16th March 2008, 20:22 | #342 | Link |
I have revised DGPulldown to work with streams that have no GOP headers, which is perfectly legal, of course, though unusual. I also defaulted the file input dialog filter to just show MPEG2 elementary streams. I'll release it after some regression testing.
16th March 2008, 20:59 | #343 | Link |
Life's clearer in 4K UHD
Will you have the time to incorporate this suggestion too?
http://forum.doom9.org/showthread.ph...70#post1026570 Cheers
17th March 2008, 01:01 | #344 | Link | |
While looking at that, I found that the number_of_frame_centre_offsets (which determines how many bits to consume from the bitstream) is calculated based on the progressive_sequence flag, and so you can't just arbitrarily set it. But that means you can't arbitrarily clear it either, as I am doing! I'll have to investgate this a bit more and get back to you. I'll follow up in the DGPulldown thread. Last edited by Guest; 17th March 2008 at 01:04. |
19th March 2008, 23:41 | #345 | Link | |
Would be possible to have the same log structure in DGIndex?
20th March 2008, 08:13 | #347 | Link |
It was just an example from DGAVCDec. I still don't know how to save that kind of information to *.log.
20th March 2008, 14:15 | #349 | Link |
Turkey Machine
The Display Size in the Information window may have a bug in it. For 720x576 video at 4:3 aspect ratio, it says the display size is 540x576, when it should be 768x576.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
20th March 2008, 15:54 | #353 | Link |
Turkey Machine
I will both double-check the manual and make a small sample later.
20th March 2008, 23:06 | #355 | Link |
Problematic HD MPEG-2 file crashes dgindex
I have a .mpg MPEG-2 HD file that seems to be pretty broken. Only Cyberlink PowerDVD can play it back. The latest DGindex crashes when opening it without saving a log file. It has been captured from broadcast HDTV, and then converted to MPEG. Unfortunately, I no longer have the original TS file.
Does anyone have any suggestions on how it can be repaired before feeding it to dgindex? Karl.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
20th March 2008, 23:25 | #357 | Link |
OK. I will PM a link.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. Last edited by karl_lillevold; 20th March 2008 at 23:30. Reason: Microsoft MASM found |
20th March 2008, 23:44 | #359 | Link |
laserfan: Thanks. However, mpeg2repair appears to work only on transport streams, and VideoReDo Plus crashes
21st March 2008, 00:59 | #360 | Link |
The first sequence header of the stream declares a size of 704x480 and then all the rest are 1280x720. But most software will allocate buffers based on the first sequence header. I made your stream work by cutting away the first sequence.
Is this a one-time occurrence for you? |
