Old 19th June 2018, 10:58   #51421  |  Link
SirSwede
Originally Posted by Clammerz View Post
No. When LAN Access is disabled, the madHcCtl process does not listen to any network traffic. Even if you accidentally enabled it, Windows firewall will block it by default unless you allow it's traffic.
SirSwede is offline   Reply With Quote
Old 19th June 2018, 21:23   #51422  |  Link
kostik
Got my new LG OLED C8 tv but cannot set RGB to 10/12bit. RGB allows only 8bit with 4K resolution . Only YCbCr 4:2:2, 4:2:0 allow 8bit + , where YCbCr 4:2:2 allows 10bit (should be native) and 4:2:0 allows only 8 or 12bit (and YCbCr 4:4:4 allows only 8bit) . Which one should I use ?
kostik is online now   Reply With Quote
Old 19th June 2018, 21:40   #51423  |  Link
Asmodian
RGB 8 bit, for sure. Also, my C7 does better with 8 bit input compared to 10 bit, less banding with 8 bit (as counterintuitive as that is), but even without the limitations of my display 8 bit RGB is much better than 10/12 bit with 4:2:2 or 4:2:0.
Edit:
This is assuming you are using a "PC" mode on your display. If you use any other mode your TV will process in 4:2:2 so you might as well send it 10 bit 4:2:2. Much better to use a PC mode with 8 bit RGB input but if you like any of the features that are disabled while in PC mode maybe another mode is worth it to you. madVR becomes less important when using subsampled chroma, still better than alternatives but you lose much of the quality difference, RGB FTW.
madVR options explained
Old 19th June 2018, 22:03   #51424  |  Link
mclingo
the problem with using PC mode is that is disables TRUMOTION on LG OLEDs, this I find essential as with no motion blur between frames due to super fast response time compared to LED you can get jagged edges on bright areas in pan shots. A good example of this is at the beginning of elysium when the earth pans away form the space station, with TRUMOTION on with a low setting of 3, with my EF9500 I get a smooth sharp picture with no wobbly edges, option 3 isnt enough to give the nasty soap opera effect for me but this is subjective.
difference is night and day for me, I could not live without this.
I'm currently using 4:4:4 full RGB and letting my players and madvr do all the switching duties.
Old 19th June 2018, 22:11   #51425  |  Link
mclingo
Latest AMD drives including 18.5.3 and 18.6.1 disables auto HDR switching in MADVR for me, guessing its something to be with being optiimised for windows 10 1803, i've had to go all the way back to 18.2.2 to find a stable fully working driver.
Anyone else on win 10 1709 using latest AMD driver 18.6.1 can HDR autoswitch on their TV?
Anyone else with win 10 1803 using latest AMD driver 18.6.1 can HDR autoswitch on their TV?
Old 20th June 2018, 02:34   #51426  |  Link
ultrahd_hdr
I have tried 18.6.1 on 1803 and it's not working,only 18.2.1 and 18.2.2
ultrahd_hdr is offline   Reply With Quote
Old 20th June 2018, 10:38   #51427  |  Link
mclingo
thanks for that, this isnt good, add this to the long list of other problems with 1803
Good to know its not just me though, i'll look at logging this with AMD, dont know is MADSHI needs to investigate as well though?
Old 20th June 2018, 10:59   #51428  |  Link
mclingo
I've logged this with AMD but also popped a bug on MADVR just in case MADSHI wants to have a look, there might be a workaround as HDR can still be toggled in windows itself using the HDR on / off toggle in display settings.
Old 20th June 2018, 16:48   #51429  |  Link
mrmojo666
in my opinion are the amd drivers the problem, this hdr auto switch missing is started happening some months ago upgrating drivers > 18.2.1. It stopped working also with winvideo player not just in madvr with recent drivers
mrmojo666 is offline   Reply With Quote
Old 20th June 2018, 17:23   #51430  |  Link
giulianoprs
I have a perplexity, I'm using madvr recently, today I tested with mpc-be + madvr, vlc and kodi17.6 with a 1080p file of the tv series "the walking dead", I chose this tv series because it presents in the video a lot noise, a kind of small dots that swarm, here with mpc + madvr the image was not better than vlc or kodi, indeed it had more noise, video noise, this is the dithering? but madvr did not have to improve the general picture of the image?
am I wrong in my settings?
-artifact removal- reduce banding active arrtifact, all the other off.
-image enhancements in default, off!
-scaling algorithms,
--chroma upscaling-super-xbr -sharpness 100, activate anti ringing filter ACTIVE.
