8th March 2009, 17:02 | #1381 | Link | |
I had a similar distorted menu where the top title was clipped and the bottom credits were not visible, the sides were clipped as well. It turned out to be a setting on my TV. I had to change my Display Area to "Full Pixel" in order to see 1080i/p sources (the menu page is 1080p) in original size. Your TV might have a similar setting. |
8th March 2009, 17:11 | #1382 | Link |
Hi Dean,
When I scroll through the titles on an XMB compilation, I need to select down arrow (or up arrow) and then select (or Ok depending on the remote) to scroll the thumbnails. Is this by design or are you still working out some stuff? I am playing the disc on a Sony BDP-S350. Otherwise the XMB menu system is great! Thanks for all the hard work. |
8th March 2009, 17:54 | #1384 | Link | |
8th March 2009, 19:24 | #1386 | Link | |
Programmer (or just 教务长)
I'd advise all multiAVCHD users when playing multiAVCHD content to use full capabilities of their TV sets. @kenguru2005: I know |
8th March 2009, 20:04 | #1387 | Link | |
8th March 2009, 20:06 | #1388 | Link | |
It does take a while to go through all the settings and "tune" a new set-up. You actually have to read the manual to figure out some of the settings, |
8th March 2009, 22:58 | #1390 | Link | |
[16:10:59] Preparing authoring information... [16:10:59] Creating NTSC top menu. [16:11:19] Authoring custom titles menu (NTSC). [16:11:21] Encoding menu pages (x264)... [16:12:09] Muxing h264 stream for menu pages (tsMuxer)... [16:12:17] Populating menu structure... [16:12:48] Creating menu backgrounds for 1 titles (XMB)... [16:12:55] Error background image for title #1 (XMB)! [16:12:55] Trying to extract frame at 00:00:01... [16:12:56] Unsuccessful! (XMB) [16:12:56] Creating video backgrounds for XMB menu completed. [16:13:46] Authoring custom menu completed. |
8th March 2009, 23:04 | #1391 | Link |
Please try to run this compilation again but have your TEMP and multiAVCHD placed in the SAME drive:... I'll try to work on it but I think that having TEMP - MKV/TS/M2TS originate folder / multiAVCHD.exe folder in the same (or at most TWO different) folder(s) should fix it.
If you have: Input files in C:\* Temp in D:\* multiAVCHD.exe in F:\* (or D:\*) Output in G:\* then it probably won't work. I'll try to fix it in 444 later. Last edited by deank; 8th March 2009 at 23:07. |
9th March 2009, 00:53 | #1393 | Link | |
output was I:\ [custom name] Temp i:\TEMP MultiAVCHD c: drive on the desktop The issue was that the thumbnails or XMB menu generation doesn't seem to work if run via remote desktop. My Media PC that I do video work on is hooked to a TV, so I control it via remotedesktop. When I hooked up a USB mouse/keyboard and ran the program without remote desktop, I got some images. |
9th March 2009, 01:26 | #1395 | Link | |
Please allow the user to allow for over-scan during menu generation (3-5% of the perimeter of the image). |
9th March 2009, 02:20 | #1397 | Link | |
Also in the USA, a lot of digital stations still send blinking white bars on the top of the ATSC digital transmissions. For new users that uses a computer to receive digital ATSC transmissions, one of the more common new user complaints is how to get rid of those blinking while bars. |
9th March 2009, 04:52 | #1400 | Link |
I was trying to put 3 mkv files (1280x720p 25fps with 2 audio & 1 subtitle) in one AVCHD to play on the PS3 (NTSC) but it would just show the menu screen with 3 titles. Every time I select one of the titles it would just return to the main menu. Any suggestions?? Following is the logfile for making the multiBD (on DVD) -
