Old 23rd September 2011, 12:22   #1  |  Link
Dogway
[FFmpeg] image conversions - batch file
My intention is to make a handy batch file for encoding images. Mainly I will be converting from jpeg to png, so I run a few tests. What I found out is that first, jpeg decoding is wrong, I think because it relies on mjpeg for decoding which is chroma subsampled. And second: the target png weights much more than say, saving from avspmod or photoshop.
I would like to know how to do this on ffmpeg or maybe some kind of avs2png, ultimately I want to right click on an image and run the batch file.
Old 23rd September 2011, 16:52   #2  |  Link
smok3
brontosaurusrex
smok3's Avatar
avisynth to png sequence or jpeg to png?
what exactly are you trying to do?
certain other member
smok3 is offline   Reply With Quote
Old 23rd September 2011, 17:38   #3  |  Link
Dogway
I dont care as long as I can convert a jpg to png, through avisynth or directly fed. I just thought that variable input would be more difficult through avisynth...
Old 23rd September 2011, 18:07   #4  |  Link
smok3
brontosaurusrex
smok3's Avatar
a bit of overkill, but how about
http://www.imagemagick.org/script/co...processing.php
convert file.jpg file.png (is the basic syntax)
(imagemagick runs on mac, win, linux, so anything learned on desktops can be than easily used on for example linux servers)
p.s. my quick test shows that default png compression is better than the one found in gimp, unless there is some sort of chroma bug...
p.s.2. png compression is slow and demanding on full HD pictures
Old 23rd September 2011, 18:10   #5  |  Link
Dogway
I didn't know imagemagick had a command line tool. I will try that, in expect I dont need to install anything.
Old 23rd September 2011, 18:14   #6  |  Link
smok3
brontosaurusrex
smok3's Avatar
you will certainly need to install imagemagick.
Old 23rd September 2011, 18:16   #7  |  Link
Dogway
I used the portable version and it works, compression to png is alongside PS, avspmod, etc. But yes, its overkill, I hoped to make it work on ffmpeg...
pd: maybe the encoder avspmod internally uses for conversion
Old 25th September 2011, 14:36   #8  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
@echo off
c:\path\to\ffmpeg -i "%~1" -vcodec png "%~dpn1.png"
save this bat into "Send To" folder.
my repositories
Chikuzen is offline   Reply With Quote
Old 25th September 2011, 18:31   #9  |  Link
Dogway
Thanks chikuzen, that was my first option, but jpeg decoding seems wrong, and png compression is... unusual. Maybe there is some option in ffmpeg we are missing.
batch, ffmpeg, jpeg, png
