44:18;00:49:13;00:54:09; [18:09:01] Preparing authoring information... [18:09:01] Top menu skipped. Playback will start from Title#1. [18:09:01] Authoring welcome screen (NTSC). [18:09:22] Authoring custom welcome screen completed. [18:09:22] Setting menu for 1 titles... [18:09:22] STOP command after title #1 inserted. [18:09:22] Forced sequential playback from Title#1 forward. [18:09:22] Completed. [18:09:22] Done! [18:09:23] C:\multiAVCHD\AVCHD folder created! [18:09:23] Burn its CONTENTS to DVD-R/RW UDF 2.50/2.60 disc! [18:09:23] Launching ImgBurn... |
25th May 2009, 07:55 | #2969 | Link | |
2) Check the offset in Muxer tab. |
25th May 2009, 09:55 | #2970 | Link |
Hello,
I've just tested the "slide menu" compilation and it's a good option for create a AVCHD with only one title (but with acces to chapters). Just a remark and a request : Can you provided in next build the option "no reflections...." for the title thumbnail like as the option avialable for carroussel menu. With custom background the reflection is not always a good rendering. Thank. |
25th May 2009, 10:29 | #2971 | Link |
After few test with Slide menu and Caroussel menu, I''ve detected a little bug with navigation buttons display on the chapter thumbnails.
Some time if a go to : Title thumbnails to 1st chapter = display of button for chapter thumbnails are correct. But if if return to the title thumbnails and another time go to 1st chapter thumbnail = 2 arrows button ar displayed in same time (tested on PDVD software, I don't know yet if the same result on satndalone player). I hope this explaination is clear, if not just make a test with alternate navigation between title and chapters for see what I mean. And at end, a suggestion for ergonomic navigation between title and chapter thiumbnails in Slide and Carrousel menus : For the fist and the last chapters thumbnails the UP nagivation action go to title but not for the chapters inserted on this 2 elements, if you can modify to have the same reaction for all chapters thumbnails with the UP (or Down) action = GO to the title thumbnail. |
25th May 2009, 19:55 | #2975 | Link |
Following the many new builds of multiAVCHD you cannot be a human beeing, you must be one of the old greek or roman gods, reborn from Jupiter's crew!
But wait! I will upload some suggestions in a RAR to RapidShare with some screenshots, questions, suggestions and specs for: 1. a Table-of-Content-like Chapter Menu 2. Aspect Ratio / Overscan issue playing 720 x 480 NTSC anamorphic in AVCHD mode Please, take your time to have a look at it and then decide, if you can do all or part of it on the fly. multiAVCHD is becoming the DVD-lab for AVCHD! Will send you a PM when upload will be finished. Cela P.S. Upload (12863 KB) finished. Last edited by Cela; 25th May 2009 at 21:12. |
25th May 2009, 20:15 | #2976 | Link |
Life's clearer in 4K UHD
26th May 2009, 09:30 | #2978 | Link |
Hi, I have a problem.
The last version isn't able to create a disc compatible with PS3, while it works perfectly with powerdvd. I try to create a BR or a AVCHD but PS3 recognise it as "Data disc". I notice that multiavchd create always the folder "HDAVCTN". I try to delete it but the PS3 continues to recognised it as a "Data disc" Please help me. Thanks. |
26th May 2009, 09:38 | #2979 | Link |
Make sure you:
1) Load your files 2) Click start 3) Select "AVCHD for optical media" 4) multiAVCHD will create AVCHD folder 4) Burn its contents (BDMV folder) to a DVD-RW disc. *** You got me worried, so I just burned a compilation to a DVD-RW disc and (of course) it works perfectly as expected in my PS3. Last edited by deank; 26th May 2009 at 09:56. |
26th May 2009, 11:48 | #2980 | Link | |
The basic operation flow is now completely changed, allowing the user to control all before clicking the START button. Title Properties is mainly affected by the changes, because one can control everything about a title in this prop-box. Here is a preview of some of the changes and options in Title properties: You can see there are a lot of controls and settings for each title, before you start the compilation. Projects can be saved and loaded + many other changes. Dean Last edited by deank; 26th May 2009 at 12:04. |