[21:23:05] Log started for multiAVCHD v2.5 (build 444) [21:23:05] Processing 3 input files/folders . [21:23:05] Existing E:\CONVERTED\AVCHD\ renamed to E:\CONVERTED\AVCHD-20090308-212305 [21:23:05] Temp folder does not exist. Set to E:\_TEMP. [21:23:05] Converting mkv file to AVCHD (E:\SOURCE\GoodLuck01.mkv). [21:23:06] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x720 25.000fps (AR:1.78) [21:23:06] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: und [21:23:06] Detected audio: ID#3:A_AC3:audio (48000Hz/2ch) Language: und [21:23:06] Detected subtitles: ID#4:S_TEXT/UTF8 Language: und [21:23:06] Generating meta file for tsMuxer... [21:23:06] M2TS stream split set at 3999MiB... [21:23:07] Searching for original chapters (mediainfo)... [21:23:07] Inserting 5 min chapters... [21:23:07] Detected frame reference count: 1 (max:9). [21:23:07] Compliant with L4.1 for 1280x720p. [21:23:07] Creating BluRay folders (tsMuxer)... [21:25:14] Done! [21:25:14] CLPI transfer: E:\_TEMP\20090308-212307-7175\BDMV\CLIPINF\00001.clpi -> E:\CONVERTED\AVCHD\BDMV\CLIPINF\00000.clpi [21:25:14] M2TS transfer: E:\_TEMP\20090308-212307-7175\BDMV\STREAM\00001.m2ts -> E:\CONVERTED\AVCHD\BDMV\STREAM\00000.m2ts [21:25:15] MPLS transfer: E:\_TEMP\20090308-212307-7175\BDMV\PLAYLIST\00000.mpls -> E:\CONVERTED\AVCHD\BDMV\PLAYLIST\00000.mpls [21:25:15] Converting mkv file to AVCHD (E:\SOURCE\GoodLuck02.mkv). [21:25:15] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x720 25.000fps (AR:1.78) [21:25:15] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: und [21:25:15] Detected audio: ID#3:A_AC3:audio (48000Hz/2ch) Language: und [21:25:15] Detected subtitles: ID#4:S_TEXT/UTF8 Language: und [21:25:15] Generating meta file for tsMuxer... [21:25:15] M2TS stream split set at 3999MiB... [21:25:15] Searching for original chapters (mediainfo)... [21:25:15] Inserting 5 min chapters... [21:25:15] Detected frame reference count: 1 (max:9). [21:25:15] Compliant with L4.1 for 1280x720p. [21:25:15] Creating BluRay folders (tsMuxer)... [21:25:56] Done! [21:25:56] CLPI transfer: E:\_TEMP\20090308-212515-2618\BDMV\CLIPINF\00001.clpi -> E:\CONVERTED\AVCHD\BDMV\CLIPINF\00001.clpi [21:25:56] M2TS transfer: E:\_TEMP\20090308-212515-2618\BDMV\STREAM\00001.m2ts -> E:\CONVERTED\AVCHD\BDMV\STREAM\00001.m2ts [21:25:57] MPLS transfer: E:\_TEMP\20090308-212515-2618\BDMV\PLAYLIST\00000.mpls -> E:\CONVERTED\AVCHD\BDMV\PLAYLIST\00001.mpls [21:25:57] Converting mkv file to AVCHD (E:\SOURCE\GoodLuck03.mkv). [21:25:58] Detected video: ID#1:V_MPEG4/ISO/AVC:1280x720 25.000fps (AR:1.78) [21:25:58] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: und [21:25:58] Detected audio: ID#3:A_AC3:audio (48000Hz/2ch) Language: und [21:25:58] Detected subtitles: ID#4:S_TEXT/UTF8 Language: und [21:25:58] Generating meta file for tsMuxer... [21:25:58] M2TS stream split set at 3999MiB... [21:25:58] Searching for original chapters (mediainfo)... [21:25:58] Inserting 5 min chapters... [21:25:58] Detected frame reference count: 1 (max:9). [21:25:58] Compliant with L4.1 for 1280x720p. [21:25:58] Creating BluRay folders (tsMuxer)... [21:26:42] Done! [21:26:42] CLPI transfer: E:\_TEMP\20090308-212558-3928\BDMV\CLIPINF\00001.clpi -> E:\CONVERTED\AVCHD\BDMV\CLIPINF\00002.clpi [21:26:42] M2TS transfer: E:\_TEMP\20090308-212558-3928\BDMV\STREAM\00001.m2ts -> E:\CONVERTED\AVCHD\BDMV\STREAM\00002.m2ts [21:26:43] MPLS transfer: E:\_TEMP\20090308-212558-3928\BDMV\PLAYLIST\00000.mpls -> E:\CONVERTED\AVCHD\BDMV\PLAYLIST\00002.mpls [21:26:43] Preparing authoring information... [21:26:43] Creating NTSC top menu. [21:26:53] Setting menu for 3 titles... [21:26:53] Setting titles #4 to #40 to point at top menu. [21:26:53] Processing clip (CPI/CLPI) files... [21:26:53] Completed. [21:26:53] Done! [21:26:53] E:\CONVERTED\AVCHD folder created! [21:26:53] Burn its CONTENTS to DVD-UDF 2.50... [21:26:53] Deleting only files in temp folder (E:\_TEMP\)... [21:26:54] You may now remove temp folder (E:\_TEMP\). [21:26:54] Your compilation contains 2hrs 31min 6sec of video material. [21:26:54] End of log. |
