17th October 2019, 03:28 | #6761 | Link |
@wushantao
Thank. Updated in r4846. @ryrynz This is not a simple request.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
17th October 2019, 03:47 | #6762 | Link |
No-no, bad idea.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
18th October 2019, 07:14 | #6763 | Link |
I suggest mpv or mpv.net for this. In the Input Editor of mpv.net or input.conf file of mpv, you can bind keys for the write-watch-later-config command; search for "watch-later" in the mpv manual. An advanced alternative would be a bookmark script from the User Scripts page at the mpv wiki.
Win 8.1 -- Core 2 Duo E7300 & Intel Q43 GMA 4500 |
18th October 2019, 16:36 | #6764 | Link |
MPC-BE 1.5.4 (build 4850) beta (SF.net) with digital signature.
MPC-BE 1.5.4 Nightly builds: main file store, alternative 1, alternative 2 Also new and old versions can be found on VideoHelp.com. Last edited by v0lt; 12th December 2019 at 15:19. |
22nd October 2019, 12:58 | #6767 | Link | |
cosmic entity
Thanks a bunch... Is there a Changelog? |
22nd October 2019, 13:35 | #6768 | Link |
22nd October 2019, 17:02 | #6769 | Link |
History of changes in English will be in the "stable" version only.
24th October 2019, 05:31 | #6770 | Link | |
李姗倩 Lǐ Shān Qiàn
https://sourceforge.net/p/mpcbe/code...g/?path=/trunk in that JavaScript is not required to browse. The diffs 4488 vs 4850 have more than 50000 lines (!) one can't practically browse everything. What an active project, alive and kicking... |
24th October 2019, 16:38 | #6772 | Link |
@Scorpio666
See menu Veiw -> Controls (Ctrl+2). @wushantao, @Klaus1189, @beter I clarified the name of the option in English in r4860. "Return initial window position and size after closing file" It turned out a long name. I think it can be made shorter. "Return initial window after closing file" In any case, please correct the translations, if necessary.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 24th October 2019 at 16:45. |
24th October 2019, 17:13 | #6773 | Link |
Compact mode? ALT+3 ?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
24th October 2019, 17:31 | #6774 | Link |
@Scorpio666:
Do I get you right, that you want to hide the controls, but make them visible when you move the mouse curser over the place where the controls are located normaly which is here over the videoframe itself and not under the videoframe? @v0lt: Thank you, I tested that feature when you added it and love it for daily use. The translation still fits, i made something like "reset the window after closing the file", so both size and position is mentioned. Like @Liisachan already wrote, so many commits for finetuning the player. You devs are the best I love to contribute as much as I can and being a small active part of it (passive user before and for over 5,5 years an active translator of this project) |
25th October 2019, 18:52 | #6776 | Link | |
I have found a small issue with the internal renderer, under: Options -> Subtitles -> Autoload paths: - ok: .;.\subtitles;.\subs;.\sub;d:\subtitles;d:\subtitles\series - no: .;.\subtitles;.\subs;.\sub;d:\subtitles\;d:\subtitles\series\ Note the \ at the end of the additional directories. Both works in MPC-HC.
26th October 2019, 01:24 | #6777 | Link | |
26th October 2019, 11:58 | #6778 | Link |
There is no such possibility.
27th October 2019, 07:48 | #6779 | Link |
Hello, reporting 2 minor bugs:
1. Please disregard The boss key doesn't instantly hide the player in Windows 7. In MPC-HC, hitting boss key instantly hides player, while in MPC-BE, the minimize animation gets shown by Windows which allows the boss to see that I just hid something. 2. Stutter when watching youtube at higher-than-normal playback speed. For example, if I watch a youtube video at 2x speed, after a minute the picture will start stuttering and, a few seconds later, the sound as well. Interestingly, pausing the video doesn't help - once I unpause the stuttering will continue. What helps is either seeking or readjusting playback speed (e.g. 2x -> 1.9x -> 2x). Playing the same videos in the normal youtube player at the same 2x speed in Google Chrome, there's no stutter at all. The higher the playback speed, the sooner this issue appears - at 1.4x and below it almost never happens, at 2.5x and higher it's pretty much unwatchable. Please let me know if there's a good way to debug this further. Thanks! Last edited by o9od2061; 27th October 2019 at 08:54. |
27th October 2019, 08:09 | #6780 | Link |
@o9od2061
1. Does MPC-HC close without animation on Windows 7? Please tell the player versions. 2. Try to specify in the settings of the YouTube parser MP4 720p. YouTube does not allow you to quickly download other formats (DASH, when audio and video are separate). Such formats cannot be played fast.
