8th January 2010, 20:14 | #881 | Link |
@neuron2
thanks a million will let you know of any bugs if i find any
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
8th January 2010, 23:01 | #884 | Link |
First off, thank you immensely for all your wonderful software. NV Tools is very helpful on my old computer, allowing me to encode HDV to SD MPEG2 in near real time.
I was wondering, would it be possible to include GPU-accelerated YV12 to YUY2/RGB upsampling in the decoder? This would be helpful for my purposes. |
8th January 2010, 23:45 | #886 | Link |
@neuron2
can you test lastest build of DGIndexNV with this build of StaxRip so we can get them working together all you have to do is set the path to DGIndexNV.exe with license in StaxRip and remove -f from arguments stax76 does'nt have a Nvidia GPU so i'am helping him i'll really appreciate it if we get this to work cause lastest build you uploaded works flawless for me manually with StaxRip either cuda driver crashes on me or DGIndexNV.exe i dont think this problem is unfixable it just need's some team work looking at the problem testing then fixing whatever you need of me just let me know
9th January 2010, 00:19 | #888 | Link |
@neuron2
you can use the version you are using ignore the message about the version as long as you have AviSynth installed your fine
9th January 2010, 00:21 | #889 | Link |
@neuron2
AviSynth is all everything else is included nothing gets installed on your pc
9th January 2010, 00:23 | #890 | Link |
@neuron2
if your OS is Windows 7 you have .NET installed and that would be the only other requirement
9th January 2010, 00:37 | #893 | Link |
9th January 2010, 00:38 | #894 | Link |
@neuron2
thanks bud
9th January 2010, 01:21 | #897 | Link |
@neuron
you can load it manually right click in filters
9th January 2010, 01:22 | #898 | Link |
@neuron2
almost everything in StaxRip is customizable
9th January 2010, 01:37 | #900 | Link |
The problem is that StaxRip is generating a script with the loadplugin at the bottom instead of the top of the script:
DGMultiSource("F:\Streams\AVC\alba temp files\alba.dgi") Width % 8 != 0 || Height % 8 != 0 ? Crop(0,0, -Width % 8,-Height % 8) : last IsYV12(last) ? last : ConvertToYV12(last) LoadCplugin("E:\tmp\StaxRip\Applications\AviSynth plugins\Yadif\yadif.dll") Yadif() Crop(0,0,-0,-0) loadplugin("E:\Don\Programming\C++\DGDecNV\DGMultiDecodeNV\Release\DGMultiDecodeNV.dll") If I move it to the top the script opens. Obviously, StaxRip has to put the loadplugin lines at the top. |
