Old 23rd April 2008, 19:41   #4401  |  Link
nautilus7
nautilus7's Avatar
It seems that eac3to is happy with the TrueHD track, but the libav decoder is not. I've never seen that "[libav] Stream parameters not seen; skipping frame" complaint before yet. Funnily now both you and Chouonsoku seem to have this problem within a few minutes of each other - with different movies! Strange...
I am quite sure i came across this error a few days ago with a truehd stream, but can't remember. Nero on the other hand dealed with the track fine.
nautilus7 is offline
Old 23rd April 2008, 19:47   #4402  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Hmmmmm... Did you download eac3to from my homepage? Did you replace some dlls? If not, I can only guess that it's a bad rip. Or that the TrueHD decoder suddenly stopped working. Or maybe there's a new bug in v2.41?
I have done nothing unusual to the contents of the eac3to folder. I'm reriping it now for some more clarity.
saint-francis is offline
Old 23rd April 2008, 19:48   #4403  |  Link
madshi
If anyone can provide a little sample which produces that "[libav] Stream parameters not seen; skipping frame" complaint, that would be helpful. I'd then forward it to the libav TrueHD decoder programmer. (If it proves to be a bad rip, this is not necessary, though.)
madshi is offline
Old 23rd April 2008, 20:20   #4404  |  Link
Chouonsoku
I've uninstalled and reinstalled Nero and I'm still getting an error with the eac3to test for Nero Audio Decoder. I'm not sure why it wouldn't be working as I know I've decoded EAC3 tracks with Nero before. =/
Chouonsoku is offline
Old 23rd April 2008, 20:42   #4405  |  Link
saint-francis
too much lurking
It failed on rerip too. Works fine with nero though. How does one make a sample? Could someone point me to a simple guide?
Also is there a way I can demux only that track? The -demux switch demuxes everything and I don't need to do that again.
Old 23rd April 2008, 20:45   #4406  |  Link
nautilus7
nautilus7's Avatar
I can't send a sample, because i deleted the ripped movie and i don't have any time to re-rip it... but i remember which movie was it. The Fifth element Remastered Blu-ray.
Old 23rd April 2008, 20:49   #4407  |  Link
madshi
Can't help you there. You've registered the HD DVD/Blu-Ray plugin, right?
Easiest way would be to use a hexeditor. E.g. this free one:
http://www.mh-nexus.de/
Just remove everything except the first 50MB.
madshi is offline
Old 23rd April 2008, 21:18   #4408  |  Link
Thunderbolt8
converted this one to flac already (with a pre-2.41 version though) and had no problems with it, using the standard decoder. did that approx. 1-1,5 months ago. that track is said to be 20-bit btw.
Thunderbolt8 is offline
Old 23rd April 2008, 21:22   #4409  |  Link
saint-francis
too much lurking
How does one do this exactly? All I see is a screen full of many characters. Some I understand as conventional numbers and letters and some I don't.
Old 23rd April 2008, 21:57   #4410  |  Link
nautilus7
nautilus7's Avatar
I did it with 2.40 i think. I also some tests... It happens only with Blu-ray TrueHD streams. I got this error with Blade Runner just now, but not with a HD DVD i tried.
Madshi, if you don't have any Blu-ray Disc with TrueHD, i 'll send you a sample.
Saint-francis, you just select the first 50 MB and copy-paste them to a new file. It's not necessary to upload the sample, i believe. I can do it, since i found one.
Old 23rd April 2008, 22:14   #4411  |  Link
saint-francis
too much lurking
IIt happens only with Blu-ray TrueHD streams. I got this error with Blade Runner just now, but not with a HD DVD i tried.
Yes HD DVD TruHD files still work for me. This is the first BD TruHD file I've encountered though.
Saint-francis, you just select the first 50 MB and copy-paste them to a new file. It's not necessary to upload the sample, i believe. I can do it, since i find one.
Good, because I can't make heads nor tails out of what this hex editor is telling me. :P
Old 23rd April 2008, 22:15   #4412  |  Link
bsw11
If eac3to outputs 2 channels, but you are certain there are 6 channels, then there is a bug somewhere.
