13th September 2007, 08:03 | #3382 | Link |
HDConvertToX author
the trim in preview panel is for cutting last part of video
you can also use the "Last line avs script" and write Trim(1500,5000) ... for example BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
13th September 2007, 15:14 | #3383 | Link |
HDConvertToX author
Update 0.90!
please referr to first post for download link 0.90 Full Package 13/09/2007 ADDED: PGCDemux and DvdDecrypter support. Reworked how episodic dvd is engaged. 1) FIRST CASE: WORKING WITH DVD TO RIP the ripping will be done by dvddecrypter, in case of "difficult" ripping i suggest to use ripit4me or dvdfabdecrypter (after this you can mount the iso to simulate "dvd to rip") On PGC list select your pgc (episode) and DVDDecrypter will rip only this pgc 2) SECOND CASE: WORKING ON DVD ALREADY RIPPED (laying on hd) If selected the first pgc, dgindex will start directly, else PGCDemux will "demux" the selected pgc and this will be used for encoding Don't strip audio from dvd or dgindex will be fouled when demuxing audio tracks! ADDED: CFilter folder in \exe folder. In this folder put plugin that need LoadCPlugin (like yadif) ADDED: VirtualDubPlugins in \exe folder. In this folder put VirtualDub plugins that want to load (example DeLogo.vdf). The filter will be loaded as this (for example) LoadVirtualDubPlugin("c:\VirtualDub-1_4_10\plugins\delogo.vdf","delogo"), attention to filter name "delogo". The filter name is based on plugin name!. So if plugin is called "awesome_deinterlacer.vdf" the filter will de called "awesome_deinterlacer". To use DeLogo plugin (and other virtualdub plugins) remember to converto rgb32 before. like this ConvertToRGB32.delogo(1, "500-999", "D:/2.bmp", "D:/2.bmp", "D:/1.bmp", "D:/2.bmp", 34, 56, 0,0).ConvertToyv12(interlaced=true) , apply this string to Last line avs string or base.avs ADDED: If .chunks is present in original folder, before launching VSrip these file will be deleted (suggestion by vOjToL) ADDED: In Xvid Status encoding the total time estimated and % of worked frames (suggestion by connex) ADDED: Even in xvid 2 pass encoding the average bitrate is displayed in window ADDED: FFmpegSource to queue saving ADDED: DGDecode_Deblock in Advanced Profile Editing ADDED: More X264 profiles, made by Kurtnoise13 PD_Apple_iPhone.xml,PD_Apple_TV.xml,PD-ATV.xml,PD-iPhone.xml,PD-Archos605.xml ADDED: MVDegrain1 ADDED: MP4 as allowed audio input (suggestion by tha_reaper) ADDED: In X264 encoding window the bitrate (suggestion by bleedingum) ADDED: In Advanced Audio Options the possibility to encode with SoundOut with OGG/FLAC/WAV Extended/MP2 ADDED: In log the use of Specify Quality and Specify Bitrate ADDED: Workaround for "Field Order Transition Detected" on Dgindex. The d2v is now checked against TFM and if movie-fixed.d2v is generated, then AutoMKV will use it ADDED: Check , in Advanced profile editing, for allowing third pass with x264 (suggestion by 3ngel) ADDED: In Advanced Settings "Hide Subs". This option is to use only for mkv container and will force player to not show subtitle ADDED: Option to force first pass with the same value as second pass. Check "HQ first pass" in Advanced profile editing (suggestion by 3ngel) ADDED: XviD_Sap_Scure to use for SAP compatibility when dealing with high compressibility source FIXED: Using preview with d2v with HD movie (thanks to bisdelf) FIXED: Spelling (thanks to InorganicMatter) FIXED: X264 profile and use of deadzone-intra/inter (thanks to peter_h) FIXED: Using the preview without filter enabled (thanks to edwardt) FIXED: Missing parsing of Width parameter for