Old 7th May 2007, 20:57   #1  |  Link
Trahald
Wewkiee
Trahald's Avatar
x264 w/ 3:2 pulldown and hrd
I put up on my sourceforge page a binary of x264 (its the 04272007 checkout w/ hrdpatch 616 applied and then i coded pulldown support over it) i will post a .patch file later (patch will only include my changes) so would be checkout + hrdpatch + pulldownpatch
its on https://sourceforge.net/projects/batchccews/ h264info package. only place i could think of to put it for now. the command line is --pulldown 32. (with the space) .. its doc'd in --longhelp . it adds tbt bt btb tb pattern, to only be used with 1080p 23.976 source. i havent tested it much tho but passes testing so far.
Newest version x264_669i_pulldown.zip (aq / mp4 / threads / hrd_pulldown compiled in cygwin)
**Note: use min-keyint 4 (or more) and do not use b-pyramid for hddvd.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 8th May 2007, 02:41   #2  |  Link
Thanks, Trahald! That will help me to get my decoding right by enabling me to create test streams.
Old 8th May 2007, 20:39   #3  |  Link
Pitou
Could anyone point me to a thread or post a command example, for x264, to encode a 1080p 23.976 with pulldown, for it to be imported in Scenarist and be HD-DVD compliant ?
Pitou!
Pitou is offline   Reply With Quote
Old 9th May 2007, 00:59   #4  |  Link
giandrea
Pitou!
Would you use pulldown to uprate it to 30 fps? Isn't the point of HD DVD and BR that they support the 24 fps framerate? Isn't it better to just encode it at the original framerate or isn't it supported by the standard?
giandrea is offline   Reply With Quote
Old 9th May 2007, 11:52   #5  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Pitou!
@REM >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
@REM >> first pass
x264.exe --keyint 14 --min-keyint 1 --vbv-maxrate 28000 --vbv-init 1.0 --vbv-bufsize 14745 --mvrange 511 --level 4.1 --nal-hrd --pulldown 32 --bframe 2 --bime --weightb --ref 1 --mixed-refs --direct auto --deblock -2:-2 --bitrate 7000 --pass 1 --stats "x264_stat.log" --qcomp 0.75 --ipratio 1.10 --pbratio 1.10 --partitions "all" --8x8dct --me "hex" --subme 5 --aud --sar 1:1 --cqmfile Sagittaire.cfg --deadzone-intra 6 --deadzone-inter 6 --progress -o test_1_75.h264 Riddick.avs
@REM >> second pass
x264.exe --keyint 14 --min-keyint 1 --vbv-maxrate 28000 --vbv-init 1.0 --vbv-bufsize 14745 --mvrange 511 --level 4.1 --nal-hrd --pulldown 32 --bframe 2 --b-rdo --bime --weightb --ref 3 --mixed-refs --direct auto --deblock -2:-2 --bitrate 7000 --pass 3 --stats "x264_stat.log" --qcomp 0.75 --ipratio 1.10 --pbratio 1.10 --partitions "all" --8x8dct --me "hex" --subme 6 --no-fast-pskip --no-dct-decimate --trellis 1 --aud --sar 1:1 --cqmfile Sagittaire.cfg --deadzone-intra 6 --deadzone-inter 6 --progress -o test_2_75.h264 Riddick.avs
Source must be 1920*1080*23.976
For HDDVD NTSC you must use 1920*1080*29.97 encoding. 1080i29.970 can be 1080p23.976 progressive encoding with pulldown flag.
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Old 9th May 2007, 13:49   #6  |  Link
Pitou
Sagittaire,
Thanks that's what I needed. This is for NTSC 1080p 23.976 source, right?
Also, x264 doesn't seem to put the end of sequence code and when importing to Scenarist, it crashes. Any idea?
Another question, what combination of graph/decoder you're using?
