4th December 2005, 21:17 | #101 | Link | |
Paldo-GNU/LinuxMaintainer
atm NO SVCD encoding
*MATRIX AUTOQ2 got changed to *MATRIX AVAMAT7 *MATRIX AVAMAT6 was added. I found out that HC shoots over the max bitrate also if you using cq_maxbitrate. So you can't do a SVCD with 2400 as max bitrate. I added a notice to my final release of GetCQ Code:
================================================== -------------------------------------------- | HCbatch - MPEG2 encoder - rel. 0.16 beta | -------------------------------------------- input: c:\programme\getcq\avs\gcqprediction.avs output: h:\out.m2v -------------------- | encoder settings | -------------------- profile: FAST frames: 1 2448 framerate: 25.00 aspect ratio: 4:3 bitrate: NA max. bitrate Kb/s: 2400 pass: 1 (Constant Quant) constant Q: 31.000 closed gops: no VBV check: yes scene change det.: yes interlaced: yes, TFF goplen,B-pic: 12 2 dc_precision: 10 scan method: ALTERNATE bias: 30 chapter frames: 0 time code: 0 0 0 0 CPU: SSE2 matrix: AVAMAT6 -------------------- | source stats | -------------------- nr. of frames in source: 2448 width*height: 480*576 fps: 25.00 nr. of frames to encode: 2448 frames to encode: 1 - 2448 --------------------- | encoding - pass 1 | --------------------- pass 1 encoding time: 0:01:09 (69 s) average fps: 35.7 ------------------ | encoding stats | ------------------ total encoding time: 0:01:09 (69 s) intra matrix used 8 16 19 22 26 27 29 34 16 16 22 24 27 29 34 35 19 22 26 27 29 34 35 38 22 22 26 27 29 34 35 40 22 26 27 29 32 35 40 48 26 27 29 32 35 40 48 50 26 27 29 35 40 48 50 60 27 29 35 40 48 50 60 62 non-intra matrix used 16 20 24 28 32 36 40 44 20 24 28 32 36 40 44 48 24 28 32 36 40 44 48 52 28 32 36 40 44 48 52 56 32 36 40 44 48 52 56 58 36 40 44 48 52 56 58 60 40 44 48 52 56 58 60 62 44 48 52 56 58 60 62 62 nr. of gops: 208 nr. of frames: 2448 nr. of I-frames: 208 nr. of P-frames: 782 nr. of B-frames: 1458 average quant (non linear): 31.000 VBV underflows detected: 0 VBV underflows fixed: 0 minimum bitrate: 612 maximum bitrate: 2859 average bitrate: 866 ================================================== ================================================== -------------------------------------------- | HCbatch - MPEG2 encoder - rel. 0.16 beta | -------------------------------------------- input: c:\programme\getcq\avs\gcqprediction.avs output: h:\out.m2v -------------------- | encoder settings | -------------------- profile: FAST frames: 1 2448 framerate: 25.00 aspect ratio: 4:3 bitrate: NA max. bitrate Kb/s: 2400 pass: 1 (Constant Quant) constant Q: 1.000 closed gops: no VBV check: yes scene change det.: yes interlaced: yes, TFF goplen,B-pic: 12 2 dc_precision: 10 scan method: ALTERNATE bias: 30 chapter frames: 0 time code: 0 0 0 0 CPU: SSE2 matrix: AVAMAT6 -------------------- | source stats | -------------------- nr. of frames in source: 2448 width*height: 480*576 fps: 25.00 nr. of frames to encode: 2448 frames to encode: 1 - 2448 --------------------- | encoding - pass 1 | --------------------- pass 1 encoding time: 0:05:14 (314 s) average fps: 7.8 ------------------ | encoding stats | ------------------ total encoding time: 0:05:14 (314 s) intra matrix used 8 16 19 22 26 27 29 34 16 16 22 24 27 29 34 35 19 22 26 27 29 34 35 38 22 22 26 27 29 34 35 40 22 26 27 29 32 35 40 48 26 27 29 32 35 40 48 50 26 27 29 35 40 48 50 60 27 29 35 40 48 50 60 62 non-intra matrix used 16 20 24 28 32 36 40 44 20 24 28 32 36 40 44 48 24 28 32 36 40 44 48 52 28 32 36 40 44 48 52 56 32 36 40 44 48 52 56 58 36 40 44 48 52 56 58 60 40 44 48 52 56 58 60 62 44 48 52 56 58 60 62 62 nr. of gops: 208 nr. of frames: 2448 nr. of I-frames: 208 nr. of