x264 profiles FIXED: No more need to copy ffmpeg libraries, libsndfile-1.dll or fftw3.dll in \windows\system32. Anyway is always preferred to copy these dll. FIXED: AutoMKV will wrongly apply TFM/TDecimate on avi input. (thanks to AC84) FIXED: In 2 pass encoding the default subme for first pass is now 2, look here http://forum.doom9.org/showthread.ph...85#post1035385 FIXED: Muxing problem using MP4Box and long path FIXED: Reporting of wrong size of muxed file when container is MP4 (thanks to delacroixp) FIXED: Title muxing when using Avi container and VirtualdubMod muxer FIXED: Preview using ifo as input (thanks to DIEGO7-5) FIXED: In log the report of a second pass when using Quality Mode (thanks to jellyfish2002) FIXED: Erroneus splitting in many and more parts (beta fix) FIXED: By default the encoding status is no more displayed. This will bring more speed to encoding and if wanted in Advanced profile editing is possible to enable it FIXED: The deinterlacer status is not displayed. This will bring a more faster analysis and a more secure results. FIXED: Custom BAT for audio encoding. Now is passed the Destination directory as variable. Look at custom_mp2.bat and custom_besweet.bat in \besweet folder REMOVED: Vstrip, DVDFabDecrypter UPDATE: MVTools to 1.8.4, mt_masktools to 2.0 alpha 32, update NicAudio (13/08/2007), PS3.xml and X264 profiles like 1_Pass_High Performance.xml, 2_Pass_Balanced.xml,2_Pass_Better_Quality.xml (http://forum.doom9.org/showthread.ph...09#post1035509), XviD profiles,Mktoolnix to 2.1.0, BAutoDeint thanks to Andreas Kuhlen, DGindex 1.5.0b1, xvid_encraw 31/08/2007, MediaInfo 0.7.5.2, ColorMatrix 2.2, FFmpegSource 1.11, dgmpgdec 150b2,x264 r675 BHH
13th September 2007, 19:31 | #3387 | Link |
thanks buzz,
I was wondering if the new Apple profiles for the apple tv and ipod will actually play on the apple tv? Strange question but I remember something a few months ago that they wouldn't; something about a package problem I think. |
13th September 2007, 19:56 | #3389 | Link | ||
HDConvertToX author
@weaver4
BHH
13th September 2007, 22:36 | #3390 | Link |
I'm still having crashing problems if the show enc stats is unchecked. I tried v0.90 out on my work computer running vista (previously is was using my home computer running XP SP2) and here is the crash log that happens a few seconds into the first pass of the encode.
Problem signature: Problem Event Name: APPCRASH Application Name: AutoMKV090.exe Application Version: 0.89.0.0 Application Timestamp: 46e934f7 Fault Module Name: AutoMKV090.exe Fault Module Version: 0.89.0.0 Fault Module Timestamp: 46e934f7 Exception Code: c0000005 Exception Offset: 000b9b0b OS Version: 6.0.6000.2.0.0.256.6 Locale ID: 5129 Code:
10:23:17 0.90 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 10:23:17 Selected Input file: F:\DVD\DVD\VIDEO_TS\VTS_01_0.IFO 10:23:17 Selected Output dir: F:\DVD\DVD\temp\ 10:23:17 Selected Final Name: VTS_01_0 10:23:17 Selected Container type: MKV 10:23:17 Selected Encoder: X264 10:23:17 Selected Size: 30 / 1 10:23:17 Selected Profile: 2_Pass_Extreme_Quality.xml 10:23:17 Selected Resizer: Lanczosmtplus / Automatic 10:23:17 Selected Filters: RemoveGrain(mode=2) 10:23:17 Selected Deinterlacer: AUTO 10:23:17 Selected Field Order: AUTO 10:23:17 NeroAACEnc.exe: not present 10:23:17 Track Language 1: English (AC3 2ch, 0xBD 0x80) [0] 10:23:17 Audio Codec 1: Copy Original 10:23:17 Audio Quality 1: 3 10:23:17 Audio Channel 1: Stereo 10:23:17 Advanced Audio Settings DUMP Track 1 10:23:17 Nero Option Profiles: AUTO --- Encoding Mode: Quality 10:23:17 CCT Option Profiles: AUTO --- Channel Options: