Old 10th February 2014, 16:17   #1  |  Link
Nozdrum
Extracting frames from mp4 clip using ffmpeg
Hi, I'm using ffmpeg to extract all frames contained in a 10 seconds mp4 file (avc/no audio), this is the syntax of the bat file (name: "extract-frames.bat"):
pause
But only the first frame is extracted correctly, then it returns this error:
[image2 @ 022fcce0] Could not open file : outputC:\Jan2014\01\extract-frames.bat5d.png
av_interleaved_write_frame(): Input/output error
I think the batch syntax "%0" causes the conflict within the output file name, do you know an alternative to this syntax that could work correctly for ffmpeg?
I was following this example:
http://www.alecjacobson.com/weblog/?p=2102
Nozdrum is offline   Reply With Quote
Old 10th February 2014, 16:33   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Found this with a quick Google search:
FFMPEG - Making an Image Sequence from a video
ffmpeg -i "input.mov" -an -f image2 "output_%05d.jpg"
Old 10th February 2014, 17:28   #3  |  Link
Nozdrum
The problem is that %0 in batch always causes the same issue, even with that command line:
[image2 @ 024ad520] Could not open file : output_C:\Jan2014\01\extract-frames.bat5d.jpg
Maybe I need to get an updated ffmpeg.exe, I'll try again with a different version.
Edit: tried with latest build from here but the problem is the same, probably %0 shouldn't be used.
Old 10th February 2014, 17:58   #4  |  Link
Nozdrum
Thanks it works, I just needed to escape the "%" symbol, it should be:
ffmpeg -i "input.mov" -an -f image2 "output_%%05d.jpg"
Old 10th February 2014, 18:19   #5  |  Link
poisondeathray
Does anyone know how to get ffmpeg to start numbering at frame "zero" instead of frame "one" for exporting image sequences ?
Old 10th February 2014, 18:28   #6  |  Link
nevcairiel
Try adding a "-start_number 0" parameter.
Old 10th February 2014, 18:32   #7  |  Link
poisondeathray
It works, thanks!
Old 13th February 2014, 09:26   #8  |  Link
Selur
Selur's Avatar
Nice, didn't know that there is a '-start_number' parameter
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
batch, extract, ffmpeg, frames, mp4