Your original track is a vob file? From dvd? Or dts wav cd? I 'm confused... Anyway can you upload a sample of the original track (dts/vob/wav/whatever) that eac3to decodes as 2 channel?
I don't think there is any audio editor that can edit dts tracks without decoding first.
Yes I am 100% certain its a 6 ch DTS wav file.
And as I stated it came from a vob file that was a DTS Audio DVD. - where the audio tracks are on the VIDEO_TS folder and I used VOBORATOR to extract them.
http://alphabase.com/downloads/testDTS.wav is the smallest test file I had.
Thanks for you help on this.
BSW
bsw11 is offline
Old 23rd April 2008, 22:53   #4413  |  Link
nautilus7
nautilus7's Avatar
Are you sure the file is ok? eac3to detects it as wav, not dts wav and i can't play it correctly.
Furthermore, eac3to can deal with vob files directly, so vobrator isn't needed. Try eac3to with the vob files.
Old 23rd April 2008, 23:40   #4414  |  Link
bsw11
I am 100% sure that file plays as a 6 ch dts using zplayer.exe (once its setup correctly).
I did try the VOB and it looks like its going to work - but I don't have the sonic decoder. I do have nero 7 on this PC, but I still get an error:
Decoding with DirectShow (Nero Audio Decoder 2)...
The DirectShow audio decoder didn't accept the input stream.
Aborted at file position 147456.
Can you provide me with a link to a usable decoder?
I am using ac3dts in zplayer - can eac3to use this?
BSW
bsw11 is offline
Old 23rd April 2008, 23:49   #4415  |  Link
nautilus7
nautilus7's Avatar
Do you have nero HD DVD / blu-ray plug-in bought and registered? If not, you can use the libav decoder that ships with eac3to (-libav option).
The command should be like:
eac3to input.vob
to get the id number of the audio dts stream, and then:
eac3to input.vob id_number: output.wavs -libav -resampleto44100
Old 24th April 2008, 00:01   #4416  |  Link
Chouonsoku
I formatted recently and forgot to do that when I installed Nero. Problem solved.
Still getting the TrueHD error though after decrypting and demuxing RE 3 again. Do you happen to still have 2.40 somewhere so I can see if there error exists with that version?
Old 24th April 2008, 00:51   #4417  |  Link
bsw11
eac3to input.vob
OK - that worked great! - I did not even have to get the id first - your program just figured it out and did the deal.
However your decoder definitely has a bug in that it is not figuring out .wav files that are dts encoded. I have tired a few other files - ones that are already 44k and they have exactly the same problem - they are calling it a 2 ch file - which by the way it is written as a 2ch file to fake out cd players into streaming the 2 channels to a decoder which then decodes the 6 channels. So my guess is that you need more code to figure out that there is really 6 channels there. Hopefully this can get fixed as I have a lot more files already .wav files that I won't be able to split up.
Thanks for you help!
BSW
bsw11 is offline
Old 24th April 2008, 00:55   #4418  |  Link
Chouonsoku
Well, whatever problem I had, it's fixed now. I demuxed the m2ts file through eac3to and then opened the TrueHD track without the AC3 track embedded and it's encoding to FLAC now.
Edit: I forgot that I updated to the latest ffdshow nightly build from XXL today. That may or may not have fixed the libav error.
Old 24th April 2008, 01:00   #4419  |  Link
nautilus7
nautilus7's Avatar
eac3to it's not my program! It's madshi's! He should get all the credit (and the blame ).
Though, what you mention about dts-wav support not being complete might be true. Perhaps madshi can have a look at the sample you uploaded in your previous post...
Old 24th April 2008, 01:04   #4420  |  Link
nautilus7
nautilus7's Avatar
ffdshow has nothing to do with the libav decoder that eac3to is using.
This truehd decoding bug, i think, isn't libav related, since it works for hd dvd tracks, but an eac3to bug. Furthermore, it was introduced in the recent versions of eac3to, where no libav update was done.
eac3to
