Old 9th March 2020, 13:01   #18401  |  Link
Ex0nuss
Hi Guys ,
I am new to this forum and loving Ripbot264.
This is why I have a question, regarding batch encoding with tonemapping:
I would like to use a Computer as a transcoding-machine. After activating "Batch-encoding" with a watch-folder, I also activated tonemapping. I transcode both, HDR- and SDR-content.
Now I am wondering if Ripbot264 automatically detects if tonemapping is required?
My second question is, if I can start up Ripbot264 at Windows-startup with Batch-encoding automatically activated?
Thank you in advance for you help
Ex0nuss is offline   Reply With Quote
Old 9th March 2020, 14:37   #18402  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
yes.
Old 9th March 2020, 16:03   #18403  |  Link
byteshare
ByteShare
byteshare's Avatar
Anyone know what changed in core 2020.03.01?
Old 10th March 2020, 06:47   #18404  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Only 1 person.....
Not poorly done, just doin' it my way !!!
Pauly Dunne is offline   Reply With Quote
Old 14th March 2020, 14:58   #18405  |  Link
activoice
Previously I was running an i7 920 and while encoding to X265 10bit with Ripbot it would use 100% of my CPU...
But on my Ryzen 7 3700x it's only using between 65 and 80% of my CPU... The source and destination drive are an NVME drive that only shows about 5% utilization, I've got 16gb of ram of which less than 8gb is being used, and the Ram is running at 2400 Mhz so I don't think the memory is a bottleneck. So if it's not the Memory or the Disk that's a bottleneck... maybe it's some setting in the profile that I'm using?
This is the profile that I'm using when encoding to X265 with a CQ of 20
--profile main10 --output-depth 10 --ssim --min-keyint 23 --keyint 250 --bframes 8 --rc-lookahead 80 --ctu 64 --no-strong-intra-smoothing --me 3 --subme 5 --merange 57 --no-rskip --aq-mode 3 --aq-strength 0.8 --analysis-reuse-level 5
activoice is offline   Reply With Quote
Old 14th March 2020, 15:25   #18406  |  Link
slalom
slalom's Avatar
Something to do with NUMA mode, is your CPU compatible?
i7 3930K @ 4.2GHz on GA-X79-UD3 16GB DDR3
i5-750 @ 3.36GHz 8GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 14th March 2020, 15:38   #18407  |  Link
byteshare
ByteShare
byteshare's Avatar
I've had similar issues. I just need to add another server with DE.
Old 14th March 2020, 18:11   #18408  |  Link
activoice
So click on Additional Server?
From what I recall when I press this button it defaults to a list of the cores and a checkmark next to each one.. Do I leave the default or am I supposed to select some of the cores but not all?
Old 14th March 2020, 18:58   #18409  |  Link
slalom
slalom's Avatar
Just press activate and enter the new address x.x.x.x:2000 in settings, DE tab
NUMA node is only 0?
Old 17th March 2020, 21:40   #18410  |  Link
GZZ
Ripbot still have issue setting language on Greek subtitles. Using newest version, all updated.
File: job25_MuxFiles.cmd
"E:\RipBot264v\tools\mkvtoolnix\mkvmerge.exe" -o "E:\Encoding\YYY.mkv" --compression 0:none --title "YYY" --default-duration 0:24000/1001fps "E:\Temp\RipBot264temp\job25\video.265" --compression 0:none --language 0:eng --sync 0:0 "E:\Temp\RipBot264temp\job25\1_audio_English_DEFAULT.dtsma" --default-track 0:yes
--language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job25\2_subtitles_English_DEFAULT.sup" --default-track 0:no --language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job25\3_subtitles_English.sup" --default-track 0:no
--language 0:eng -s 0 -D -A "E:\Temp\RipBot264temp\job25\4_subtitles_English.sup" --default-track 0:no --language 0:ara -s 0 -D -A "E:\Temp\RipBot264temp\job25\5_subtitles_Arabic.sup" --default-track 0:no
--language 0:bul -s 0 -D -A "E:\Temp\RipBot264temp\job25\6_subtitles_Bulgarian.sup" --default-track 0:no --language 0:hrv -s 0 -D -A "E:\Temp\RipBot264temp\job25\7_subtitles_Croatian.sup" --default-track 0:no
--language 0:cze -s 0 -D -A "E:\Temp\RipBot264temp\job25\8_subtitles_Czech.sup" --default-track 0:no --language 0:fre -s 0 -D -A "E:\Temp\RipBot264temp\job25\9_subtitles_French.sup" --default-track 0:no
--language 0:und -s 0 -D -A "E:\Temp\RipBot264temp\job25\10_subtitles_Greek.sup" --default-track 0:no --language 0:heb -s 0 -D -A "E:\Temp\RipBot264temp\job25\11_subtitles_Hebrew.sup" --default-track 0:no
--language 0:hun -s 0 -D -A "E:\Temp\RipBot264temp\job25\12_subtitles_Hungarian.sup" --default-track 0:no --language 0:ice -s 0 -D -A "E:\Temp\RipBot264temp\job25\13_subtitles_Icelandic.sup" --default-track 0:no
--language 0:kor -s 0 -D -A "E:\Temp\RipBot264temp\job25\14_subtitles_Korean.sup" --default-track 0:no --language 0ol -s 0 -D -A "E:\Temp\RipBot264temp\job25\15_subtitles_Polish.sup" --default-track 0:no
