3rd December 2010, 09:20 | #8801 | Link |
I have a problem I had to go back to Windows XP and RipBot stopped working; /
I did reinstall all codecs but it did not help any suggestions? and I can`t change audio DTS -> AC3 i have still "Please wait ... Initializing" ;/ |
3rd December 2010, 09:58 | #8802 | Link |
@DB4Ever123
http://www.microsoft.com/net/download.aspx @8ternity What kind of discs did you use? DVD or BD? @extravirgin change file extension to .m2ts and let me know if this helps. Screenshot would be also very helpful (encoding settings)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd December 2010 at 10:06. |
3rd December 2010, 23:10 | #8803 | Link | |
Thanks for the reply.
Change the extension? You mean of the output file?? (n00b) |
3rd December 2010, 23:53 | #8804 | Link |
DVD 4,7GB and also DVD 8,5GB
I always use good medias such has "Ritek/Ridata DVD-R 4.7GB" "Ritek/Ridata DVD+R DL 8,5GB non printable" "Verbatim DVD+R DL 8,5GB" i was using before Memorex DVD+R DL but i've got 4 last bundle defect for verify pass; purchased before to Staples; Refunded, went to Best Buy; Samething "refunded" and also to future shop = the same! i've try to 3 LG burners = faild i've try to Sony Optic arc = faild dupplicator at work = faild Try also to my freind computer = faild i was using Memorex for last 3 years without problems, but it seems to have an problem in manufacturing!!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 4th December 2010 at 00:04. |
4th December 2010, 01:21 | #8805 | Link |
memorex doesn't make their own media. if you get the DVD+R DL that say "DVD+R DL" on the discs and package you'll get ritek/ridata discs (at least this has always been true for me)
it's when you get the ones that say "dual layer DVD+R" that you get MBI discs or something else |
4th December 2010, 07:01 | #8806 | Link | |
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
4th December 2010, 09:15 | #8807 | Link |
Change input file extension. Example video.ts rename to video.m2ts
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th December 2010 at 09:22. |
4th December 2010, 13:26 | #8808 | Link |
Hi, is there an option in the program to say encode at 50% cpu usage?
I am worried about my cpu burning out (cpu temp gets very very high) with 100% usage for hours on end. My encoding needs are not time sensitive, so I dont mind it taking twice as long to encode without high cpu temps. Anyone? |
5th December 2010, 17:05 | #8812 | Link | |
The Black Reaper
http://www.videohelp.com/tools/RipBot264 |
5th December 2010, 17:32 | #8813 | Link | |
5th December 2010, 17:39 | #8814 | Link |
New user here, un-7zip'd to its own directory on C:\Apps(x86) in Win 7 x64 ultimate.
I'm getting UAC messages "do you want to allow this program from an unknown publisher to make changes to your computer?" I'm running many open source applications and this & megui are the only ones that do this. What am I doing wrong? |
5th December 2010, 23:11 | #8815 | Link |
you're not doing anything wrong, it's just a windows security feature.
it can be disabled (UAC can be shut off, I'm not sure if that disables this as well because there are 2 diff types of messages like this)....I wouldn't recommend it unless you're a more advanced user you should be able to disable it for specific programs though. if you right click the exe and go to properties there's an 'unblock' button. this will suppress the "The publisher could not be verified. Are you sure you want to run this software?" if that doesn't get rid of the error it's a UAC only error and I never use that so I'm not sure if it has any exception options (I don't see any in the control panel, just the level it can be set to). it might have something on the popup you get |
6th December 2010, 00:41 | #8816 | Link |
I been using CQ when encoding my Blu-rays discs with RipBot. Is there a recommended setting for CQ? I noticed the file gets larger as you lower the CQ setting. For example The Godfather part II was 20GB when set at 20 for CQ, but when I redid at 22, it was 11GB. I'm certainly not expert, but I didn't notice a huge difference between the two. Though this was on my PC screen, not my big screen. I was just wondering about the pros and cons for lowering or raising the CQ settings. Thanks for any help.
6th December 2010, 01:36 | #8817 | Link |
lower cq # = higher quality
18 is commonly regarded to be transparent (indistinguishable from the source, quality wise) the setting is purely up to you. the differences will probably be negligible unless you compare like an 18 to a 24 |
6th December 2010, 18:28 | #8819 | Link |
Hi there ,
It seems that VC-1 make me troubles again Here is the error : eac3to v3.24 command line: "C:\Program Files\RipBot\Tools\eac3to\eac3to.exe" "W:\Bluray FULL\CLARKSONTHEITALIANJOB\" 1) 2: "W:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 1: "W:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="W:\temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 1 audio track, 1 subtitle track, 1:21:39, 50i 1: Chapters, 19 chapters 2: VC-1, 1080i50 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 4: Subtitle (PGS), English Creating file "W:\temp\RipBot264temp\job1\chapters.txt"... [v02] Extracting video track number 2... [v02] Muxing video to Matroska... Added fps value (25) to MKV header. Video track 2 contains 122475 frames. eac3to processing took 45 minutes, 15 seconds. Done. ---------- test : DirectShowSource: couldn't open file W:\temp\RipBot264temp\job1\video.mkv: An operation failed due to a certification failure. (W:\temp\RipBot264temp\job1\getinfo.avs, line 2) ---------- Does anyone know where is the mistake and why it gaves me such error ?? Thanks !! Last edited by benjyv; 6th December 2010 at 18:48. |
7th December 2010, 04:25 | #8820 | Link |
-zazon
yeah the director (or someone involved) made a point to add grain to the godfather movies, a retarded decision imo. 11GB to 20GB is a significant difference....but honestly you probably won't notice the difference. however, I'd be inclined to stick with the higher quality one regardless of whether you can tell the difference or not. I'm more anal about my stuff than most, though. |