P-frames: 782 nr. of B-frames: 1458 average quant (non linear): 10.725 VBV underflows detected: 0 VBV underflows fixed: 0 minimum bitrate: 1962 maximum bitrate: 2859 average bitrate: 2255 ================================================== ================================================== -------------------------------------------- | HCbatch - MPEG2 encoder - rel. 0.16 beta | -------------------------------------------- input: h:\vts_01_1.d2v.avs output: h:\out.m2v -------------------- | encoder settings | -------------------- profile: FAST frames: 1 40392 framerate: 25.00 aspect ratio: 4:3 bitrate: NA max. bitrate Kb/s: 2400 pass: 1 (Constant Quant) constant Q: 1.000 closed gops: no VBV check: yes scene change det.: yes interlaced: yes, TFF goplen,B-pic: 12 2 dc_precision: 10 scan method: ALTERNATE bias: 30 chapter frames: 0 time code: 0 0 0 0 CPU: SSE2 matrix: AVAMAT6 -------------------- | source stats | -------------------- nr. of frames in source: 40392 width*height: 480*576 fps: 25.00 nr. of frames to encode: 40392 frames to encode: 1 - 40392 --------------------- | encoding - pass 1 | --------------------- pass 1 encoding time: 1:23:13 (4993 s) average fps: 8.1 ------------------ | encoding stats | ------------------ total encoding time: 1:23:14 (4994 s) intra matrix used 8 16 19 22 26 27 29 34 16 16 22 24 27 29 34 35 19 22 26 27 29 34 35 38 22 22 26 27 29 34 35 40 22 26 27 29 32 35 40 48 26 27 29 32 35 40 48 50 26 27 29 35 40 48 50 60 27 29 35 40 48 50 60 62 non-intra matrix used 16 20 24 28 32 36 40 44 20 24 28 32 36 40 44 48 24 28 32 36 40 44 48 52 28 32 36 40 44 48 52 56 32 36 40 44 48 52 56 58 36 40 44 48 52 56 58 60 40 44 48 52 56 58 60 62 44 48 52 56 58 60 62 62 nr. of gops: 3398 nr. of frames: 40392 nr. of I-frames: 3398 nr. of P-frames: 10162 nr. of B-frames: 26832 average quant (non linear): 10.291 VBV underflows detected: 0 VBV underflows fixed: 0 minimum bitrate: 1526 maximum bitrate: 4057 average bitrate: 2242 ================================================== |
5th December 2005, 06:12 | #102 | Link |
Thank you Ebobtron, video_magic, prodater64. I will read the pdf and follow the advice. Didn't know about the "" where there are spaces.
@prodater64 I haven't been following MPEG2 encoders for more than a year now but followed the development of QuEnc for awhile. The problem there was the rate control was broken in ffmpeg. Also, have heard that TMPGenc has some specs issues. I was hoping that HC gives truly compliant MPEG2 streams, but your last post seems to indicate that there are problems here too... Do I follow you correctly? |
5th December 2005, 08:15 | #103 | Link | |
I don't know from what post mine i could make you think that HC streams are not compliant! (or you quoted me wrongly). Hank315 said that HC Encoder gives compliant streams (in multipass vbr or cq_maxbitrate modes). I didnt investigate the stream structures, only play it in mi unique SAP, so weirdly could i to talk about compliants.
Prodater64 |
5th December 2005, 10:21 | #104 | Link | |
AUTOQ2 is the only reference. IF HC016.PDF document exists and reflect this changes for AVAMAT, where can I get it? Best regards. Last edited by alfixdvd; 5th December 2005 at 10:25. |
5th December 2005, 17:28 | #105 | Link | |
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
5th December 2005, 18:16 | #106 | Link | |
5th December 2005, 21:09 | #107 | Link | |
Errant Knight
http://forum.doom9.org/showthread.ph...836#post738836 Ebobtron http://members.aol.com/avsfilmcutter |
15th December 2005, 23:07 | #108 | Link |
HCenc author
The GUI for HC016 is finally finished, also some bug fixes for the batch version and the manual is updated.