AUTO 10:23:17 Lame Settings: ABR 10:23:17 Audio Normalization: 1 10:23:17 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 10:23:17 Advanced Audio Settings DUMP Track 2 10:23:17 Nero Option Profiles: AUTO --- Encoding Mode: Quality 10:23:17 CCT Option Profiles: AUTO --- Channel Options: AUTO 10:23:17 Lame Settings: ABR 10:23:17 Audio Normalization: 1 10:23:17 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 10:23:17 10:23:17 Starting Indexing 10:23:17 Dgindex CMD: F:\AutoMKV090_NORIP\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1 -YR=2 -AIF=[F:\DVD\DVD\VIDEO_TS\VTS_01_1.vob] -OF=[F:\DVD\DVD\temp\movie] -exit -minimize 10:23:44 Finished indexing 10:23:44 D2V file size: 62302 10:23:44 Starting fixing audio delay on track number 1 10:23:44 DelayCut CMD: F:\AutoMKV090_NORIP\exe\dgindex\Delaycut.exe -auto -out "F:\DVD\DVD\temp\fixed1.ac3" "F:\DVD\DVD\temp\movie T01 2_0ch 192Kbps DELAY 0ms.ac3" 10:23:44 Original 1 Audio Size: 12549888 bytes 10:23:45 Fixed 1' Audio Size: 12549888 bytes 10:23:45 Finished fixing audio delay 10:23:45 Renamed file fixed1.ac3 to audio.ac3 10:23:45 Encoded 1' Audio Track: 12549888 bytes 10:23:51 Number of Frames: 13072 10:23:51 Framerate: 25.000000 10:23:51 Movie length in Seconds: 523 10:23:51 Movie Width/Height: 720/576 10:23:51 DgIndex AR: 4:3 10:23:53 Starting X264 AutoResize with WIDTH of Automatic and wanted size of 31457280 bytes 10:23:53 CRF encoding X264: F:\AutoMKV090_NORIP\exe\encoder\x264.exe --pass 1 --crf 18 --stats "F:\DVD\DVD\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 12 --filter -2,-1 --direct auto --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-pyramid --b-rdo --bime --analyse p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads auto --thread-input --output "F:\DVD\DVD\temp\resmovie.mp4" "F:\DVD\DVD\temp\resmovie.avs" 10:26:14 Finished Autosize procedure 10:26:14 Tested total movie: 5% 10:26:14 AutoResize movie size: 11449467 bytes 10:26:14 Movie Width suggested: 96 value based on sample size (13.33% of original width) 10:26:14 Starting X264 10:26:14 Command Line 1' Pass X264: F:\AutoMKV090_NORIP\exe\encoder\x264.exe --pass 1 --bitrate 288 --stats "F:\DVD\DVD\temp\.stats" --ref 1 --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --filter -2,-1 --subme 2 --direct auto --vbv-maxrate 25000 --me dia --no-ssim --b-pyramid --analyse none --threads auto --thread-input --output NUL "F:\DVD\DVD\temp\movie.avs" 10:26:14 Command Line 2' Pass X264: F:\AutoMKV090_NORIP\exe\encoder\x264.exe --pass 2 --bitrate 288 --stats "F:\DVD\DVD\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 12 --filter -2,-1 --direct auto --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-pyramid --b-rdo --bime --analyse p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads auto --thread-input --output "F:\DVD\DVD\temp\movie.mp4" "F:\DVD\DVD\temp\movie.avs"
A Man Eating Duck |
14th September 2007, 06:49 | #3391 | Link |
HDConvertToX author
you got always the error .. or only sometimes ?
BHH
14th September 2007, 08:18 | #3392 | Link |
HDConvertToX author
update 0.90a
FIXED: Keyboard shortcut form HCEnc/Avs2Avi (previusly could break some games.. like PES6 when played at in windowed mode) FIXED: Better thread optimizations i have worked on how threads (encoding and windows) are collaborating. In this build i have re-enabled by default the encoding status windows. On XviD encoding, with encoding status window, the speed are over +15% and some point % for x264 I suggest all to update to this build http://www.64k.it/andres/data/a/AutoMKV090a.exe BHH
14th September 2007, 09:00 | #3393 | Link |
Hi buzzqw!