-image upscaling -JINC -anti-ringing filter ACTIVE.
-upscaling refinement, default, all off.
--dithering- error diffusion-option 1 !!!
--trade quality for perfomance-all disabled
Thanks and bye
giulianoprs is offline   Reply With Quote
Old 20th June 2018, 17:58   #51431  |  Link
SamuriHL
SamuriHL's Avatar
This is probably old news but I wanted to report it anyway. With v0.92.14 I'm not able to render subtitles in JRiver MC24. Going back to v0.92.4 fixes the issue so I'm not sure when it started.
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 20th June 2018, 18:29   #51432  |  Link
brazen1
For the noise you see, use 'reduce compression artifacts'. Helps to map the feature to your remote control and toggle the intensity 1-10.
W10v1809 X5690 9604GB RGB 4:4:4 8bit Desktop @60Hz 8,10,12bit @Matched Refresh Rates
KODI MPC-HC/BE PDVD DVDFab
65JS8500 UHD HDR 3D
Old 20th June 2018, 18:54   #51433  |  Link
Warner306
Thanks and bye
Definitely not dithering. The image has compression artifacts and/or film grain and madVR is doing a faithful representation. Such is life with bad sources. As brazen said, try reduce compression artifacts. Also try using NGU image upscaling. It should do a better job of ignoring the noise, but it won't remove it. Reduce banding artifacts might even leave some noise in these scenes where it removes the banding. This is usually the case with dark scenes with debanding set to medium.
Reduce random noise might also be worth trying.
Old 20th June 2018, 19:38   #51434  |  Link
brazen1
Fyi, bad compressed sources are not the only cause of noise. Many, (too many imo) titles have excessive grain. Personally, I don't like any and find myself running to RCA to process the crap out of it. I know it's subjective but I can't stand it tbh. Even at the expense of detail loss, removing grain looks better to me. If I had more processor and memory, I'd sharpen it up after removing as much noise as possible. So glad madshi created it for us!
This is why I prefer video over film. Modern video rarely has grain or noise that I notice. I wish everything was created in video. Instead of burning frames to nitrate (I mean come on, this is the standard since motion pictures was developed), capture it straight to the digital chip. Clean, fast real time, and post processing a breeze. No more waiting for film to be developed. No guess work how the scene is going to look after processing. Etc. TBH, I think the only reason film is still around is to keep cinematographers and colorists employed. Perhaps some editors. With video, I don't think we need them and their old school expertise. Sure would cut down on production costs too. If the savings were passed to consumers (yeah sure) perhaps a movie ticket and/or a disc price would become realistic. Few are willing to break the chain imo. Hollywood is in constant fear of heads rolling and no one dare rock the boat. Politics, all of it. I think those that prefer this antiquated film and voice it anytime someone has something to say contrary, is shaking in their boots.
What's that saying? No grain..... no pain?
65JS8500 UHD HDR 3D
Old 20th June 2018, 19:58   #51435  |  Link
Quiet
Cube LUT
Is it possible to use this kind of LUT's (.cube) in madVR by converting or directly:
https://www.dropbox.com/s/ezzdqrvjsj...elut.cube?dl=0
Quiet is offline   Reply With Quote
Old 20th June 2018, 21:18   #51436  |  Link
starlight2
Hi, i have a projector FullHD and gtx 970. I watch only mkv 1080p you could advise me the best setting for the boost image quality? I have to use only chroma with ngu? what else do you recommend?
Thank you
starlight2 is offline   Reply With Quote
Old 20th June 2018, 21:40   #51437  |  Link
mclingo
if i'm honest i'm not 100% sure, I am sure 18.5.2 was working the other day and now it isnt, i'm only back to 18.2.2 though because later drivers have been unstable for me, random freezes mainly using RDP conections to my machine from work.
18.2.2 is very stable for me, everything works as it should as far as I can tell.
EDIT, I have the blown out reds issue again after going back to 18.2.2, I need to look into this further.
Old 20th June 2018, 23:01   #51438  |  Link
giulianoprs
ok, I try this way, thanks to everyone, although I believe that with those filters set I will put a strain on my gpu, sorry my english not correct, hello and good evening !!!
Old 20th June 2018, 23:18   #51439  |  Link
Quiet
Just here to say that grain is life.
Old 20th June 2018, 23:30   #51440  |  Link
jmone
Related issue is that on BD Menus some of the Button Text is drawn off screen.
jmone is offline   Reply With Quote
