Old 13th March 2012, 11:55   #14861  |  Link
haruhiko_yamagata
Haruhiko, have you ever considered a version with has the audio and video decoders removed?
Nope.
You can disable a filter from its dialog, DirectShow control -> Multiple ffdshow instances: "none disabled".
I think it is possible to register filters separately by some code change, although I have no plan. You might ask clsid for an opinion.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 13th March 2012, 12:06   #14862  |  Link
Nya_Su
Originally Posted by haruhiko_yamagata View Post
@Nya_Su,
fixed at rev 4382. Thanks.
Thanks a lot!
Nya_Su is offline   Reply With Quote
Old 13th March 2012, 20:18   #14863  |  Link
VipZ
Nope.
If you interested I have made a patch previously to do just that, I just replicated the option code for DXVA to all the other filters. Just like DXVA code, if the registry value isn't set its as if there is no change.
Patch, http://www.mediafire.com/file/5i0rhl...regpatch.patch
The above isn't tested to latest SVN, last time I used this was against 3985.
Windows 10 Pro x64 (1809), CPU: Core i7 6700K, GPU: GeForce GTX 980 /w 417.71, Audio: HDMI to Yamaha RX-A3060 (5.1)
VipZ is offline   Reply With Quote
Old 14th March 2012, 18:44   #14864  |  Link
kasper93
MPC-HC Developer
Could you look at this sample http://dl.dropbox.com/u/16282309/LAV/AR.2.ts at beginning AR is 4:3 and than AR is 16:9. It crash whole player on aspect ratio change point with ffdshow video decoder. Works fine with Microsoft DTV-DVD Video Decoder.
kasper93 is offline   Reply With Quote
Old 16th March 2012, 12:22   #14865  |  Link
haruhiko_yamagata
Crash confirmed. I'll take a look.
Old 17th March 2012, 13:41   #14866  |  Link
haruhiko_yamagata
The crash has been fixed at rev 4389. But sorry, it just avoid crashing.
Libav says, "Width/height/bit depth/chroma idc changing with threads is not implemented. Update your Libav version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented."
So if you set "Number of decoding threads:" 1, everything is fine.
Old 18th March 2012, 00:59   #14867  |  Link
haruhiko_yamagata
Fix linker warnings
To fix the linker warnings saying that the TargetPath doesn't match with OutputFile, I have written a patch.
The warning goes away but more files appear in bin directory.
Is this OK? More files may be a bit annoying...
Old 18th March 2012, 02:24   #14868  |  Link
FlashGordon
I think I've found some odd behavior using ffdshow build 4332. Using libmpeg2 as decoder and opening a specific PAL DVD with mpc-hc, there are certain specific parts where the decoder seems to drop frames. For me, the "glitch" is 100% reproducible under the same conditions, it is always the same times that drop these frames. Here's the odd part: opening just the VOB and playing these parts with libmpeg2 doesn't produce the 'glitch'. Opening the full DVD but using libavcodec for mpeg2 will also play fine. The filter chain when this happens includes the MS DVD navigator (all the others seem to not affect it).
Wish I could get a working sample, but like I said, the individual VOB plays fine with libmpeg2, this only happens when the MS DVD navigator is in use.
Is there any reason why libmpeg2 would be glitching at these parts and libavcodec plays them fine?
FlashGordon is offline   Reply With Quote
Old 18th March 2012, 03:02   #14869  |  Link
haruhiko_yamagata
I don't know.
I think libavcodec is better as MPEG-2 decoder. For example, color space conversion matrix is decoded by libavcodec. libavcodec is faster on current CPU. etc...
Currently libmpeg2 is not maintained. In my opinion, there is no point in maintaining libmpeg2. Recently Intel Quick Sync decoder has been added. Three is too many choice for users.
If no objection, I would remove it.
Old 18th March 2012, 03:12   #14870  |  Link
FlashGordon
I see. Would the IDCT options under "decoder options" affect this? libmpeg2 doesn't use these settings, right? So I'm thinking maybe the DVD company transferred the film badly and libavcodec somehow deals with these glitches better...
Right now I have IDCT on 'auto', workaround encoder bugs on 'autodetect', error recognition on 'careful' and error concealment on 'guess MVS + deblock'. Are these recommended settings?