Something is wrong with the new xvid_profile_balanced(maybe with the others profiles too) Look at this: new profile/old profile http://img369.imageshack.us/img369/3880/profile2ro4.jpg and this: http://img369.imageshack.us/img369/8457/profileuc1.jpg Average bitrate firstpass new profile ~7000kbps old profile ~1700kbps Average movie bitrate: 1044kbps Last edited by vOjToL; 14th September 2007 at 14:10. |
14th September 2007, 09:30 | #3394 | Link |
HDConvertToX author
the change made should bring more quality to 2 pass profile... here is the old profile pack http://www.64k.it/andres/data/a/AutoMKV_profiles089.rar but.. it's strange! could you do some test with other source too ? thanks! BHH
14th September 2007, 11:25 | #3395 | Link | |
02:46:23 0.90 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 02:46:23 Selected Input file: E:\samuraj jack[9][xvid].avs 02:46:23 Selected Output dir: E:\Scooby Doo\Scooby-Doo Show\temp\ 02:46:23 Selected Final Name: samuraj jack[9][xvid] 02:46:23 Selected Container type: AVI 02:46:23 Selected Encoder: XviD 02:46:23 Selected Size: 175 / 1 02:46:23 Selected Profile: 2_Pass_Balanced.xml 02:46:23 Selected Resizer: NONE / Original 02:46:23 Selected Filters: NONE 02:46:23 Selected Deinterlacer: AUTO 02:46:23 Selected Field Order: AUTO 02:46:23 Enabled CRF/CQ AutoRes at 2.5 value 02:46:23 Track Language 1: E:\samuraj jack[9][xvid].avs 02:46:23 Audio Codec 1: Lame 02:46:23 Audio Quality 1: 112 02:46:23 Audio Channel 1: Stereo 02:46:23 Advanced Audio Settings DUMP Track 1 02:46:23 Nero Option Profiles: AUTO --- Encoding Mode: Quality 02:46:23 CCT Option Profiles: AUTO --- Channel Options: AUTO 02:46:23 Lame Settings: ABR 02:46:23 Audio Normalization: 1 02:46:23 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 02:46:23 Advanced Audio Settings DUMP Track 2 02:46:23 Nero Option Profiles: AUTO --- Encoding Mode: Quality 02:46:23 CCT Option Profiles: AUTO --- Channel Options: AUTO 02:46:23 Lame Settings: ABR 02:46:23 Audio Normalization: 1 02:46:23 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 02:46:23 02:46:23 Copied file E:\samuraj jack[9][xvid].avs to E:\Scooby Doo\Scooby-Doo Show\temp\fixed1.avs 02:46:23 Copied file NONE to E:\Scooby Doo\Scooby-Doo Show\temp\fixed2. 02:46:23 Encoding E:\Scooby Doo\Scooby-Doo Show\temp\fixed1.avs To Mp3 with 112 ABR Preset 02:51:20 Encoded 1' Audio Track: 16811502 bytes 02:51:48 Number of Frames: 31867 02:51:48 Framerate: 25.000000 02:51:48 Movie length in Seconds: 1275 02:51:48 Movie Width/Height: 560/448 02:52:30 FIRST pass XviD: "H:\AutoMKV\exe\encoder\xvid_encraw.exe" -pass1 -bitrate 1044 -turbo -progress -max_bframes 2 -imin 3 -imax 16 -quality 6 -vhqmode 1 -pmax 16 -bmax 16 -bquant_ratio 30 -bquant_offset 0 -kboost 20 -odegrade 9 -nopacked -nochromame -bvhq -threads 0 -i "E:\Scooby Doo\Scooby-Doo Show\temp\movie.avs" -type 2 -avi "E:\Scooby Doo\Scooby-Doo Show\temp\movie.avi" 02:52:30 SECOND pass XviD: "H:\AutoMKV\exe\encoder\xvid_encraw.exe" -pass2 -bitrate 1044 -progress -max_bframes 2 -imin 3 -imax 16 -quality 6 -vhqmode 1 -pmax 16 -bmax 16 -bquant_ratio 30 -bquant_offset 0 -kboost 20 -odegrade 9 -nopacked -nochromame -bvhq -threads 0 -i "E:\Scooby Doo\Scooby-Doo Show\temp\movie.avs" -type 2 -avi "E:\Scooby Doo\Scooby-Doo Show\temp\movie.avi" 03:17:55 Starting Second Pass 03:47:15 Only Movie Size: 170858592 bytes 03:47:16 Using VirtualDubMod for Muxing! 03:47:31 Encoding finished: 00:29:36 elapsed time 03:47:31 ----------------------------------------------------------------------- 03:47:31 Script AutoCrop.log 03:47:31 ----------------------------------------------------------------------- 03:47:31 Script Resmovie.avs 03:47:31 ----------------------------------------------------------------------- 03:47:31 Script movie.avs 03:47:31 03:47:31 Import("E:\samuraj jack[9][xvid].avs") 03:47:31 isRGB(last) ? ConvertToYV12(last,interlaced=true) : last 03:47:31 isYUY2(last) ? ConvertToYV12(last,interlaced=true) : last 03:47:31 return last 03:47:31 ----------------------------------------------------------------------- 03:47:31 Script mkvmaudio.avs 