I tried:
file.vc1 --> Sonic HD demuxer --> Sonic video decoder 4.2
and:
file.evo (Haali media splitter) --> WMV9 Advance decoder DMO
and:
file.evo (Haali media splitter) --> ffdshow video decoder
and my avs script:
DirectShowSource("C:\HDDVD\para.grf",fps=23.976,framecount=312,audio=false)
Which one is best?
One last thing, is it possible for you to post your cqmfile Sagittaire.cfg?
Again, Thank you very much for help!
Pitou!
Old 9th May 2007, 16:33   #7  |  Link
Trahald
Wewkiee
Trahald's Avatar
yep
I can possibly add a sequence end code flag , although lack of sequence end code is only a warning for scenarist and should not cause it to crash.
Old 9th May 2007, 16:40   #8  |  Link
Pitou
Yes I thought so, since you wrote h264info and the x264 pulldown patch... thanks btw!
Not sure why scenarist crash, but when encoding with "your" x264 HRD and then passing the result file through H264info to apply pulldown, Scenarist doesn't complain anymore.
So, as you wish, maybe I can reinstall scenarist or if you add the end code, I can test it...
Thanks!
Pitou!
Old 9th May 2007, 18:14   #9  |  Link
Trahald
Wewkiee
Trahald's Avatar
can you provide me a small sample that still crashes scenarist ? are you using hte same settings as Sagittaire? i couldnt reproduce the problem
Old 9th May 2007, 20:17   #10  |  Link
Pitou
Finally, it did import it with the warning (normal), but it didn't crash...
Maybe my encoding was bad...
I did test with the latest command line Sag just posted and it seems fine.
Thanks!
Pitou!
Old 10th May 2007, 02:52   #11  |  Link
Pitou
Now Scenarist complain that my video is shorter than my DD+ audio track.
The error is:
"Warning Multiplex is terminated at 00:00:12:22, but expecting end time is 00:00:12:24. Please check video data file or track "para-t".
Video=00:00:12:24
Audio=00:00:12:29
Any idea?
Pitou!
Old 10th May 2007, 06:38   #12  |  Link
Trahald
Wewkiee
Trahald's Avatar
i think i see the issue.. should have a fix out in a day or 2
Old 10th May 2007, 15:07   #13  |  Link
Pitou
Wow, great!
Do you think Dolby TrueHD will work as well?
Old 10th May 2007, 22:28   #14  |  Link
Trahald
Wewkiee
Trahald's Avatar
ok.. give 616b a shot
Old 11th May 2007, 15:37   #15  |  Link
Trahald
Wewkiee
Trahald's Avatar
ok.. let me know.. if you can.. gimmie a sample i can replicate the issue with. ive tried different settings and havent been able to duplicate a crash
Old 18th May 2007, 15:37   #16  |  Link
Toti
I am getting a mux error with Scenarist. I first encode the video at 23.976 fps then apply the pulldown with h264info and the resulting video gets accepted but when is creating the HD-DVD it give me the error.
The funny thing is that it works with small video of 1min. This one hour and thirty mins gives me the error.
I tried Alpha 007 & 006. Any suggestions?
VAIO VGX-XL3 4gig RAM, 4Tb HDD. MEDIA CENTER WINDOWS 7 simply the best!!
Toti is offline   Reply With Quote
Old 18th May 2007, 16:17   #17  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
You use Mainconcept/Elecard H264 stream ... ???
Old 18th May 2007, 19:40   #18  |  Link
Trahald
Wewkiee
Trahald's Avatar
if you used x264, i would make sure you use 12 frames between idrs.. using history and cinevision (which defaults to 12 frames for pulldown) .. at what clock time is your first chapter break.. also.. either way, can you make a peice available?
Old 18th May 2007, 22:23   #19  |  Link
Toti
Yes, I am using MainConcept 2.1.0 please note that if I encode a few minutes the pulldown works. If however, I encode the complete movie then it gives me this error. The movie I was encoding is Winged Migration.
Old 19th May 2007, 09:32   #20  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
H264info don't work correctly with mainconcept/elecard stream because duration for AVC stream will be not good with pulldown flag (audio/video desynchro with scenarist). You must use x264 and anything else.