--language 0or -s 0 -D -A "E:\Temp\RipBot264temp\job25\16_subtitles_Portuguese.sup" --default-track 0:no --language 0:rum -s 0 -D -A "E:\Temp\RipBot264temp\job25\17_subtitles_Romanian; Moldavian; Moldovan.sup" --default-track 0:no
--language 0:srp -s 0 -D -A "E:\Temp\RipBot264temp\job25\18_subtitles_Serbian.sup" --default-track 0:no --language 0:slo -s 0 -D -A "E:\Temp\RipBot264temp\job25\19_subtitles_Slovak.sup" --default-track 0:no
--language 0:slv -s 0 -D -A "E:\Temp\RipBot264temp\job25\20_subtitles_Slovenian.sup" --default-track 0:no --language 0:spa -s 0 -D -A "E:\Temp\RipBot264temp\job25\21_subtitles_Spanish; Castilian.sup" --default-track 0:no
--language 0:tur -s 0 -D -A "E:\Temp\RipBot264temp\job25\22_subtitles_Turkish.sup" --default-track 0:no --language 0:fre -s 0 -D -A "E:\Temp\RipBot264temp\job25\23_subtitles_French.sup" --default-track 0:no
--language 0:hin -s 0 -D -A "E:\Temp\RipBot264temp\job25\24_subtitles_Hindi.sup" --chapters "E:\Temp\RipBot264temp\job25\chapters.txt"
File: Subtitle.txt
2_subtitles_English_DEFAULT.sup=eng
3_subtitles_English.sup=eng
4_subtitles_English.sup=eng
5_subtitles_Arabic.sup=ara
6_subtitles_Bulgarian.sup=bul
7_subtitles_Croatian.sup=hrv
8_subtitles_Czech.sup=cze
9_subtitles_French.sup=fre
10_subtitles_Greek.sup=und
11_subtitles_Hebrew.sup=heb
12_subtitles_Hungarian.sup=hun
13_subtitles_Icelandic.sup=ice
14_subtitles_Korean.sup=kor
15_subtitles_Polish.sup=pol
16_subtitles_Portuguese.sup=por
17_subtitles_Romanian; Moldavian; Moldovan.sup=rum
18_subtitles_Serbian.sup=srp
19_subtitles_Slovak.sup=slo
20_subtitles_Slovenian.sup=slv
21_subtitles_Spanish; Castilian.sup=spa
22_subtitles_Turkish.sup=tur
23_subtitles_French.sup=fre
24_subtitles_Hindi.sup=hin
If I open the video.mkv file, greek is correct and also correct in input file. So along the path in Ripbot it fails to set it properly in output file.
MkvInfo.txt also detect Greek correct for subtitle.
GZZ is offline   Reply With Quote
Old 30th March 2020, 22:58   #18411  |  Link
Balthazar2k4
Just built a new 3970x system and am trying to get a handle on distributed encoding again. I generally haven't had issues in the past, but this is the first time I've broke out RipBot264 in a couple years. I am trying to saturate the system by setting up multiple clients on the host machine. Unfortunately, all of my local clients are showing offline and will not connect. What am I missing here?
Balthazar2k4 is offline   Reply With Quote
Old 31st March 2020, 11:29   #18412  |  Link
Pauly Dunne
Grumpy Old Man.
Gee's, I'm jealous...I have bought some bits & pieces to build a reasonable 3950X system.....
So, are you using DE on a single computer, or do you have a couple of other pc's to join in ??
It's VERY dependant on matching IP address's, and appropriate port address, otherwise it won't "talk to itself".
Might need to do a bit of trial & error, to jog your memory.
I'm even a little rusty as I haven't used RipBot for a couple of months, been way too busy sorting out 1,000's of old & corrupted movies.
Old 31st March 2020, 12:43   #18413  |  Link
slalom
slalom's Avatar
Encoding server keeps freezing randomly even when no-one is doing anything. Only at the i5-750
Old 31st March 2020, 13:44   #18414  |  Link
Pauly Dunne
Grumpy Old Man.
Strange behaviour....
Did this just start, as there was an auto update a couple of days back.
Latest core version 2020/03/29, but there was no update for Encoding Server or Client.
MKVToolNix v44.0
Old 31st March 2020, 15:31   #18415  |  Link
Balthazar2k4
Just working on the one machine. A single instance doesn't come close to saturating the threads so I was hoping to run multiple instances locally to make that happen. I did it before years ago when I had my 1950x, but I think I killed those brain cells since.
Old 31st March 2020, 19:11   #18416  |  Link
slalom
slalom's Avatar
MKVToolNix v44.0
That's for about the past six months
Old 31st March 2020, 19:59   #18417  |  Link
Pauly Dunne
Grumpy Old Man.
Might need to do a fresh Windows setup....
Old 31st March 2020, 20:05   #18418  |  Link
Pauly Dunne
Grumpy Old Man.
A 3970X costs around $3,800 in Australia...WAY out of my budget, I'm hoping the 3950X is REALLY good for Ripbot.
So if your using only 1 pc, you might try using this series of IP/port address's, with DE enabled (of course)
ServerIP1=127.0.0.1:1000
ServerIP2=127.0.0.1:2000
ServerIP3=127.0.0.1:3000
ServerIP4=127.0.0.1:4000
etc, until you get that beast anywhere near saturated.
Hope this helps
Old 31st March 2020, 23:05   #18419  |  Link
slalom
slalom's Avatar
Fresh setup goes with fresh hardware
Old 1st April 2020, 00:43   #18420  |  Link
Pauly Dunne
Grumpy Old Man.
Not sure if you're hinting that it might be time to do a bit of a system upgrade...
I have a 3930K OC'ed to about the same as your sig, and it does basic encodes reasonably fast, I'd say that the i5 would be slower.
They are no match at all, with what you can buy these days..NO comparison
