10th April 2013, 20:59 | #1481 | Link |
Cheers Selur....works fine now.
Quick question with Bob. There is only a 'non-avisynth based smart Bob', but Bob AFAIK (can't remember) not listed as a standalone avisynth based bobber, just via qtgmc. 1;Any reason why no standalone avi-synth Bob listed, except from within qtgmc ? 2;I assume qtgmc calls an avisynth bobber?, or does it call the normal one ? Thanks. Sent from my Galaxy S II using tapatalk |
10th April 2013, 21:07 | #1482 | Link |
1. QTGMC itself is a bobber, but Hybrid normally automatically adds 'selectEven()' after it, to use it as a bobber simply enabled Bob in the QTGMC Settings
2. 'Yadif - custom (Avisynth)' and 'Yadifmod (Avisynth)' with mode 1 work also as bobbers -> no reason to add an additional option of named 'Bob (Avisynth)'; even the normal 'Bob'-option is not really neaded it simply calls 'Yadif' with mode 1. |
13th April 2013, 22:29 | #1484 | Link |
I think I found small issue with latest Hybrid 64bit. When you in x264 settings select hardware profile (for example I set Blu-ray AVCHD) the resize check-box turns to "grayed" state. But when I unset hardware profile, resize check-box stays in the same "grayed" state.
16th April 2013, 18:39 | #1486 | Link |
Hybrid rev 2013.04.16.1:
*changed*
-> downloads: http://www.selur.de/downloads Cu Selur |
17th April 2013, 06:53 | #1487 | Link |
Hallo. Really good program.
But maybe a bug in windows version: when creating a .avi file, all encoding processes are ok, but the final muxing process is aborted and creation is not completed. It is a known problem or maybe its a known conflict with other sw? im using win xp sp3 tks for answer Alex |
17th April 2013, 07:01 | #1488 | Link |
No, avi output should work fine, at least it does here.
-> might be a bug, but I need more infos to reproduce and fix the problem if it is caused by Hybrid (http://forum.selur.de/topic8-infos-needed-to-fixreproduce-bugs.html) Only real conflict with other software that was reported to me, from an asian user, was with a misconfigured (no clue in which way) version of "ZoneAlarm Firewall Free" which caused all sorts of problems (not only with Hybrid). So if you create a debug output and may be write a few lines (step by step guide) and send both to me, I might be able to: a. tell you what's going wrong b. fix the problem and send you a fixed version Cu Selur |
17th April 2013, 07:22 | #1489 | Link |
so i tried to encode a dvd to avi but stopped (aborted the muxing).
so i muxed the temp audio video files made by hybrid with virtualdub (it was with no problem) and just to test the hybrid muxing process i puted the avi file (called Hugo) in C root (thinking maybe too many folder trees) and tryng to create another avi file called okok in passthrough mode. no success... muxing process aborted again i used both 09.04.2013 and 16.04.2013 version here the logfile: ffmpeg started... Starting Main@08:12:07.531: "C:\Programmi\Hybrid\ffmpeg.exe" -y -threads 2 -i "C:\HUGO.avi" -vn -acodec copy "C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3" finished after 00:00:19.812 finished... Created C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3 (111.42 MB) ffmpeg started... Starting Main@08:12:27.359: "C:\Programmi\Hybrid\ffmpeg.exe" -y -i "C:\HUGO.avi" -vcodec copy -an -f avi "C:\08_12_07_5110_02.avi" finished after 00:00:35.905 finished... Created C:\08_12_07_5110_02.avi (589.01 MB) ffmpeg started... Starting Main@08:13:03.312: "C:\Programmi\Hybrid\ffmpeg.exe" -y -i "C:\08_12_07_5110_02.avi" -vtag xvid -aspect 1 -i "C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3" -vcodec copy -acodec copy -map 0:0 -map 1:0 -metadata handler_name="Hybrid 2013.04.09.1" -r 25 -f avi "C:\okok.avi" finished after 00:00:01.828 with exitCode 1 finished... C:\okok.avi was not created! Last edited by aleacido; 17th April 2013 at 07:50. |
17th April 2013, 07:31 | #1490 | Link |
"here the logfile:" <- sorry, but the log file doesn't help much, I need a debug output, see the link I posted before on how to create it.
"C:\Programmi\Hybrid\ffmpeg.exe" -y -threads 2 -i "C:\HUGO.avi" -vn -acodec copy "C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3" > Created C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3 (111.42 MB) Code:
"C:\Programmi\Hybrid\ffmpeg.exe" -y -i "C:\HUGO.avi" -vcodec copy -an -f avi "C:\08_12_07_5110_02.avi" > Created C:\08_12_07_5110_02.avi (589.01 MB) Code:
"C:\Programmi\Hybrid\ffmpeg.exe" -y -i "C:\08_12_07_5110_02.avi" -vtag xvid -aspect 1 -i "C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3" -vcodec copy -acodec copy -map 0:0 -map 1:0 -metadata handler_name="Hybrid 2013.04.09.1" -r 25 -f avi "C:\okok.avi" what happens if you call: Code:
"C:\Programmi\Hybrid\ffmpeg.exe" -y -i "C:\08_12_07_5110_02.avi" -vtag xvid -aspect 1 -i "C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3" -vcodec copy -acodec copy -map 0:0 -map 1:0 -metadata handler_name="Hybrid 2013.04.09.1" -r 25 -f avi "C:\okok.avi" -> think I found the problem (send you a test version via pm) Cu Selur Last edited by Selur; 17th April 2013 at 07:50. |
17th April 2013, 08:21 | #1493 | Link |
tried the test hibrid.exe from PM.
still having the problem i tried too with command line: the dos windows reports a vtag error (force video tag/fourcc), cannot be applied, you are trying to apply an input option to an outpout file o viveversa. error number 22 here the new debug (when approved) Hi Alex i copied the text from dos command : C:\Documents and Settings\alex>"C:\Programmi\Hybrid\ffmpeg.exe" -y -i "C:\08_12_ 07_5110_02.avi" -vtag xvid -aspect 1 -i "C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_ai d_1_08_12_07_5110_01.mp3" -vcodec copy -acodec copy -map 0:0 -map 1:0 -metadata handler_name="Hybrid 2013.04.09.1" -r 25 -f avi "C:\okok.avi" ffmpeg version N-52045-g694fa00 Copyright (c) 2000-2013 the FFmpeg developers built on Apr 12 2013 16:54:51 with gcc 4.8.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp e --enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrn b --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libr tmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheo ra --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena ble-zlib libavutil 52. 26.100 / 52. 26.100 libavcodec 55. 2.100 / 55. 2.100 libavformat 55. 2.100 / 55. 2.100 libavdevice 55. 0.100 / 55. 0.100 libavfilter 3. 53.101 / 3. 53.101 libswscale 2. 2.100 / 2. 2.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 3.100 / 52. 3.100 Input #0, avi, from 'C:\08_12_07_5110_02.avi': Metadata: encoder : Lavf55.1.100 Duration: 02:01:42.04, start: 0.000000, bitrate: 676 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv 420p, 576x320 [SAR 1:1 DAR 9:5], 25 tbr, 25 tbn, 25 tbc Option vtag (force video tag/fourcc) cannot be applied to input file C:\DOCUME~1 \alex\IMPOST~1\Temp\iId_1_aid_1_08_12_07_5110_01.mp3 -- you are trying to apply an input option to an output file or vice versa. Move this option before the fil e it belongs to. Error parsing options for input file C:\DOCUME~1\alex\IMPOST~1\Temp\iId_1_aid_1_ 08_12_07_5110_01.mp3. Error opening input files: Error number -22 occurred Last edited by aleacido; 17th April 2013 at 08:48. |
17th April 2013, 08:27 | #1494 | Link | |
17th April 2013, 09:23 | #1495 | Link | ||
@aleacido:
---- the problem from the command line should have been fixed with the build I uploaded,... Cu Selur |
17th April 2013, 23:52 | #1496 | Link |
Thanks Selur, perfect fix of avi mux problem with your afternoon upgrade-fix. So so so many Thanks for you excellent (and free) job.
Your sw is more useful than hundreds of payware, and quality encoding is better than many other encodind sw. Hi Alex PS, sorry for debug files came late, i posted it in same time of message, but moderator approval request a little bit of time. Last edited by aleacido; 17th April 2013 at 23:55. |
18th April 2013, 19:05 | #1498 | Link |
Hi (im hammering ?, hope not ).
Just some little thinking about Hybrid. - The up and down arrows in all hybrid windows does not work with holding mouse button (no continuos data change on press holding), it works with arrows key on keyboard. A little annoying when needed a great change of data (eg: theorically, change bitrate from 1500 to 750 kbs needs to press mouse button 750 times...). -in resizing window the resolution divided for mod (1, 2, 4, 8, 16, 32) affects only the other dimension. Could be useful an option for both sizes divided for choosen fixed divider (maybe a new scrolling option: eight, width, both). just small things, but maybe useful. And now, im asking a miracle. Gordianknot had a soso useful function , a size and bitrate calculator based on quality factor, not just a bitrate mathematical calculation, GK makes a small test based on 5 -10 % of movie, to find the best quality ratefactor, based on bitrate, size and video complexity.I know could be difficult, but try to insert somethink like that? Thanks for your attention Alex Last edited by aleacido; 18th April 2013 at 19:10. |
18th April 2013, 19:23 | #1499 | Link | |||
I'm not totally sure if you want to change the stepping: up/down changes X by Y or if you want Hybrid to only allow values which are mod Y. Last edited by Selur; 18th April 2013 at 19:28. |
18th April 2013, 19:46 | #1500 | Link |
perfect answer!
The only thing is: i remember many codec works better with resolution multiple of 16 or 32 modulator (less interpolation, so better quality and better compatibility with standalone players), maybe i'm lazy but i have to calculate by my mind (not ever well working) the x or y size eg multiple of 16 (the other size in automatically calculated by hybrid). both dimension changed automatically step by step based on mod could be just an easier way to resize. But if dont, thanks to let my mind alive, obliged to remember how work simple calculation processes . Hi Alex Edit: sorry, my mistake, is just easy way with hybrid to change from x to y to have both divided for mod. Last edited by aleacido; 18th April 2013 at 19:58. Reason: sorry, im getting old and stupid |
