4th May 2013, 16:34 | #17001 | Link | |
4th May 2013, 17:10 | #17002 | Link |
All ok so far .... just did an GM anaglyph successfully @ 1440x1080.
This led me to another question: Is left-right standardized for 3D blu-ray? I seem to remember cases where the channels have been swapped. When there is no possibility to swap the channels during playback, the GM (or CR) setting should be changed to MG (or RC respectively) for encoding. Any thoughts? |
4th May 2013, 17:12 | #17003 | Link |
So i grabbed that BD3D2MK3D package and found the instructions & folder stereoplayer.exe inside it. If i read them instructions right i pretty much only need copy that folder to the harddrive & i'm done. Ifnot perhaps a clear set of instructions for it could be added to the 1st post of this thread.
4th May 2013, 17:34 | #17004 | Link | |
I'm hoping the Intel Directshow MVC decoder will work out and become a completely freeware solution that I can include with BD-RB in the future. Last edited by jdobbs; 4th May 2013 at 17:39. |
4th May 2013, 18:45 | #17006 | Link |
How would I set this up to output as a m2ts and fat compliant "under 4 gig". I have been using ripbot with no problem. I save as AVCHD 2 pass and lock size to 4103MB. But when I try that with this I get random results. Would it be possible for you jdobbs to and this as a output size?
I am just trying to do movie only. I go between mac,pc and ps3 with my thumbdrive to watch movies. Thanks |
4th May 2013, 19:38 | #17007 | Link |
Oh BDRB has always been in program folders for me. I got that lousy UAC disabled ^^. Never any issues. However it seems that the x264 builds in that stereoplayer.exe are older than the ones from BDRB. Should i replace them with BDRB's ?
BDRB x264: 0.132.2309.0 Stereo x264: 0.130.2273.0 Or will BDRB do that on it's own? |
4th May 2013, 19:48 | #17008 | Link | |
4th May 2013, 19:50 | #17009 | Link | |
4th May 2013, 20:00 | #17010 | Link |
kk, then i don't need to do anything. For simplicity i copied that folder into BDRB's "Tools" Folder. Same as i did with my DGDecNV . No possible chance of write access problems then ^^. Even though BDRB is in the program Files (x86) folder. I'll be trying that option out real soon.
5th May 2013, 04:59 | #17012 | Link |
The challenge I've noticed is... It's an extra. Movie & Menus with selective extras not to be blanked.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 5th May 2013 at 06:15. |
5th May 2013, 08:02 | #17014 | Link |
I just tried my first 3D encode with v0.44.03 and everything went fine until the rebuild phase when I get an "error in attempt to mux (MKVMERGE).
[05/04/13] BD Rebuilder v0.44.03 (beta) [22:42:05] Source: LIFE_OF_PI_00800 - Input BD size: 27.20 GB - Approximate total content: [02:06:59.611] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 640Kbs DD5.1 - 3D conversion mode enabled - Decoding/Frame serving: DirectShowMVC - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [22:42:16] PHASE ONE, Encoding - [22:42:16] Processing: VID_01217_3D (1 of 1) - [22:42:16] Combining multiple 3D segments. - [22:52:05] Extracting A/V streams [VID_01217] - [22:56:48] Reencoding video [VID_01217] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 182,688 frames - Converting output to Side-By-Side 3D Format - Bitrate: 7,570 Kbs - [22:56:48] Reencoding: VID_01217, Pass 1 of 2 - [00:09:21] Reencoding: VID_01217, Pass 2 of 2 - [01:20:50] Video Encode complete - [01:20:50] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [01:23:13]PHASE ONE complete [01:23:13]PHASE TWO - Rebuild Started - [01:23:13] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [01:28:53] - Failed to REBUILD edit: I went into the work files and saw two x264 streams of the same sizes, I manually muxed them with an old build of mkvmerge, the resulting two mkv files both play in sbs format but each side's video is out of sync by 10seconds on the one mkv and even more on the other mkv. I have no knowledge of how all this encoding works, so if I'm doing something dumb, dont hesitate to correct me. I'll try the next encode with a different 3D blu-ray and use the DirectShowMVCSource.dll and files from MVC Player Free v0.0.1.5 and not BD3D2MK3D as I did with the first encode. Last edited by richardrpg; 5th May 2013 at 09:42. |
5th May 2013, 12:04 | #17015 | Link |
Just ran another 3D encode (Thor 3D) and it worked perfectly, I used the DirectShowMVCSource.dll and files from MVC Player Free v0.0.1.5 and not BD3D2MK3D. I also checked the work files and there is only 1 x264 stream and not 2 as with the previous encode of Life of Pi. I did notice that with Life of Pi, there was an extra step used during the encode, namely "Combining multiple 3D segments." which did not happen with Thor.
I'll run Life of Pi again with my current set-up as I know the set-up works and then should have clarity whether its a BD-rebuilder bug or an issue with Life of Pi itself. |
5th May 2013, 14:00 | #17017 | Link | |
5th May 2013, 14:59 | #17018 | Link |
Completed Life of Pi 3D with exactly the same settings as Thor 3D, again I get the error "failed to rebuild" it rebuilds up to 100% and then stops and sends that partial rebuild to the work files.
Seems there is something different about the Life of Pi 3D disc, even if I remux that partial build, the resultant mkv is in sbs format, but as before the 2 sides are way out of sync. Someone who has more knowledge regarding encoding can take a stab at Life of Pi 3D. ---------------------- [05/05/13] BD Rebuilder v0.44.03 (beta) [13:10:07] Source: LIFE_OF_PI_00800 - Input BD size: 27.20 GB - Approximate total content: [02:06:59.611] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 640Kbs DD5.1 - 3D conversion mode enabled - Decoding/Frame serving: DirectShowMVC - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [13:10:10] PHASE ONE, Encoding - [13:10:10] Processing: VID_01217_3D (1 of 1) - [13:10:10] Combining multiple 3D segments. - [13:17:42] Extracting A/V streams [VID_01217] - [13:21:39] Reencoding video [VID_01217] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 182,688 frames - Converting output to Side-By-Side 3D Format - Bitrate: 7,570 Kbs - [13:21:39] Reencoding: VID_01217, Pass 1 of 2 - [14:34:40] Reencoding: VID_01217, Pass 2 of 2 - [15:45:23] Video Encode complete - [15:45:23] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... [15:47:44]PHASE ONE complete [15:47:44]PHASE TWO - Rebuild Started - [15:47:44] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [15:52:32] - Failed to REBUILD |
5th May 2013, 15:28 | #17020 | Link | |
I'll do a few discs to MKV and see if I run into any issues. I seem to recall someone mentioning an alternate version of MKVMERGE for some systems... Last edited by jdobbs; 5th May 2013 at 15:31. |
