9th February 2007, 02:14 | #441 | Link |
Angel of Night
Only if your hardware is 10 years old and improperly cooled, or your power supply is about to die.
Computers are designed to be able to run at full utilization for a full year straight if necessary, pushing it hard for 12 hours can't hurt it, and can't even crash it if it's properly cooled. |
11th February 2007, 07:41 | #442 | Link |
@tsp
Is the source code for your version of avisynth available? or just diffs from the cvs code? I got a chance to test Merlin7777's script using debug builds of Decomb, Colormatrix, and AddGrainC, along with your 2.5.7.3 avisynth.dll and 4 out of 5 times the script stopped on an access violation several calls deep in avisynth.dll. 1 time it stopped in Decimate::FindDupicate() because the data pointer of one of the pvideoframe object's videoframe pointer's vfb pointer was null causing an access violation when decimate tried to use the pointer it was returned by ->GetReadPtr(). |
11th February 2007, 11:21 | #443 | Link |
tritical: the sourcecode is available here. It includes a vs 2003 solution.
I also encountered the bug with decimate calling env->bltbit with a null pointer as the dst pointer.
Get my avisynth filters @ http://www.avisynth.org/tsp/ |
11th February 2007, 17:25 | #444 | Link |
Tsp, is there a way to TOTALLY shut off SetMTMode in parts of script? I was testing this following basic script using Tritical's TWriteAvi and i keep getting a file exists error which appears to coming from 2 threads of TWriteAvi each trying to create/open/write to "C:\test.avi" (work fine when i do not use MT)
Very basic failing example: SetMTMode(5) mpeg2source("D:\AutoEncode\part1\part1.d2v",cpu=0) #source input is 1080i SetMTMode(2) Lanczos4Resize(624,352) SetMTMode(5) TWriteAvi(fname="C:\test.avi",overwrite=true,showAll=true) tsp i thought you once said there was a SetMTMode(0) for that but i can't find the thread. (Maybe i dreamt it haha) Thanks |
11th February 2007, 22:10 | #445 | Link | |
No SetMTMode(0)
http://forum.doom9.org/showthread.php?t=94996&page=15 http://forum.doom9.org/showthread.ph...583#post812583 |
11th February 2007, 23:31 | #446 | Link |
Zep: mode=0 is set when setmtmode is not used. It can not be set. Mode 5 should only create one instance if the filter(TWriteAvi).
If you only wants to use multithreading to resize the video use mt() instead: Code:
mpeg2source("D:\AutoEncode\part1\part1.d2v",cpu=0) mt("Lanczos4Resize(624,last.height())",splitvertical=false) mt("Lanczos4Resize(last.width(),352)",splitvertical=true) TWriteAvi(fname="C:\test.avi",overwrite=true,showAll=true)
12th February 2007, 04:43 | #447 | Link |
Thanks for the source. I haven't been able to figure anything out except that (on this comp at least) it is definitely a problem with filters having pvideoframes with references to vfbs with null data pointers and datasize=0... which seems to indicate that those vfbs had their destructor code run by i->~LinkedVideoFrameBuffer() in ScriptEnvironment::GetFrameBuffer2().
12th February 2007, 11:59 | #448 | Link |
tritical: It suggest that the refcounting somewhere is messed up. If the refcount only temporarily goes down to 0 in a filter and increase to 1 before the filter return it would only appears as an error when running with more than 1 thread.
13th February 2007, 02:53 | #449 | Link |
dumber every day
I have been using 0.5 with good success. I upgraded the avisynth and mt dll's to the new 0.6 version and began to experience some problems.
