27th August 2008, 12:56 | #1342 | Link |
Mr. Sandman
@amango: no.
27th August 2008, 21:49 | #1344 | Link | |
If so and it is still not working, post an unprocessed source stream sample. |
29th August 2008, 21:29 | #1348 | Link |
Sorry, no. The changes I need to do are extensive. I'm waiting for a final version that is really fixed, because I have no way to be sure things won't change again before that happens. Michael tells me he's still fixing PAFF bugs, so we'll all just have to wait until he's finished.
In the meantime, I'm working on GPU decoding support. |
30th August 2008, 13:17 | #1350 | Link | |
1st September 2008, 01:29 | #1355 | Link |
Version 1.0.0 alpha 35
* Removed the irritating warning about decoding not starting with a reference frame when starting a
play/preview for open GOPs. Examine the DGA file if you need to know if your GOPs are open. * Added a new option in the Video menu: Copy Frame to Clipboard. * Fixed missing info log data for CLI invocation with -e. * Implemented proper relative/absolute path handling for the Load Project function. * Implemented mouse scrollwheel support for GOP and frame stepping. * Fixed missing SPS/PPS's in the DGA file when reloading a file without closing DGAVCIndex. This can also happen when reloading a different file if it has identical SPS/PPS's to the previous file. * Fixed crashing when a source file with no extension is loaded. http://neuron2.net/dgavcdec/dgavcdec.html Last edited by Guest; 1st September 2008 at 07:40. |
1st September 2008, 02:05 | #1356 | Link | |
I don't guess there is any chance you could display the current frame or time in the preview window? |
1st September 2008, 07:38 | #1357 | Link | |
BTW, re-download alpha 35 as my fix for crashing when a source file with no extension is loaded was bugged. |
1st September 2008, 09:33 | #1358 | Link |
Hello, Thank You for new version
With alpha 35 i get these warnings when open my any TS files (drag and drop file, and before i see video image): There was no such errors with previous versions. For sample i re-uploaded with_errors_LTV.ts http://www.mediafire.com/file/azxjya..._errors_LTV.ts One more thing, then i select range in DGAVCIndex an chose to Save Project and Demux Video, isn't *.dga file should use demuxed video instead TS? |
1st September 2008, 12:10 | #1359 | Link |
I am getting the first error message now, but not the second. Not sure it's related but I also am occasionally having dgavcindex when demuxing a file with AAC-HE LATM audio, stop demuxing part way through the file (the slider doesn't reach the end and there is still time to go on the counter). No other error occurs. But the output AAC file is shorter than the video length and when converted to AC3 and muxed back, the new file has no audio at the end of the file.
Can create and upload a sample if required Thanks |
