4th January 2011, 06:08 | #15621 | Link | |
An excerpt from Anand's Sandy Bridge review,
http://www.anandtech.com/show/4083/t...-2100-tested/7 Quote:
That part about Intel reaching out to "the developer" of MPC-HC is odd. Who did they talk to? Is Intel contributing code for MPC-HC? Last edited by joe42; 4th January 2011 at 06:29. |
4th January 2011, 10:28 | #15622 | Link |
Beyond the Corn Border
joe42, there is no spoon. In other words, I'll bet D3DFS fooled you into thinking you've got 10bit smooth output, but instead what happened was that D3DFS switched 16-235 on. And there is the display itself that does on-the-fly adjustments even if you set it at certain figures. Did you notice a slight drop in brightness level? Because that's what happens when 16-235 goes on. And please note that windowed tests are irrelevant, this whole 10-bit thing works only on full-screen mode. After ~2h of staring at a solar eclipse, my conclusion might be wrong
Anyway, this whole FP thing does little thing for 8-bit displays at the moment, and that is where the resources should be spent, not for the 0.05% 10-bit capable (not advertised) hardware, users have. Maybe it's time for a dither implementation, now that direct processing sort of works, JanWillem32? |
4th January 2011, 11:47 | #15624 | Link | ||
I think I will answare these on behalf of joe42.
Almost everything can happen when I connect my display to my Radeon HD5850 with a HDMI cable: PC-TV level mismatch (ignored pixel format settings and chaotic PC->TV conversions with HDTV resolutions), double-corrected (desaturated) colors with the xvYCC mode, and other random things (like a small flickering in every ~20 minutes). But it's absolutely stable and reasonable with DisplayPort connection. The driver doesn't think that it has to be a smartass and deal with a broken player software and HDTV combo, and the display doesn't think that it fights against a broken media player which thinks that it has a dirty business with a broken HDTV; or God knows why the hell they do these chaotic things. On the other hand... The display works with a 12-bit controller, so I guess it would do a nice job with a TV-PC level conversion. But the possibility that EVR could tell the display to do this expansion and it really did it... almost zero... (May be with HDMI connection and the help of this solar eclipse but only once in a lifetime...) It's an LCD with ~950:1 contrast ratio. It's far from perfect but only "acceptable" for me. So, it's easy to tell if 0-16 values are cut or not. Dark tones would be really bright grays then. Quote:
The "10-bit input" without the "10-bit output" used 10-bit RGB and dithered it back to 8-bit display output (older builds, not these test versions) and caused a smooth gradient. And it also worked with windowed mode! You need the D3DFS mode for real 10-bit display mode but it isn't necessary for 10-bit processing and dithering until the display mode is the usual 8-bit. (At least as I can remember. I used to watch movies with madVR, I am just here to do some experiment with 10-bit and XYZ-LUT based CMS.) Why do you think that it wasn't 10-bit? The hardwares are capable, the software is theoretically capable and it looks like it works. Why can't you believe if it worked? Didn't it work for you with a TN display or an expensive but unfortunately incompatible HDTV, or what? Last edited by janos666; 4th January 2011 at 11:52. |
4th January 2011, 12:09 | #15625 | Link |
Sry joe42 It's easy to get disoriented with all these clone-type names janos666, you are right. After all those panel lotteries going on, I did not expect any change in the business model to favour the customer. So it's an 8-bit panel with dither advertised as 10-bit, but it still works better in Photoshop than in MPC-HC?! It's hard to find a professional display here, I will search some more.
4th January 2011, 13:26 | #15626 | Link |
The higher than 8-bit processing formats are quite useful if you have to: extend Y'CbCr values to full range, up-scale chroma resolutions, convert Y'CbCr formats to RGB formats, convert input gamma functions, scale video resolutions, apply display output gamma functions(+color corrections), and any other kinds of filtering applied besides that. Each of those steps can change the color values enormously of an original pixel. Using a limited processing format of 8-bit will truncate the original output of each step to 8-bit, causing inaccurate rounding.