Using just a simple script of setting mt mode=2 and opening an avi file (vhs capture, about 1hr long) with no processing. I then opened that in virtualdub and the playback has cracking in the audio and some single frames are fully pixelated with random colored blocks. I backed out to 0.5 and opened the same script with no issues. Anyone else experience problems? |
13th February 2007, 08:14 | #450 | Link |
When I was testing I did stick an _ASSERTE(vfb->refcount>0) inside VideoFrame::AddRef(), and also changed
if (InterlockedCompareExchange((long*)&i->refcount,1,0)==0) to if (InterlockedCompareExchange((long*)&i->refcount,0,0)==0) in GetBuffer2() so that the refcount would stay 0 on those. The assert triggered once, but I wasn't able to figure out the sequence of events that lead to it happening. The call stack pointed back through PVideoFrame::Init() and PVideoFrame::PVideoFrame(VideoFrame* x) to this line in cacheMT.cpp: PVideoFrame retval=BuildVideoFrame(i, n); // Success! Unfortunately, I don't have access to that comp right now so can't do anymore testing until my comp is free. |
13th February 2007, 09:32 | #452 | Link | |
ok will do. I sorta thought i would have to use MT() but sometimes my triple and quad quoting doesn't work haha and why i like to stick to set SetMTMode() whenever i can will give it a go thx |
14th February 2007, 14:51 | #453 | Link | |
I ran into a few problems though. Most of the following comes from me wanting to only MT certain functions and not MT the whole script with SetMTmode() since some of the filters i use are slower with setMTmode(5) or (6) than no MT at all and if i try to go 2 they crash and if 3 or 4 are really slow. Anyway... 1) I get an access violation error every time i try to do mt("Decimate(cycle=5,quality=0)") Any idea if the bug is in MT or Decimate? I wonder because SetMTMode(2) Decimate(cycle=5,quality=0) seems to works fine 2) for the life of me i can't figure out the syntax for mt("mpeg2source("D:\whatever.d2v",cpu=0)") I have tried triple quotes with no luck mt(""" mpeg2source("D:\whatever.d2v",cpu=0) """) any ideas on getting that to work? 3) 2.6 alpha with built in setMTmode() is faster for me by a rather large amount (about 25%) than the 2.5.7 MT 0.6 package. Any idea as to why that could be? 4) when using setMTmode() is there a way to set splitvertical to either true or false? Does it internally always use false? 5) Some filters work with setMTmode() but not with MT() or vise versa. Are there some basic differences we should know about between the two methods? 6) using as example Lanczos4Resize() with MT() is MUCH faster then using it in setMTmode() run. Not only that but CPU usage goes through the roof as well without any speed gain over the MT() way even when i do something like this SetMTMode(2) Lanczos4Resize(960,last.height()) Lanczos4Resize(last.width(),528) oh i think i will stop for now Thanks for such a wonderful tool! |
14th February 2007, 17:33 | #454 | Link | |
Pig on the wing
In SetMTMode a thread requests the whole frame so no need to split in vertical or horizontal direction. MT requests one frame and splits it in two halves.
14th February 2007, 17:48 | #455 | Link |
Angel of Night
2) Since mt() splits the input in pieces, that can't work, it's not smart enough to figure out when a source shows up; if it did, it'd probably give you two copies of the source stacked. All the multithreading comes from being able to split the input.
5) The basic difference is that mt() splits and sends both pieces of the frame to two copies of each filter, while setmtmode() says "give me 3, oh and run 4 while you're at it" on the assumption that the next frame is probably going to be needed, without splitting anything. I have no idea how smart the frame decision part is though. Some mt modes will try to use the same copy of the filter, some will create new ones. (That should explain why #4 isn't needed.) The rest of the answers are buried in the code somewhere, I only know the basics. ;_; |
14th February 2007, 22:16 | #456 | Link | |||||
oh i think i will stop for now Thanks for such a wonderful tool![/QUOTE] Quote:
16th February 2007, 03:57 | #457 | Link | ||
16th February 2007, 04:02 | #458 | Link | ||
ahhh and now i see why resize works fine in setmtmode without having to worry about changing both width and height at the same time unlike MT() |
16th February 2007, 04:15 | #459 | Link | |||
than all other version i have tried by a good amount. Quote:
example being setmtmode(3) mpeg2source* mt("Lanczos4Resize(960,last.height())",splitvertical=false) mt("Lanczos4Resize(last.width(),528)",splitvertical=true) note mode 3 is faster than mode 2 for mpeg2source which i find interesting. mode 2 puts that filter into a roller coaster ride but mode 3 speeds it up some and keeps it at a steady rate on my box anyway thx! |
16th February 2007, 04:34 | #460 | Link | |
Actually in reserve
Could you give a link to the Wilbert 2.6 alpha cause I can see only the 2.6 pre-alpha like here http://forum.doom9.org/showthread.ph...298#post862298 or here http://forum.doom9.org/showthread.ph...359#post841359 Thanks Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
