21st September 2008, 14:52 | #6301 | Link |
I'm Intresting to convert TrueHD and DTS-MA to PCM
If using eac3to input.thd output.thd Is that the correct way to get a prober MultiChanel PCM ? or do I have missed something in the command line ? I dont want to get a bad track, Doing this do I got a better soundtrack or should I stay with the original ones ? So what would the best command be to convert to PCM ? Have a nice day ALL Results [a03] Extracting audio track number 3... [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with libav/ffmpeg... [a03] Swapping endian... [a03] Creating file "l:\Soundoutput.24bit.pcm"... [a03] This audio track contains more than 16 bits of information. Is it not possible to get a 24bit PCM Is a lot of questions and I hope some one can give me a short Answer :-) EDIT One example.... look at the command, to be a good output do I need more commands ? L:\BT\bd-tg\BDMV\STREAM>eac3to 1) M2TS, 1 video track, 5 audio tracks, 8 subtitle tracks, 2:57:09 1: Chapters, 23 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB 4: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 5: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 6: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 7: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 8: Subtitle (PGS), English 9: Subtitle (PGS), English 10: Subtitle (PGS), French 11: Subtitle (PGS), Spanish 12: Subtitle (PGS), Portuguese 13: Subtitle (PGS), English 14: Subtitle (PGS), French 15: Subtitle (PGS), Spanish L:\BT\bd-tg\BDMV\STREAM>eac3to 1) 3: output.pcm It gives me this info ... Is this right ?? [a03] Extracting audio track number 3... [a03] Extracting TrueHD stream... [a03] Removing TrueHD dialog normalization... [a03] Decoding with libav/ffmpeg... [a03] Swapping endian... [a03] Creating file "l:\Soundoutput.24bit.pcm"... [a03] This audio track contains more than 16 bits of information. Last edited by piratburner; 21st September 2008 at 15:01. Reason: Output |
21st September 2008, 16:05 | #6303 | Link | |
And a request for eac3to, if I may. Can we get something like .ini file, so we can specify a few paths to nero aac encoder and mkvtoolnix? First one I have to move into the folder every time I update eac3to, and I don't use installer for the second, so it's "unavailable".
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 Last edited by lexor; 21st September 2008 at 16:13. |
21st September 2008, 16:41 | #6304 | Link | |
21st September 2008, 16:58 | #6305 | Link | |
Sorry, but I don't want to add an ini file right now. IIRC you can copy the NeroAAC exe to the system32 folder. And mkvtoolnix is not used by eac3to at all. eac3to just checks whether there's a new version available, that's it. So it's not a big loss if eac3to doesn't find mkvtoolnix. |
21st September 2008, 19:58 | #6306 | Link | |||
-no7doubling parameter. or let the doubling optional using the active parameter -double7 |
21st September 2008, 20:13 | #6307 | Link | |
I as able to rule them out because I never got to those steps. I only ever used eac3to. However, it doesn't really matter because...
So it seems that you were correct about GraphStudio, I was not able to get raw PCM to play back correctly on my PC, but the PS3 can handle it fine. I apologize for the confusion though, I wasn't exactly blaming eac3to. The main point of my previous post was just to show that the problem was not with pcm2tsmu or tsmuxer. But as it turns out, it wasn't eac3to either, just my PC. I also want to thank you for the development of eac3to, it is definitely the best software of its kind! Lastly, does anyone know how I can play back raw PCM files on my PC? If anyone wishes to respond, you're welcome to PM me, as I know this subject isn't on topic. Thanks! |
21st September 2008, 20:44 | #6308 | Link | |
Any other suggestions? Do you agree that $603 is the proper value? As you can see here:
http://msdn.microsoft.com/en-us/library/aa474707.aspx Microsoft wants 5.1 by default to map to "FL, FR, FC, LFE, SL, SR". And IMHO that's the correct mapping. Do you disagree? I guess that there might be some trouble. Maybe some applications will complain because they expect $3f. But should I output a wrong mask just because some apps expect a wrong value? I don't like to behave like that... Quote:
The idea of the "pcm" output is to produce a Blu-Ray compatible PCM stream, similar to what e.g. xport demuxes. But the Blu-Ray spec clearly doesn't allow a 6.1 channel configuration for PCM. So what sense does it make to offer a 6.1 PCM output option? |
21st September 2008, 20:46 | #6309 | Link | |
http://xkodi.svobodno.com/SpkrConfig5.rar currently, the only valid channel mask for 5.1 channels is 0x3f. |
21st September 2008, 21:10 | #6310 | Link | |
"In Windows XP with SP2 and Windows Server 2003 with SP1, if the system mixer produces a 5.1-channel output stream, the mixer always sets the stream's channel mask to 0x3F. The system mixer behaves this way even if it receives a 5.1-channel input stream with a channel mask of 0x60F." So clearly the system mixer supports receiving a 0x60f channel mask. Fortunately the document contains a Microsoft email address for questions about this topic. I'll write to that address and ask for clarification - also about 6.1. |
21st September 2008, 21:17 | #6311 | Link |
For re-encoding to dts/ac3? But then I think I'd rather have 5.1 option, since people who don't have receivers to accept a lossless 7.1 probably also don't have 7.1 or 6.1 speakers.
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 |
21st September 2008, 21:21 | #6312 | Link | ||
21st September 2008, 21:35 | #6313 | Link | ||
Why would you ask eac3to to export to PCM if you want to reencode to DTS/AC3? That doesn't make much sense to me. If you want to reencode to DTS/AC3, you should either ask eac3to to do that directly for you. Or alternatively you could ask eac3to to output to WAV or AGM and then use an external AC3/DTS encoder. I'm not aware of any DTS/AC3 encoder which would accept a Blu-Ray style PCM file with the Blu-Ray channel ordering and handle that correctly. |
21st September 2008, 21:42 | #6314 | Link | |
21st September 2008, 22:25 | #6315 | Link |
It seems that last version of EAC3TO has broken DTS encoding with surcode. I get the following:
C:\EAC3TO>eac3to "f:\dir" 1) 2: d:\file.mkv 4: d:\file.dts 5: d:\file.ac3 -keepdialnorm Code:
... [a04] Extracting audio track number 4... [v02] Extracting video track number 2... [a05] Extracting audio track number 5... [a04] Extracting TrueHD stream... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] Writing WAVs... [v02] Muxing video to Matroska... [a04] Creating file "d:\file.L.wav"... [a04] Creating file "d:\file.R.wav"... [a04] Creating file "d:\file.LFE.wav"... [a04] Creating file "d:\file.BR.wav"... [a04] Creating file "d:\file.BL.wav"... [a04] Creating file "d:\file.C.wav"... [a05] Creating file "d:\file.ac3"... [libav] End of stream indicated [a04] This audio track has a constant bit depth of 16 bits. Encoding DTS <1536kbps> with Surcode... Found Surcode DTS Encoder version 1.0.23.0. Surcode says/asks: "Invalid Wave File d:\file.SL.wav.". Surcode says/asks: "Invalid Wave File d:\file.SR.wav.". Surcode says/asks: "Source file sample rates differ from encoding sample rate. Cannot encode.". Pressing the Surcode "Encode" button didn't seem to work... Closing Surcode... |
21st September 2008, 23:24 | #6317 | Link | ||||
The Surround channels (110-120º) aren't the Side (90º) or Back (150º) channels, also $603 is wrong. Quote:
FL-FR-FC (LF) BL-BR-BC. Isn't a name question is the channel order here Quote:
21st September 2008, 23:32 | #6318 | Link |
Hi guys, thanks for all those technical discussions since they will make SW better but as far as i remember somebody suggested some time ago opening a new thread on developing eac3to?
22nd September 2008, 01:58 | #6319 | Link |
Is anybody who knows making it in a more practical way ?
F:\>eac3to\eac3to.exe 00000.m2ts+00001.m2ts+00002.m2ts+00006.m2ts+00007.m2ts+00008.m2ts+00009.m2ts+00010.m2ts+00011.m2ts+00012.m2ts+00013.m2ts+00014.m2ts+00015.m2ts+00016.m2ts +00017.m2ts+00018.m2ts+00019.m2ts+00020.m2ts+00021.m2ts+00022.m2ts+00024.m2ts+00025.m2ts+00026.m2ts+00027.m2ts+00028.m2ts+00032.m2ts+00033.m2ts+00034.m2ts+00036.m2ts+00037.m2ts +00038.m2ts+00039.m2ts+00040.m2ts+00041.m2ts+00042.m2ts+00043.m2ts+00044.m2ts+00045.m2ts+00046.m2ts+00047.m2ts 1: E:\output\video.h264 2: E:\output\audiothd.thd+ac3 3: E:\output\audiodts.dtshd 4: E:\output\subtitle_en.sup 23: E:\output\subtitle_tr.sup M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:39:54 1: h264/AVC, 1080p24 /1.001 (16:9) 2: TrueHD/AC3, 5.1 channels, 48khz 3: DTS Master Audio, 5.1 channels, 24 bits, 48khz 4: Subtitle (PGS) ******** 23: Subtitle (PGS) [v01] Extracting video track number 1... [a02] Extracting audio track number 2... [a03] Extracting audio track number 3... [s04] Extracting subtitle track number 4... [s23] Extracting subtitle track number 23... [v01] Creating file "E:\output\video.h264"... [a03] Creating file "E:\output\audiodts.dtshd"... [a02] Creating file "E:\output\audiothd.thd+ac3"... [s04] Creating file "E:\output\subtitle_en.sup"... [s23] Creating file "E:\output\subtitle_tr.sup"... ------------------------------------- |
22nd September 2008, 02:26 | #6320 | Link | |
The rest of the log; what should i do now?
Please don't tell me this: Quote:
[v01] Extracting video track number 1... [a02] Extracting audio track number 2... [a03] Extracting audio track number 3... [s04] Extracting subtitle track number 4... [s23] Extracting subtitle track number 23... [v01] Creating file "E:\output\video.h264"... [a03] Creating file "E:\output\audiodts.dtshd"... [a02] Creating file "E:\output\audiothd.thd+ac3"... [s04] Creating file "E:\output\subtitle_en.sup"... [s23] Creating file "E:\output\subtitle_tr.sup"... [a02] Audio overlaps for 5ms at playtime 0:46:24. [a02] Audio overlaps for 5ms at playtime 1:28:23. [a02] Audio overlaps for 5ms at playtime 2:33:42. [a02] The audio gaps/overlaps technically can't be removed from the TrueHD bitstream. [a02] In order to remove them you'll have to transcode the audio to another format. [a03] Audio overlaps for 12ms at playtime 0:17:55. [a03] Audio overlaps for 6ms at playtime 0:26:28. [a03] Audio overlaps for 10ms at playtime 0:28:43. [a03] Audio overlaps for 6ms at playtime 0:31:42. [a03] Audio overlaps for 8ms at playtime 0:32:19. [a03] Audio overlaps for 13ms at playtime 0:37:23. [a03] Audio overlaps for 10ms at playtime 0:38:37. [a03] Audio overlaps for 6ms at playtime 0:42:03. [a03] Audio overlaps for 6ms at playtime 0:45:20. [a03] Audio overlaps for 7ms at playtime 0:50:38. [a03] Audio overlaps for 7ms at playtime 0:54:43. [a03] Audio overlaps for 13ms at playtime 0:58:37. [a03] Audio overlaps for 11ms at playtime 1:04:12. [a03] Audio overlaps for 9ms at playtime 1:17:40. [a03] Audio overlaps for 12ms at playtime 1:26:10. [a03] Audio overlaps for 7ms at playtime 1:32:06. [a03] Audio overlaps for 10ms at playtime 1:34:01. [a03] Audio overlaps for 7ms at playtime 1:35:03. [a03] Audio overlaps for 6ms at playtime 1:36:00. [a03] Audio overlaps for 6ms at playtime 1:40:20. [a03] Audio overlaps for 10ms at playtime 1:43:08. [a03] Audio overlaps for 9ms at playtime 1:55:53. [a03] Audio overlaps for 7ms at playtime 1:56:38. [a03] Audio overlaps for 9ms at playtime 1:57:12. [a03] Audio overlaps for 10ms at playtime 2:33:42. [a03] The audio file was demuxed without making use of the gap/overlap information. [a03] Please rerun the same eac3to command line. That will correct the gaps/overlaps. Video track 1 contains 230070 frames. eac3to processing took 3 hours, 13 minutes. Done. _ _ _ __ Last edited by rica; 22nd September 2008 at 02:49. |
eac3to |
