21st October 2009, 23:12 | #8801 | Link | |
Didée Fan
I found a trojan in it though: Trojan/Win32.Banbra.gen This kind of trojan steals banking info for people in Brazil. Maybe your pc is infected for this trojan to have been in the ffdshow you made for me? So I will not use or tell other people to use this build you kindly made for me for fear it does have a trojan and this is not a false positive. May I ask clsid to please make me a patch generic build as requested ( link ) as I have good experience with his ffdshow builds.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 21st October 2009 at 23:25. |
21st October 2009, 23:34 | #8802 | Link |
Don't be silly It's a known issue with useless AV programs like AVG. Update to the latest signatures, they are supposed to have fixed it. Every Inno Setup installer was detected as a trojan. And as a note, use virustotal.com to check if your AV detects something wrongly or not.
But anyway, too much time spent with you. Maybe I'll infect you too. EDIT: link removed since you asked for that specific build and you downloaded it. Last edited by XhmikosR; 21st October 2009 at 23:42. |
21st October 2009, 23:51 | #8803 | Link | |
Didée Fan
So either both have trojans or neither do. I'm sorry for offending you. It must be a false positive like you said.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. |
22nd October 2009, 00:11 | #8804 | Link |
Do you have ANY idea how many false positives AVG produces? It's ridiculous. They must get 100 reports a day about that. It would drive me insane to use something that flags so much stuff as a virus/trojan/whatever. Some people would argue that being overly cautious makes you safer, but, I'd argue against that concept because really, if you can't trust the AV to get it right, then, um, it's not very useful IMO. "Oh, must be another false positive." BAM.
22nd October 2009, 00:25 | #8805 | Link | |
Didée Fan
Maybe you can make a new ffdshow.ax with the patch, same build as the one you made for me today and I will see if that works better than the exe. I'm testing the patched build with mvtools2 motion interpolation, scene skipping in mpc.
22nd October 2009, 00:42 | #8806 | Link |
No, the process is simple. Patch applied and then rebuilt ffdshow. Setup has the same ffdshow.ax so what you suggest does not make any sense. Nothing more I can do. So ask SEt, or wait until someone takes a look at that patch.
22nd October 2009, 11:11 | #8810 | Link | |
As usual you can find the link in my signature. If someone could make some more benchmarks, that would be nice, since in my case the performance improvement is small, but not that bad. (see a few pages before) Also I wonder maybe it's time to update the project files for ICL 11 since no one can download the ICL 10 from Intel. ICL 11.1.048 works very nice, no problems reported. The only thing is that I have to disable vectorization. |
22nd October 2009, 11:40 | #8811 | Link | |
Kid for Today
plugins need to be compiled w/ the new 2.58 DLL's, not too handy..so let's leave at that until 2.60 comes out. Last edited by leeperry; 22nd October 2009 at 11:42. |
22nd October 2009, 16:50 | #8814 | Link |
Multiply aspect ratio
Hi guys,
i have a problem with my aspect ratios and i miss an option for the resize/aspect-ratio filter: I am running WinXP with 800x600 resolution and my drivers and some applications require this resoltution as minimum. Although, my 7" LCD has a native resolution of 800x480 which squeezes the 800x600 diplay-content verticaly. Now i tried to get the right settings in the ffdshow resize-section to get the original aspect ratio on my lcd. This works perfectly for a given aspect-ratio, but is impossible if i e.g. want to watch both 16:9 and 4:3 videos. Only for one aspect i can set the right resize-options. What i need, is a field, where i can set mulitpliers for one side of the aspect-ratio. For example: The video is 16:9 and has to be modified to 16:9/480*600=16:11.25 to be displayed right on the LCD. If i play a 4:3 video, the aspect ratio has to be 4:3/480*600=4:3.75 to displayed right. I thought that the "process pixel aspect ratio internally" might do the trick, but this option had no effect what so ever on my machine. Is there a combination of configurations which i have to set to get the effect or is this option missing? thx SEB |
22nd October 2009, 22:55 | #8815 | Link | |
Roelofs Coaching |
22nd October 2009, 23:10 | #8816 | Link |
thx, played around with this option but never made any difference. only in combination with "keep original aspect ratio" it modified it to the seemingly corret aspect. The resize to fit resolution put the last piece into the puzzle.
thx alot |
23rd October 2009, 08:03 | #8817 | Link |
Remote API - delphi - DrawOSD
Whats up with DrawOSD function?
Will it be back again? And else - there is no updated delphi header and there is an error (imho) in last IffDecoder.h - the DrawOSD function is removed and added one more shortOSDmessage. When compiling that as overloaded functions - it cause an errors, if I remove old shortOSDmessage function - it works, but without HTML and multiple line handling PS I compile this on Delphi 7 Versoin of ffdshow - 3109 & Up Last edited by swordsman; 23rd October 2009 at 08:07. |
23rd October 2009, 10:21 | #8818 | Link |
swordsman,
we discussed about it few pages ago, DrawOSD was required the usage of a registry key to store the OSD message, which made it limited (no more than one message per frame), and hard to maintain with the upgrade to preset based OSD. we have a new overloaded shortOSDmessage (with x and y coordinates) which is more powerful. - I wasn't aware of a delphi header, but I see it now (IffDecoder_com.pas), can you use the "Overload;" keyword to make both work in delphi? otherwise I'm assuming we will have to rename the second shortOSDmessage to something like shortOSDmessageAbsolute. - regarding HTML / multiple lines, I now see that I've missed something, I'll see about it. p.s. regarding multiple lines, in most cases you can just use multiple calls to shortOSDmessage. Thanks, Tal Last edited by tal.aloni; 23rd October 2009 at 11:18. |
23rd October 2009, 11:25 | #8819 | Link |
If I use overload function I get errors, if I delete old ShortOSDMessage then I got it working? except HTML & multiline
In ffdshow with drawosd I used next: ..... st:='<font color=yellow> Sample rate:</font>'+smplrate+'KHz'+#10+ '<font color=yellow> Bit rate:</font>'+bitrate+'KBps' DrawOSD(10,10, pchar(st)); and got 2 lines with 2 colors. |
