4th March 2012, 18:17 | #901 | Link | ||
http://msdn.microsoft.com/en-us/library/dd492418.aspx Quote:
My code to convert YUV -> RGB is incredibly slow in debug builds <.<
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th March 2012 at 18:21. |
4th March 2012, 19:21 | #902 | Link | |
QuickSync Decoder author
Checked with Dependency Walker - no new dlls are linked. QS decoder dll is twice as big though.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
4th March 2012, 20:07 | #903 | Link |
All the code required is dynamically pulled in through templates and whatnot, so yeah it ends up in your file.
4th March 2012, 20:50 | #904 | Link | |
for the second, I'm using BVBViewer (a very good TNT program). You can chose all the elements you want to use in the directX configuration page. If i chose an other decoder (CoreAVC, cyberlink, or ATI), it works as expected. If i chose FFDSHow (your version), it is ffdshow, and everything seems to wok. The only problem is, in ffdshow, i had configured Quick Sync for the codec, and (thanks to the direct show intelligent connect, of ffdshow ?) right clicking on the icon or opening Info & cpu tab shows Libavcodec as used instead. It says " input FOURCC:H264, Decoder: Libavcodec h264, Output color space: YV12 " I had tried both with EVR or VMR9 rendrers, same issue. According to one of your messages, i had configured the graphic card in BIOS to reserve 500 Mo of ram, and i can indeed see 3553 for the available physical memory (instead of 4GO) in the SEVEN task manager, and 543 Mo as reserved for material. Last edited by Esperado; 4th March 2012 at 21:01. |
4th March 2012, 21:14 | #905 | Link | |
4th March 2012, 21:28 | #906 | Link |
@ Egur
Still a lot Decoding issues with WMV3/9 MP though i guess you and the MSDK guys know that http://img859.imageshack.us/img859/9...codeissues.png
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 4th March 2012 at 21:33. |
4th March 2012, 21:36 | #907 | Link |
Esperado,
Can you try LAV video decoder instead of ffdshow - it will show you if QS is enabled on your system. I don't have live TV streams to check and very little test material for fourcc::H264 (most h264 content is AVC1). Make sure you are using the ffdshow latest version, fourcc::H264 wasn't supported a few versions ago. The problem could also be in the stream - if it's an h264 10bit or 4:2:2 profile than HW acceleration doesn't support it (neither on Nvidia/AMD).
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 4th March 2012 at 21:50. |
4th March 2012, 21:37 | #908 | Link | |
BTW, SPP deblocking or probably any other deblocking algorithm within ffdshow relies on having the quantization parameter for each macro block. I can't supply those parameters, so the deblocking algorithms will smooth the image a lot and effectively become useless.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 4th March 2012 at 21:49. |
5th March 2012, 00:21 | #909 | Link | |
Can it helps-you if i provide in line for you some .ts files recorded from TNT HD ? If yes, just tell-me how long you want-them. Yes, Intel Quick Sync seem activated, as it works now with ffdshow on non HD programs (since i had reserved memory for the graphic card ?). But it is not fluid (disappointing). Still does not woks with H264. Under libavcodec it is 1ms instable, under Quick sync it is 27-32ms, varying continuously. FFDshow Version is tryouts rev4322 feb 13 20 12 21:44:36 (MSCV 2010) and says H264 is implemented. If you need some extra info, feel free to ask me (with the way to get-it). Last edited by Esperado; 5th March 2012 at 00:29. |
5th March 2012, 04:38 | #910 | Link |
Installed LAV video decoder. It says "Intel Quick Sync active". And wow !
Works out of the box. Even with H264 HD channnels. The best de-interlacing of all my (numerous) testings. Added ffdshow raw video filter for a little Xsharpen, and gosh ! The best image of all. Soft and hardware. I have too an ATI Radeon R6850. 50 I/s absolutely constant in EVR renderer, <1ms of instability. And 0ms of instability with VMR9 (witch i prefer the texture). Only a little disappointed by cpu usage: it eats as much cpu than ffdshow libavcodec. Still here, Egur, if you need some files, and thanks so much for your help and fantastic work, together with Nevcairiel ! Last edited by Esperado; 5th March 2012 at 05:03. |
5th March 2012, 08:13 | #911 | Link | |
Both ffdshow and QS use the same QS dll but LAV sets the timestamps better. The latter is affected by the splitter in many cases and LAV does a better job than what I can do within my code (my code is not aware of the DirectShow environment as it's not a DS filter). LAV also has a very nice SW fallback mechanism in case a specific profile isn't supported in HW. CPU utilization levels are affected by bitrate - high bitrate will make QS shine, lower bitrates will make libavcodec shine. In live TV playback, LAV is superior to ffdshow with respect to QS usage as it works in lower latency. This has to do with timestamps generation as stated above. Update The latest ffdshow I've built fixes most of the live TV issues. you should try it too.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 5th March 2012 at 08:37. |
5th March 2012, 08:59 | #912 | Link |
Thus i say having a non copy back version like in the Reference Decoder would rock with less overhead lower latency
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 5th March 2012 at 09:03. |
5th March 2012, 09:35 | #913 | Link |
No image processing, no subtitles, must use EVR/VMR and the gain is mostly visible in benchmarks not in real playback of contemporary streams (e.g. most of stuff we watch today). One can use the MS decoder or a bunch of other DXVA decoders for that.
5th March 2012, 09:39 | #914 | Link |
To be fair, subtitles do work in many players, just not with ffdshows subtitle renderer or DirectVobSub.
5th March 2012, 09:46 | #915 | Link |
if everyone looks @ what dukey did and builds up on it subtitles would be no problem
and image processing the most important stuff can still be done over the shaders though i dunno what for the quality of intels EVR chain is excellent
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
5th March 2012, 10:53 | #916 | Link | |
In theory it should work with AYUV, but many GPUs don't support that.
5th March 2012, 15:51 | #918 | Link |
Yes, HW WMV9 playback and probably MVC (not supported in my code) as well but this driver isn't ready for the public yet so I recommend not using it. I recommend sticking with the official SandyBridge drivers for now (15.22 family).
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
