19th January 2012, 13:41 | #10601 | Link |
Believe I found a litlle bug in the encoding client. If the connection times out for some reason the connect button stays disabled. In my case it was the first run of the latest encoding client and it wasn't allowed in the firewall. So the connction timed out. The connect button should be enabled after the connection timed out so you can reconnect after fixing the problem with the connection. Had to enter the ip in server 3 to be able to start the encode on the second machine.
//Trayman |
19th January 2012, 16:11 | #10602 | Link |
Added: MKV can also be used in Distributed Encoding Mode. Changed: 1 min chunks for CQ mode instead of 10 min Fixed: not working 'Shutdown when Finished' Fixed: error message in batch mode. Broken video file will be automatically discarded Fixed: EncodingClient was using Domain-Name instead of Computer-Name Fixed: Incorrect number of frames between passes in Distributed Encoding. Now number of frames in last chunk will be limited according to stat file Fixed: corruption at the begining of the chunk. (Encoding Client will first analyze video and then prepare chunks according to I-Frame (key frame) position.)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th January 2012 at 19:35. |
19th January 2012, 17:02 | #10604 | Link | |
I am also interested to see if the chunking change is a plus or minus for CQ. Seems to me that creating 120 chunks as opposed to 12 is opening up a greater chance of error, but we will see. Any chance the chunking time could be an INI change? |
19th January 2012, 17:08 | #10605 | Link | |
I found some bug (MKV in distributed encoding hangs for some files) .
19th January 2012, 17:26 | #10606 | Link | |
Also, I don't know if you know this, but there is a regression bug in x264 with trellis=2 and subme >=8 that can cause corruption. You may want to update the package with r2146. Edit: Nevermind, I see that it is packaged with r2120. Should be fine. |
19th January 2012, 19:35 | #10607 | Link |
19th January 2012, 19:43 | #10608 | Link | |
19th January 2012, 20:38 | #10609 | Link | |
20th January 2012, 02:02 | #10612 | Link |
I sort of figured as much, but I never had it do that before for so long. Also, I am getting more "Starting..." chunk hang-ups than I was getting before. I am sure it has to do with the fact there are so many more chunks in CQ mode now. Simply increases the odds of a hang-up.
20th January 2012, 04:31 | #10613 | Link |
I was ripping Leaving Las Vegas Blu-ray tonight with the new software running 1 minute chunks. Something very odd occurred with the final video. Occasionally, there are parts of the movie that have 1 or two frames from other parts of the movie put into it. Almost like it was not re-assembled correctly. I'm going to re-encode it again to see if the same thing happens.
Edit: I encoded Willy Wonka blu-ray and about every minute (or so), there is corruption for a frame or two. Last edited by Ryushin; 20th January 2012 at 07:12. |
20th January 2012, 07:35 | #10614 | Link | |
20th January 2012, 13:53 | #10617 | Link |
It looks like I have to encode subtitles (build into picture) to get the forced subtitles can anyone suggest what the best configuration would be to get the closest quality to the original video would be for BD. I want to encode the subtitles for Avatar and keep the quality as close as original, space is not an issue. Thanks
20th January 2012, 14:07 | #10618 | Link | |
20th January 2012, 14:13 | #10619 | Link |
Definitely having more problems with "Starting..." hang-ups after the CQ split change. Had an encode hang overnight when it stalled on a chunk. Basically turned what should have been a 2-3 hour encode into almost 8 hours.
20th January 2012, 15:32 | #10620 | Link |
@rc71 I had the same problem with some of my dvds. It's dgindex that generates that error. It has something to do with invalid characters in the filenames.
I used ifoedit to remove some streams and made a new ifo file. After that it ran smoothly. Don't know what it reacted to only that my tinkering solved the problem. Will take a look again at my copy of A Clockwork Orange to see if i can isolate the error. //Trayman |