Old 18th March 2012, 03:52   #14871  |  Link
haruhiko_yamagata
libmpeg2 does not use the settings.
The default settings for Error recognition is "very aggressive". I have not tried various options for that though.
Old 18th March 2012, 04:01   #14872  |  Link
haruhiko_yamagata
NV12 preferred
Because current GPU prefer NV12 to YV12, I have written a patch to prefer NV12 as an output color space.
It doesn't affect image filters except the output filter.
Index: src/imgFilters/ffImgfmt.cpp
--- src/imgFilters/ffImgfmt.cpp	(revision 4388)
+++ src/imgFilters/ffImgfmt.cpp	(working copy)
@@ -420,6 +420,13 @@
             *rank = 200;
         return outPrimaryCSP|(inCSP&~FF_CSPS_MASK);
+    // prefer YV12 to NV12 conversion for the final output. Currently rank is set only for the final output.
+    if (rank && (inCSP & FF_CSPS_MASK) == FF_CSP_420P && (wantedCSPS & FF_CSP_NV12)) {
+        *rank = 101;
+        return FF_CSP_NV12|(inCSP&~FF_CSPS_MASK);
     uint64_t outCSP=inCSP&wantedCSPS&FF_CSPS_MASK;
     if (outCSP) {
         if (rank) {
@@ -1182,8 +1189,8 @@
                 FF_CSP_P216 ,
                 FF_CSP_444P10,
                 FF_CSP_Y416 ,
+                FF_CSP_NV12 ,
                 FF_CSP_420P ,
-                FF_CSP_NV12 ,
                 FF_CSP_YUY2 ,
                 FF_CSP_UYVY ,
                 FF_CSP_YVYU ,
Old 18th March 2012, 04:46   #14873  |  Link
FlashGordon
Is there a reason why that is the default? According to the wiki, it states that valid parts may be detected as errors... would this decrease image quality?
Old 18th March 2012, 05:01   #14874  |  Link
haruhiko_yamagata
Looks like a bug.
Old 18th March 2012, 08:36   #14875  |  Link
CruNcher
CruNcher's Avatar
I don't know.
What ?
in my experience Libmpeg2 is still one of the fastest Single threaded Software decoder (and it can keep very low latency @ the same time), and especially Gabest Decoder used in MPC-HC shows this to it's full potential on Windows especially if you pressure it to the extreme and combine iqualitycontrol with it
and im on Sandy Bridge see https://forum.doom9.org/showpost.php...postcount=9946
Lav Videos used avcodec has no chance it stucks and halts so heavily and due to the multithreading it's latency seems severely higher, and without multithreading i couldn't reach the speeds of libmpeg2 in singlethreaded performance
It is about Time
Old 18th March 2012, 09:02   #14876  |  Link
clsid
Preferring NV12 output is fine with me.
Old 18th March 2012, 09:04   #14877  |  Link
clsid
I rather have a warning than a mess of files.
Old 18th March 2012, 09:36   #14878  |  Link
haruhiko_yamagata
Originally Posted by CruNcher View Post
What ?
Who has single core CPU? I don't think ffdshow should work on Atom. Single threaded performance has no meaning to me.
The latency is higher with frame based multithreading. But what's the inconvenience with it?
The point is that the maintenance is hard. I want to drop it unless the merit is big enough.
// EDIT
As for the dropped frames, I doubt that the performance is relevant. More likely, timestamps are wrong. If frames are dropped using ffdshow, please send me the sample.
IQualityControl: How is it used? It wouldn't be necessary for MPEG-2 at least on Sandy Bridge.
Old 18th March 2012, 10:00   #14879  |  Link
CruNcher
CruNcher's Avatar
I cant do this test with ffdshow because i cant activate SPP to pressure 1 core completely this is just ffdshow used as PP after the decoding and displaying the latency stats of the PP (OSD,SPP overhead distributed to 1 virtual core (25%), while decoding on the same). Also if you say you not interested in Single threading then you should boost some of the PP stuff to Multi threading.
It is about Time
Old 18th March 2012, 10:17   #14880  |  Link
haruhiko_yamagata
Multitheading of PP may be a good feature if I have time to implement.
In my opinion, just single thread performance is not worth for maintenance effort. ffdshow has too many features to maintain. Please understand it is important to drop old stuffs.