Another thing is dithering. If the ditherer receives an input format with the same accuracy as the output format, it shouldn't activate at all. Dithering should be done by selectively rounding in-between values up or down from the input format to the output format. If the the processing format doesn't deliver those bits, there's nothing to round up or down anymore. I also don't like the current type of dithering. The color resolutions it can use are okay, even for 10-bit output, but the method suits still image dithering the most. I tried to write a ditherer that uses a different method in a pixel shader, but it's very hard to get it just right, also considering the temporal dithering issues. I agree that the usage and type of dithering should be user-selectable (maybe even with the GPU/CPU processing costs indicated in the menu). I worked quite a bit on making it possible to render with only 4×fp32 surfaces (the maximum allowed surface format in DirectX 9). Later on, it will be important to choose what formats are sane for 10-bit output, 8-bit output and 8-bit output on slower machines. I'm already satisfied with the current handling of the 10-bit backbuffer and display formats. The only big problem is that exiting video from D3DFS with 10-bit output can cause black or darkened screens, but I think that can be solved in a while. (Build 1824 had the same problem.) |
4th January 2011, 14:43 | #15627 | Link |
MPC-HC has started doing some weird stuff with going into fullscreen mode on my Windows 7 HTPC with v1.4.2499. I've never seen it before until I switched to W7. Basically I go into fullscreen mode, but the left edges and bottom edges are still displaying the windows desktop in the background. If I exit and go back into fullscreen 2-3 times it eventually fixes itself.
Any solutions? Edit: It seems it doesn't do it when you go from a non-maximised window to fullscren. But if the window is maximised and you enter fullscreen mode the problem is there. This is occurring while watching a 720P MKV with DXVA. Not sure if it does it with Avi or non-DXVA yet. Last edited by Ingram; 4th January 2011 at 14:48. |
4th January 2011, 15:08 | #15629 | Link |
Ingram, what display driver are you using? It sounds like the backbuffer isn't cleared automatically. Try the VMR-9 (renderless), EVR-CP and EVR Sync. renderers. Of those I'm sure they clean up of the buffers quite properly.
4th January 2011, 15:11 | #15630 | Link | |
4th January 2011, 15:14 | #15631 | Link | |
Because when "Enable custom channel mapping" it's enable the default mapping for 8 channels it's wrong = channel 7 it's mapped to "Front Left of Center" instead of "Back Left" and channel 8 it's mapped to "Front Right of Center" instead of "Back Right" When "Enable custom channel mapping" it's not enable the mapping it's correct !
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 4th January 2011 at 15:24. |
4th January 2011, 15:34 | #15632 | Link | |
As for system font, default? I've not touched it. |
4th January 2011, 15:41 | #15633 | Link | |
But take a look at some 6+2 bit TN panels. They are significantly better than simple 6-bit TN panels. When you do 8+2 bit, the side-effect is much weaker. And there is internal processing. It's better to feed the display with 10-bit before it starts to send it though the 12-bit internal LUT and correct the WP according the R,G,B Gains. And may be I will get a real 10-bit panel in the "not too distant future". The current dithering is enough to test the possibilities (software side) and judge if it's worth some money or not (visible or not). |
5th January 2011, 11:13 | #15634 | Link | |
MPC-HC uses the default Microsoft EVR Mixer. The MPC-HC EVR Presenter only accepts RGB input, so it lets the Mixer do the YUV->RGB conversion. By Forcing 10-bit Input, it trys to get the Mixer to output 10bit data of this conversion, and hopefully also process it internally at this level (it might do float processing internally anyway, or use the output format, i don't think MS ever exposed those details). It does not affect the output from the decoder.
5th January 2011, 14:41 | #15635 | Link |
Is there a list of ATI cards and what H264 decoding is supported on them?
For example I know that my 4850 can deal even with 1080p at L5.1 and I want to know economic models on sale now that supports all kinds of formats. |
5th January 2011, 14:53 | #15636 | Link |
http://en.wikipedia.org/wiki/Unified_Video_Decoder
All versions of UVD should support H264 decoding. Best results you'll get with all UVD 2.2 or UVD 3 models, of course. Also don't forget that you might need performance to do rescaling and deinterlacing on the GPU, however the 5450 appears to handle that just fine already (lowest card in the 5xxx series)
5th January 2011, 19:41 | #15637 | Link |
Yes, I was more worried about the specifics. For example it seems some cards can't handle 1080p L5.1, or can't handle more than 8 ref frames.
It seemed that it didn't depend entirely on just the chip. Mine has just UVD 2 and can read everything (beside LQ, which is a driver thing). Some other cards seem to work fine only up to L4.1. So could a 5450 do 1080p with L5.1 and 16 ref frames like mine? |
5th January 2011, 19:46 | #15638 | Link | |
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
5th January 2011, 21:59 | #15639 | Link |
Just saw this (SDK documentation for AMD/Ati Open Video Decode API) and wondered if this is interesting to you guys.
JanWillem: Ik volg je vorderingen met grote interesse. Ben benieuwd hoe eea uit zal gaan komen in MPC-HT ! |
6th January 2011, 06:36 | #15640 | Link | |
micksh is doing some UVD3 testing which may be of interest to you. http://www.avsforum.com/avs-vb/showp...&postcount=120 |