The GUI version doesn't have a built in encoder anymore, it uses the batch version for encoding. It has some new features: - load and save ini files - preview function - setting chapter points Get it at http://hank315.dyndns.org/HC_016.zip Recommended Avisynth version: 2.5.6a |
16th December 2005, 00:15 | #109 | Link |
woman @ german doom9
Hello hank315, tested the straight final. It is already again the freezing error available. This was noticeable to me already in the beta GUI and evening yesterday by VNC session LigH showed.
Test-Scripts: Code:
v1=ImageReader("*path*\MIXVideo.bmp",0,0,25,pixel_type="rgb24") v2=Loop(v1,18).FadeIn(28,$FF0000) v3=AlignedSplice(v1,v2,v1) v3=LanczosResize(v3,720,576) return ConvertToYV12(v3) ---- OR ----- v1=ImageReader("*path*\MIXVideo.bmp",0,0,25,pixel_type="rgb24") v2=Loop(v1,18).FadeIn(28,$FF0000) AlignedSplice(v1,v2,v1) LanczosResize(720,576) ConvertToYV12() sorry google translate
katjarella by Creyskull Visuell Design |
16th December 2005, 01:22 | #110 | Link |
katjarella - i tried the second example and all worked fine. can you say what exact settings you used in HC ? also have you updated to avisynth 2.5.6 ?
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1) |
16th December 2005, 04:46 | #111 | Link |
@hank315
I dont know if this is a bug or not but when I load a avisynth script into the GUI it doesnt read the movie info, I can't change the bitrate, everything on the "preview chapters" tab is grayed out, and "encode" button is grayed out. |
16th December 2005, 07:20 | #112 | Link | |
Gold (Au) Member
Regards,
*********************************************************** Don't assume anything...Verify! It's as easy as 3.14159265 The Problem is Usually found between the Chair and the Keyboard! |
16th December 2005, 10:58 | #113 | Link |
VideoLinux Developer
@feedback
The .exe in this .zip is still called HCbatch_0.16 but when running the title bar reports HCbatch0.16A beta so not sure about 0.16.0.1 you mention Used it last night to encode a movie with RB and quality seems very good at first glance |
16th December 2005, 18:22 | #116 | Link |
Errant Knight
@ Hank,
Wow, another great improvement. Love the new gui. Question: Are we stuck with the frame offset between AviSynth and HC? HC's frame 10 is AviSynth's frame 9. A feature I intend to add to avsFilmCutter's scene editor is a chapter list generator much like the one in HC's gui. I can offset my list, but it would be nice if I did not have to. What say you? Feature request: Because you have the best scene detector I have ever seen. Could you maybe create a non encoding scene detection pass for HC. Which we could then look at and modify as needed. Again, great work and thank you for it. Ebobtron Last edited by Ebobtron; 16th December 2005 at 18:24. |
16th December 2005, 21:40 | #118 | Link | ||
HCenc author
@All
The batch version (0.16.0.1 = HCbatch016A) just didn't made into DVD-RB 1.05 because at the time I mailed it to jdobbs the 1.05 package was already finished. The 0.16.0.1 version solves an error using *CQ_MAXBITRATE in which it could get stuck. So for those who want it to use it with DVD-RB just rename and copy/replace it. @katjarella I ran the first script and it came out OK with all settings I tried... Will mail you about it. @neo squidward If you check the version with the button "Avisynth info" what does it say? Also if loading an Avisynth script fails the info window should give the error message generated by Avisynth, what does that say? @Ebobtron Quote:
Just kidding... But you're right, it would be more compatible with other video apps. Will be in the next release. (Although I still dislike the idea ) Quote:
16th December 2005, 22:33 | #119 | Link |
Google did not certainly translate correctly. And my Translators (LigH, scharfi) cannot be attained.
The HCbatch_016.exe functions. Only the HCGUI_016.exe remains hanging from time to time, if I load a Script. In the GUI see I "AVS file opened" and then still freezes it. Then I must close the Process so long and load different Scripte, until it functions times again. Also the GUI default Settings load , help here not always.
