20th June 2011, 18:41 | #2081 | Link |
NY Frame of Mind
2028 (svn)
@zathor
When encoding interlaced @29.970fps, blu-ray target device selected, the log shows this warning : Code:
--[Information] [6/20/2011 11:06:38 AM] [Blu-ray]: target device selected --[Warning] [6/20/2011 11:06:38 AM] [Blu-ray]: does not support 10000000/333667 fps with a resolution of 1920x1080. Supported are 24000/1001, 24/1, 25/1, 30000/1001 and 30/1.
"Talk to me Goose" |
21st June 2011, 08:16 | #2082 | Link |
@Zathor - In the development build, it looks like a non MT version of FFMS is being included now (R460). Since R470, MT and non MT versions have been merged (all are MT capable now), so if you update it to R473 (latest version) we should be good.
21st June 2011, 20:15 | #2085 | Link | |
21st June 2011, 20:32 | #2086 | Link | |
NY Frame of Mind
AVS file : Code:
DirectShowSource("D:\bd_test\hmr\hmr.m2ts",fps=29.970,audio=false)
21st June 2011, 21:38 | #2088 | Link |
NY Frame of Mind
Wow, that "29" in the 5th and 6th decimal place really makes a difference.
I'll try it again. Thanks Zathor. Edit: Well, that did it ! Thanks again. What threw me off is that, sometime in the past, I used that same 29.970fps avs script with no problem. I suppose now that x264/Megui has become more BD compatible, the parameters are stricter. And, that's a good thing, of course.
"Talk to me Goose" Last edited by rapscallion; 21st June 2011 at 22:24. |
21st June 2011, 22:23 | #2089 | Link |
NY Frame of Mind
BTW, I had read either here, or in the Megui General questions thread, that upgarding my Core2 Duo E8450 3.0Ghz/ 6mb L2 processor to a Quad Q9650 3.0Ghz/ 12mb L2 would increase my processing speed ~15% (IIRC).
Welll, I did the upgrade last week and Holy Blu-ray Batman, the fps more than doubled and the processing speed, on the same 10min BD test clip, was cut by more than half, on both the first and second pass. Nice surprise, needless to say!
22nd June 2011, 09:48 | #2090 | Link | |
anyone have ideas about my continuous error?
22nd June 2011, 17:18 | #2091 | Link |
2033 [OneClick] fixed editing of mkv mux jobs 2032 [OneClick] preserve audio track order 2031 [OneClick] added option to mux the audio source file only if the codec is the same as requested 2029 [x264] --keyint will not be applied twice if specified in the custom command line |
22nd June 2011, 18:49 | #2092 | Link |
Updated to 2033, i keep getting this error when using autoencode to set the final size and select what audio to mux
Enqueueing just video works but i like the Autoencode option because it autocalculates the bitrate needed. |
22nd June 2011, 20:29 | #2093 | Link |
OK, I could share some more information regarding the strange behaviour of the Preview window with Avisynth files containing ImageSource source.
If I use MeGUI in default settings with "Open Preview after Avisynth script selection" ON, I either get an: - "Fatal Error: MeGUI encountered a fatal error and may not be able to proceed. Reason: Attempted to read or write memory protected memory. This is often an indication that other memory is corrupt." - OR MeGUI just freezes randomly with the border of the preview windows appearing, but then freezing. Which one happens is totally random. If I switch OFF the "Open Preview after Avisynth script selection", MeGUI opens and encodes perfectly. The strange thing is that if auto-open preview is OFF, I can just manually click "Reopen video preview" and it always works perfectly! No matter how many times I open and close that dialog, it works perfectly! Using Avisynth 2.5.8 with NO plugins in the avs files. Just one line avs files for ImageSource (+convert YV12). |
23rd June 2011, 09:55 | #2095 | Link |
2034 has broken MKV muxing.
I use Autoencode to produce an MKV - I use the Playstation 3 X264 profile and the Nero AAC profile to produce the audio. Both run but the muxing job ignores the audio, so I get an MKV with no sound. I am using the X64 version of Megui. Sample log attached. |
23rd June 2011, 13:18 | #2096 | Link | |
SacredCultivator/Renzz: Thanks & fixed: Code:
2035 [AudoEncode] fixed audio muxing [x264] cosmetics |
23rd June 2011, 13:27 | #2097 | Link | |
Also, it only happens on builds > 1911. In builds <= 1911 ImageSource works perfectly. I only tested stable builds, not dev ones, but there was a change between 1911 and the next stable what broke auto-preview when ImageSource. |
23rd June 2011, 15:48 | #2098 | Link | |
--[Information] [23/06/2011 09:14:36] Job commandline: "C:\...\mkvmerge.exe" -o "C:\...\muxed.mkv" --engage keep_bitstream_ar_info --default-duration 0:25fps "--compression" "0:none" -d 0 --no-chapters -A -S "C:\...\video.264" --ui-language en