03:47:31 03:47:31 LoadPlugin("H:\AutoMKV\exe\filter\NicAudio.dll") 03:47:31 LoadPlugin("H:\AutoMKV\exe\filter\SoundOut.dll") 03:47:31 LoadPlugin("H:\AutoMKV\exe\filter\FFmpegSource.dll") 03:47:31 Import("E:\samuraj jack[9][xvid].avs") 03:47:31 #Applying STEREO downmixing routines 03:47:31 function stereo(clip a) 03:47:31 { 03:47:31 flr = GetChannel(a, 1, 2) 03:47:31 fcc = GetChannel(a, 3) 03:47:31 lfe = GetChannel(a, 4) 03:47:31 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071) 03:47:31 mix = MergeChannels(lfc, lfc) 03:47:31 lrc = MixAudio(flr, mix, 0.2929, 1.0) 03:47:31 blr = GetChannel(a, 5, 6) 03:47:31 Return MixAudio(lrc, blr, 1.0, 0.2929) 03:47:31 } 03:47:31 # 03:47:31 6==Audiochannels() ? stereo() : last 03:47:31 function addvideo(clip c) { 03:47:32 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100) 03:47:32 Return audiodub(last,c) 03:47:32 } 03:47:32 Normalize() 03:47:32 Soundout(output="mp3",type=0,format=0,autoclose=true,mode=1,abrrate=112,showoutput=false,filename="audio.mp3") 03:47:32 ----------------------------------------------------------------------- 03:47:32 Script mkvmaudio.bat 03:47:32 ----------------------------------------------------------------------- 03:47:32 Script mkvmaudio2.avs 03:47:32 ----------------------------------------------------------------------- 03:47:32 Script mkvmaudio2.bat 03:47:32 ----------------------------------------------------------------------- 03:47:32 Script VirtualDubMod.vcf 03:47:32 03:47:32 VirtualDub.Open("E:\\Scooby Doo\\Scooby-Doo Show\\temp\\movie.avi",0,0); 03:47:32 VirtualDub.RemoveInputStreams(); 03:47:32 VirtualDub.stream[0].SetSource("E:\\Scooby Doo\\Scooby-Doo Show\\temp\\audio.mp3",0x00000202,1); 03:47:32 VirtualDub.stream[0].DeleteComments(1); 03:47:32 VirtualDub.stream[0].AdjustChapters(1); 03:47:32 VirtualDub.stream[0].SetMode(0); 03:47:32 VirtualDub.stream[0].SetInterleave(1,500,1,0,86); 03:47:32 VirtualDub.stream[0].SetClipMode(1,1); 03:47:32 VirtualDub.stream[0].SetConversion(0,0,0,0,0); 03:47:32 VirtualDub.stream[0].SetVolume(); 03:47:32 VirtualDub.stream[0].SetCompression(); 03:47:32 VirtualDub.stream[0].EnableFilterGraph(0); 03:47:32 VirtualDub.stream[0].filters.Clear(); 03:47:32 VirtualDub.video.DeleteComments(1); 03:47:32 VirtualDub.video.AddComment(0x00000005,"ISFT","Done with AutoMKV! http://forum.doom9.org/showthread.php?t=113811"); 03:47:32 VirtualDub.video.AdjustChapters(1); 03:47:32 VirtualDub.video.SetDepth(24,24); 03:47:32 VirtualDub.video.SetMode(0); 03:47:32 VirtualDub.video.SetFrameRate(0,1); 03:47:32 VirtualDub.video.SetIVTC(0,0,-1,0); 03:47:32 VirtualDub.video.SetCompression(); 03:47:32 VirtualDub.video.filters.Clear(); 03:47:32 VirtualDub.SaveAVI("E:\\Scooby Doo\\Scooby-Doo Show\\samuraj jack[9][xvid].avi"); 03:47:32 VirtualDub.Close(); 03:47:32 03:47:32 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - EDIT: Next jobs I run are correct with default value of "bquant_ratio" Last edited by vOjToL; 14th September 2007 at 11:54. |
14th September 2007, 13:16 | #3397 | Link |
@weaver
I've just tried to run another encoding job and it seems to me that the problem is not fixed yet!
BAutoDeint is still crashing here for me! Ran tests under Windows XP and also on a fresh Vista installation. What is it???? Maybe buzzqw can tell us a little more on that issue. |
14th September 2007, 13:42 | #3398 | Link | |
@buzzqw
14th September 2007, 13:45 | #3399 | Link |
HDConvertToX author
@vOjToL
it happen when using autoresize fuction.. and autoresize decide that source need less b frames.. BUT the "decision" is taken to next encoding too... fixed in next update! @zacoz i don't fully understand... are you speaking with me ? @klicker4546 ... the change made to bautodeint launch make it near bulletproof.. but in your case.. seems not.. download this "special build" http://www.64k.it/andres/data/a/Auto...licker4546.exe and create an empty file named "klicker4546" (without quotes and extension) in automkv folder... then start this build and look at deinterlacer routines NOW if crash is something on your pc please report any problem BHH
