1st January 2006, 19:27 | #961 | Link |
Mr. Sandman
note: do not upload the patches to SF if they're not completed or i (or the other admins) have to reject them.
Just post screenshots or include/attach them here. Also, is it incemetal (restuctured2 goes over restructure1) or is it from scratch (restructure2 goes over the megui sources)?
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 1st January 2006 at 19:45. |
1st January 2006, 19:58 | #962 | Link |
Feature request : Could you add a date/time stamp at the start and end of logging each job? Would be useful to see how long each bit takes as I usually just set my PC to shutdown when finished and then go back looking at the logs (which incidently it seems to sometimes write two identical logs a few seconds apart, I've not figured out what scenario's it does it yet).
1st January 2006, 20:43 | #963 | Link |
Mr. Sandman
you mean in the logfiles?
1st January 2006, 22:01 | #964 | Link | ||
In future i'll just host temp builds until everyone's satisfied with the changes, then i'll post it on SF. I'll remove the two patches from SF regarding the layout changes, and i'll submit a final one later (that goes over the CVS source) when everything is double checked. |
1st January 2006, 22:04 | #965 | Link |
Mr. Sandman
i said that coz the Patch tracking is inteder for "working" or almost ready to be submitted patches
1st January 2006, 22:09 | #966 | Link | |
1st January 2006, 22:13 | #967 | Link |
Mr. Sandman
it's ok. it just creates some minor problems.
2nd January 2006, 00:05 | #968 | Link |
Heres a build if anyone wants to check out the new x264 configuration dialog layout.
Let me know of any problems. http://www.fileshack.us/files/741/Me...264-Dialog.zip |
2nd January 2006, 02:04 | #969 | Link | |
Ok, after having some problems with patching (TortoiseCVS patching requires CVS access, and with unreliable anonymous access, and disallowed developer access , this didn't eventuate), I ended up just copying the changed files into a separate folder. The changes are the same as last time, but this time, it includes the new files. Some files are no longer needed, ie both of the OneClickDefault window ones (cs and resx), and the OneClickDefaults.cs file. I've made no change to the version number as I don't know what numbering system we are following.
The changes are here on rapidshare. The code I have attached only works in .NET 2.0. If it is decided that we should stay in .NET 1.1 for the moment, then I will change the code, but for now it is too much work. The code should work if you simply copy and replace the files in my archive on top of the 1029a version Sharktooth posted. As to going with .NET 2.0, I had somehow assumed that we were already using .NET 2.0 Quote:
Changelog: -Redesigned One Click mode to have a basic and advanced tab. Added oneclick profiles, and added support for avs profiles inside oneclick. -Allowed user to select "Don't care" for the file target in both AutoEncode and OneClick, so that MeGUI will not adjust the bitrate to reach the target, but will instead use the profile's settings. This also allows the use of crf and qp in AutoEncode and OneClick. Last edited by berrinam; 2nd January 2006 at 02:07. |
2nd January 2006, 15:33 | #970 | Link |
Mr. Sandman
So the question rises again... Shall we move to .NET 2.0?
2nd January 2006, 15:51 | #971 | Link |
Well, there's no disadvantages to moving except that people will have to install the .NET2.0 package (but they'll either already have it thanks to windows update, or will have to install it soon enough anyway). Advantages include more controls and hopefully faster development due to VC# Express being a bit better, so i'd say go for it.
2nd January 2006, 15:56 | #972 | Link |
Mr. Sandman
I know what are the advantages... also the "x264 ppl" chosen .NET 2.0 too ( http://forum.doom9.org/showthread.php?t=104797 ), but the other devs should agree to move to .NET 2.0 (im all for it though).
2nd January 2006, 16:15 | #973 | Link | |
Mr. Sandman
2nd January 2006, 16:30 | #974 | Link |
Whoops, my bad. I just renamed them, created a patch and uploaded to SF. I think its pretty much finished. I havn't spotted any cut-off text. Everything seems to be placed appropriately. All the controls are still linked to their correct events (as far as i can tell). So i think its good to go.
2nd January 2006, 16:33 | #975 | Link | |
clueless n00b
2nd January 2006, 16:57 | #976 | Link |
Mr. Sandman
On my way...
2nd January 2006, 17:03 | #977 | Link |
Mr. Sandman
CVS Update: included berrinam patch. It now requires .NET 2.0 to compile.
0.2.3.1030 2 Jan 2005 Redesigned One Click mode to have a basic and advanced tab. Added oneclick profiles, and added support for avs profiles inside oneclick. Allowed user to select "Don't care" for the file target in both AutoEncode and OneClick, so that MeGUI will not adjust the bitrate to reach the target, but will instead use the profile's settings. This also allows the use of crf and qp in AutoEncode and OneClick. However snow and x264 conditional compiling is br0ken. Easy to fix but have no time to do it right now.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 2nd January 2006 at 17:06. |
2nd January 2006, 18:50 | #978 | Link | |
Ciao |
2nd January 2006, 19:54 | #979 | Link |
clueless n00b
Made my first changes. Is it possible to tell tortoise to store my password? It's not like anybody else could use this box.
Also, does anybody know how tortoise will act when I take those files to my notebook tomorrow, work in them on my way to work and back, then put them back on the PC where I have tortoise installed? And does anybody know of a good diff that tortoise could use? Last but not least, has anybody figured out how to make VS2k5 (or Express) stop complaining about GUI classes with conditional compilation statements? It's not like this warning has any useful meaning in the current context.
development, megui, not a help thread |
