27th April 2009, 07:50 | #641 | Link | ||
I don't know why he's done it that way. Of course if YUY2 or even RGB is sent to the renderer, the renderer has to do less work - but then the CPU has to do more work. The purpose of madVR is to do everything in best possible quality. So madVR does not let decoders do YV12 -> YUY2 upsampling, because all decoders I know are doing this is inferior quality compared to madVR. |
27th April 2009, 08:29 | #643 | Link | |
27th April 2009, 18:56 | #647 | Link |
Hi, Ran a Test DVD today to check some recent changes to ffdshow, but noticed some badish banding on the gradient test (probably my TV causing alot of this) but wanted to try madVR.
Surprised the "macrovision failed" error still occurs in the latest version. this stopped me using haali for playing back all of my ripped DVD's also... did you get a chance to look into this error madshi? When i ripped these DVD's I removed all protection's and using AnyDVD doesn't have any effect on it.. |
27th April 2009, 21:31 | #648 | Link | |
And MadVR resizes in YCbCr colorspace if I get your algorithm correctly. Performance is the problem? What do you think about that? Thanks! |
28th April 2009, 07:14 | #652 | Link |
I think madshi already said in this very thread that screeshot is middle priority feature, so you'll have to wait. As a renderer, I don't think it has control over MPC-HC (or other players for that matter) to enable/disable taking screenshot feature either.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
28th April 2009, 09:03 | #653 | Link | |
28th April 2009, 10:29 | #654 | Link | |
Hi-Fi Fans
But about the step button is invalid, that's a real problem. |
28th April 2009, 16:29 | #655 | Link | |
You have 2 samples/pixels with values [0, 100] and you want to find the samples between them. The result should be a linear gradiant. In linear light the sample will be (assuming Gamma of 2 for simplicity): [0, 100^2] == [0, 10000] Let's resample the value exactly between 0 and 100 or 0 and 10000. In gamma corrected space the value will be 50 and in linear space it will be 5000 which is ~71 in gamma corrected space. The result will not appear linear at all. |
28th April 2009, 16:59 | #656 | Link | |||
Both problems are already known. Quote:
Performance is the problem with what? With the current algorithm? It doesn't matter much in which colorspace I scale, the scaling performance is the same. However, converting between different colorspaces costs performance. |
28th April 2009, 17:03 | #657 | Link | ||
http://www.avsforum.com/avs-vb/showt...8#post16313488 Here's an extract: Quote:
28th April 2009, 17:25 | #658 | Link |
_
About subtitles, you said you would work on it at some point. But are you interested in jfs stuff ? Or do you prefer to implement it your way ?
I know subtitles support is not a priority for you, but for those simple users as me, it's the only thing which prevents your rendered from being used as the default one and then, to help reporting bugs. Anyhow, your motivation and your work (no problem since v0.1) are really appreciated. Thank you for that. |
28th April 2009, 19:43 | #659 | Link | |||
madshi
I am not a video expert. So I just quote recognized authority Don Munsil. dmunsil http://archive2.avsforum.com/avs-vb/...2&page=3&pp=30 #88 (very interesting thread by the way) Quote:
