17th August 2009, 04:58 | #7841 | Link |
heres a sample: http://www.sendspace.com/file/u83a49
17th August 2009, 10:43 | #7843 | Link | ||
Select "Set interlace flag in output media type" and Method: "Bob" Select NV12 colorspace and unselect all other colorspaces. Remove all filters (deinterlacers, resizing, ...) that you were using. If hardware deinterlacing and denoising doesn't work after these settings, try different renderers. Quote:
17th August 2009, 12:10 | #7844 | Link |
hardware deinterlacing works now that way, thanks. playback is quite a bit faster now and also had noise problem got somewhat better due to that. not as good as with powerdvd, but still better than all those software renderers.
only remaining problem seems to be that when I activate sharpening and the camera moves then the sharpened layer also seems to jump as well :S btw. is it still possible to use (.ass) subs with hardware deinterlacing? |
17th August 2009, 12:17 | #7845 | Link |
If you use the internal subtitle renderer of MPC then it should work.
MPC-HC 2.2.1 |
17th August 2009, 12:49 | #7847 | Link | |
MPC-HC Project Manager
Vsfilter is also interesting for mpc-hc use, some bugs that are in the internal splitter are not in vsfilter and vice versa (this has to do with the way the subs are drawn to the screen)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
17th August 2009, 16:58 | #7850 | Link |
aka XaS
Hardware de-interlacing comes last no matter what, so ... you can't =) Either use a sharpener that supports interlaced input, or separate fields + sharpen + weave.
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
17th August 2009, 17:12 | #7852 | Link |
Kid for Today
you only option is the PS sharpening scripts in MPC/KMP I think..try the default one at 0.65, it looks good, not as good as LSF though.
or through your graphic card drivers maybe? Last edited by leeperry; 17th August 2009 at 17:16. |
17th August 2009, 18:27 | #7854 | Link | |
17th August 2009, 18:46 | #7855 | Link |
wtf, denoising of 64 is the default setting 0o
in order to be as close to be to the original intended presentation as possible, I guess such options as denoising & edge enhancement & dynamic constrast have to be disabled then? |
17th August 2009, 19:04 | #7856 | Link | |
One of the reasons for denoising by default is that review sites test the video playback quality of graphics cards and other devices by playing benchmark videos such as HD HQV. The tested device gets better benchmark scores if it denoises noisy scenes properly. |
18th August 2009, 20:40 | #7858 | Link |
What means "Added new audio structure for windows 7" in rev 3056?
"Revision 3056 - Directory Listing Modified Mon Aug 17 12:37:38 2009 UTC (30 hours, 59 minutes ago) by albain Added new audio structure for windows 7 Added a verification of supported output sample format when the codec changes" |
18th August 2009, 22:31 | #7859 | Link |
It means better S/PDIF support.
MPC-HC 2.2.1 |
19th August 2009, 22:06 | #7860 | Link |
Some interesting news Dolby Digital Plus Chosen as an Audio Format for Windows 7 !
Maybe we will need the full 7.1 channels DD+ working in the end, cause this may rise back the almost dead DD+ format ?!
Intel UHD Graphics 750; Win 10 22H2 |
